Re: High amp @ idle alt. [Re: finadk] #1340940
11/27/12 07:21 PM
11/27/12 07:21 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I have the same setup that jbc426 has except I went this route.
http://www.amazon.com/Powermaster-47294-...7294+Alternator
It doesn't quite have the power that the CS-144 has but it is close and easier to wire.
Idle amps are about 80 with total output around 140amps
My came with testing specs. (they must test each one after building it) that show the actual output was 154Amps with 95 amps at idle.
Re: High amp @ idle alt. [Re: rapom] #1340941
11/27/12 07:59 PM
11/27/12 07:59 PM
CS-144
To go with that one would a rebuilt one be OK & what year/app should a person ask for?
Re: High amp @ idle alt. [Re: RapidRobert] #1340942
11/27/12 11:11 PM
11/27/12 11:11 PM
IN
ahy Offline
ahy  Offline
IN
High amp at idle and stock look (late 70's). I tried the 140 amp GM case Powermaster first. No fit with a BB and aluminum heads. I ran a 75 amp square back for a while but it just barely kept up when running and gave a big discharge at idle. I switched to this from my 78 Cordoba core engine and it works great. Just heavy.
Re: High amp @ idle alt. [Re: jbc426] #1340943
11/27/12 11:21 PM
11/27/12 11:21 PM
ky hills
thehemikid Offline OP
ky hills
cjskotni...I'm trying to set up for worst case scenario if the fans were needed to be at wide open. If I go with this fan idea, I do plan on running the controller Howzywhatsit (sp) has built for it. I haven't checked with him to see if he has a selector type controller for more of a manual/driver's control of the percentage of output (another topic). Good battery is understood.
jbc426... I'm planing on better than stock head lights on relays, but I haven't got to that bridge yet, the rest of the car will be on LEDs. The CS 144 may be what I have to do. A lot of things I've chose to do have pushed me out of the stock look, but I keep trying.
I have read some on the one wire bypass & the 2 wire with the ammeter & bulkhead connecter deal. I ran into that the hard way back in 85-6. I'll try an run extras on relays.
Mad Electric...I've see the name but haven't read there yet,...will have to do that.
Re: High amp @ idle alt. [Re: RapidRobert] #1340944
11/28/12 02:47 PM
11/28/12 02:47 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
CS-144
I went to my local Alternator/Starter repair shop and bought a rebuilt one. I had him upgrade the internals with a rewound stator & heavy duty, regulator & bridge rectifier. It was around $200.
These CS144 alternators come on late model GM products such as Escalades and full-sized pick-ups etc.
You can also buy them online from several vendors.
This is where I got my adaptor braket.
http://store.alternatorparts.com/cs144-series-200-amp-high-output-stator.aspx
