W2 header adapters
#1341842
11/26/12 08:36 PM
11/26/12 08:36 PM
Posts: 3,397 Pa
Hot 340
Pa
Hello yall...anyone know where I can find adapters to fit a set of w2 headers to a stock port and bolt pattern head?
Re: W2 header adapters
[Re: MR_P_BODY]
#1341844
11/26/12 09:48 PM
11/26/12 09:48 PM
Posts: 3,397 Pa
Hot 340
Pa
Mr.P I need the additional space an adapter would provide, because the one tube shrouds plug access on #7. Having the header away from the head would help.
[Re: rt66jim]
#1341846
11/26/12 11:41 PM
11/26/12 11:41 PM
Posts: 239 Lawton, MI
Headhunter22
Lawton, MI
Spdexhaust sells flanges for those heads...don't know if that helps. Here is the link Link Also, out of curiosity is the W2 header worse than this on shrouding the plugs? This is a set of 1 7/8" TTI's for an a-body.> Steve
[Re: Headhunter22]
#1341850
11/27/12 12:16 AM
11/27/12 12:16 AM
Posts: 3,397 Pa
Hot 340
Pa
Good luck, I may just end up making a set of headers instead of cutting / pounding the TTI's. Still in the decision stage here.
Thanks My TTI's arent pounded but the finish needs redone so I am free to alter things a bit.
[Re: Headhunter22]
#1341851
11/27/12 12:21 AM
11/27/12 12:21 AM
Triple Threat
Renton Washington
SPD will make any flange you want. Send them a tracing.
Headers on these things suck.
[Re: topside]
#1341855
11/27/12 03:04 AM
11/27/12 03:04 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
I think i have some spacers that would work in the garage. I'll pm you tommorow with a pic.
68 Barracuda Formula S 340
[Re: Bad340fish]
#1341856
11/27/12 06:48 AM
11/27/12 06:48 AM
Posts: 3,397 Pa
Hot 340
Pa
Let me know. I can make a set but sometimes you are farther ahead to find out if there is anything out there already made.
[Re: mcduff]
#1341859
11/27/12 11:22 AM
11/27/12 11:22 AM
Posts: 12,016 Finally a HUSKER again
Moparnut426
I tried a set of Brodix B1Ba heads on my 408 in my Demon, and Ill tell you what I butchered a set of TTI w2 headers, burned plug wires, had exhaust leaks, Screwed up a number of spark plugs, etc, etc. then I came to realize that I either had to pay for custom headers, build my own which I have never attempted, or had to switch heads. Well luck for me I found a guy to trade my Brodix stuff for a set of Indybrocks.
For the life of me I can not figure out why they used a w2 exhaust port with a standard exhaust flange. Blows my mind, Why not use a standard W2 port/flange.
Wouldnt that be easier??
[Re: mcduff]
#1341860
11/27/12 11:24 AM
11/27/12 11:24 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
I have a set of the Hedman 10220 flanges here that have been ported. I can't remember what heads they were for as I have had the Brodix B1-BA's and the small pattern W2's in the past. They come from Hedman with very small port openings that have to be port matched to the exhaust port if you want to go that route. Center bolt hole spacing is 4", outside bolt hole spacing is approx. 2.125" diagonally, .3125" thick.
Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
