EFI Fuel tanks/In-tank Fuel pumps #1339043
11/21/12 01:56 PM
11/21/12 01:56 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Is anyone running one of the modern style of tanks? I've got a new spectra tank on the car, but fitting a resivoir to the car is proving tricky.
I'm still not convinced that a new tank is the way to go, but for the sake of civility and packaging it sure would be nice.
I need to have enough fuel in reserve to run the car at WOT for at least 20 seconds.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: AlexP] #1339044
11/21/12 02:04 PM
11/21/12 02:04 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
20 seconds?
WAY too little to run an autocross, and a laugher to run a road course.
What's the purpose of the vehicle?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: amxautox] #1339045
11/21/12 02:10 PM
11/21/12 02:10 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
add an internal pump / sump from rock valley or spring for a tank with it installed already.
best move I ever made on my EFI
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: DJVCuda] #1339046
11/21/12 06:28 PM
11/21/12 06:28 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
http://www.tanksinc.com/index.cfm/page/p...prod/prd253.htm is where I got my universal hanger. Then I built a sump with trap doors, then found an aluminum 25 gallon tank used out of a boat. I got the trap doors from Fuel Safe and they were $90 for the 3.
Mopar to the bone!!!
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: 72Swinger] #1339047
11/21/12 06:30 PM
11/21/12 06:30 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Here it is in the car
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: 72Swinger] #1339048
11/21/12 06:36 PM
11/21/12 06:36 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I originally envisioned having the tank raised above the truck floor about 4" but that wouldnt of allowed me to retain my factory fill location and not have the trunk hinge hit the hose so it now looks like this from the rear. The fill valve is a 45 degree RCI with a flapper.
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: 72Swinger] #1339049
11/21/12 09:00 PM
11/21/12 09:00 PM
IN
ahy Offline
ahy  Offline
IN
I'm running a Ricks Hot Rod Shop tank with Bosch pump inside. The Bosh pump is good for +/- 700 HP... in between the Walbro and Aeromotive A1000. I had it made 1" deeper for an extra gallon or so capacity. Huge improvement over the frame mounted pump. The lines come out in approximatly the stock location so I used OE style steel fuel lines with a length of braided hose for the connections at the tank and in the engine compartment (3/8" supply/8 AN braided, 5/16" return/6 AN braided).
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: AlexP] #1339050
11/24/12 03:34 AM
11/24/12 03:34 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Anyone use the Aeromotive Phantom Fuel system in a stock tank? It looks interesting.
http://www.summitracing.com/search/depar...om-fuel-systems
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: 451Mopar] #1339051
11/24/12 11:01 AM
11/24/12 11:01 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not much cheaper than a new tank built for FI.
Don't be the exception.
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: Supercuda] #1339052
11/24/12 12:08 PM
11/24/12 12:08 PM
East Tennessee
Burkenator Offline
Burkenator  Offline
East Tennessee
Another vote for Rock Valley. Mine works great!
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: Supercuda] #1339053
11/24/12 01:11 PM
11/24/12 01:11 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
How much is a Rock Valley (or other custom) tank? Looking a bit online at some other forums says $1000+, so I'm curious what a Mopar one is worth to be close to the price of that $550 Aeromotive kit..
Paul
'69 Super Bee 383 EFI Turbo
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: AlexP] #1339054
11/24/12 03:51 PM
11/24/12 03:51 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Just another idea (which is popular for retrofits) would be to use a regular carb style low pressure pump to feed a surge tank that feeds the high pressure efi pump. Would work well for a autocross track car too. Down side is that its a bit more complex and you are running 2 pumps. A new sumped tank is better....but more expensive.
I'm working on my efi conversion again, LS1 pcm controlling efi and coil on plug ignition on a BB 440 mopar. I using a Bosch 044 inline pump from a sumped aluminum Hot Rod garage aluminum tank.
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: Black_Bee] #1339055
11/24/12 09:51 PM
11/24/12 09:51 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Mine was 800 including pump.
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: DJVCuda] #1339056
11/24/12 10:26 PM
11/24/12 10:26 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have close to $500 in mine,but it holds 25 gallons.
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: Quicksilver440] #1339057
11/25/12 02:47 AM
11/25/12 02:47 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I am probably going to go this route myself...seems like a cheap and easy way of doing it...
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: Black_Bee] #1339058
11/25/12 12:29 PM
11/25/12 12:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
http://hotrodcitygarage.com/mopartanks.html
Even cheaper system: http://autoperformanceengineering.com/html/pickups.html
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: Supercuda] #1339059
11/25/12 01:35 PM
11/25/12 01:35 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I was just asking if anyone has tried the aeromotive kit? The custom tanks sound like a good deal.
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: AlexP] #1339060
11/26/12 04:35 AM
11/26/12 04:35 AM
Utah
topbrent Offline
topbrent  Offline
Utah
This is how Steve Strope mounted the in-tank pump on the Dust'Ya Duster.
http://www.hotrod.com/featuredvehicles/91658_1971_plymouth_duster/
"To feed the FAST EFI unit, Strope mated a ’90 Corvette in-tank electric fuel pump to the stock Duster sending unit. Operating pressure is 42 psi."
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: topbrent] #1339061
11/26/12 09:14 AM
11/26/12 09:14 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
and they will never tell you if it did - but i bet it had starvation issues. The lack of baffles like the rock valley setup will cause the efi to fall flat on it's face if you expose the pickup and allow it to suck air.
It's the number one issue with retro fitting a conventional tank.
If the tank is below 1.4 tank and you stab it, corner hard or brake hard you have the chance to momentarily expose the pickup - it will kill the engine instantly - WHY? because the EFI works on pressure - the carb it has replaced had a fuel bowl, or two that would act as a resivor that will makeup for these momentary issues. With EFI you dont have that luxury
Re: EFI Fuel tanks/In-tank Fuel pumps [Re: DJVCuda] #1339062
11/26/12 09:31 AM
11/26/12 09:31 AM
Finland
mafo Offline
mafo  Offline
Finland
this is what I did, sure it s not a race car but it works excellent even
for some "inspired" driving
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
