383 budget build?
#1338973
11/21/12 01:34 PM
11/21/12 01:34 PM
Posts: 8,794 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
What is a good budget combo for a street/weekend strip engine. The combo: '69 B-body. 4 speed. 3.55 gear. Leftover headers(I think 1 7/8). Full body, full interior. Some freeway driving. Friday night test and tune and probably MoPar event racing. The objective: Reliable, fun, big block b-body. mid-to-low 12's. No exotic parts, stock rods, maybe splurge on a set of pistons. Parts available here, Racing Junk, FBBO, FastMopar, etc. Hand port heads, or used aluminum someone is not using anymore(yeah, right.) Suggestions? 10:1 compression? Single plane, dual plane, or notched dual plane? Performer RPM? M1 dual plane? Holley Street/Strip dominator? 750 carb or bigger? Hydraulic cam? Solid? Thanks in advance. Just want to get the car on the road and sage to drive, will upgrade later. Side note, I have the option of a 383, or a 400, but I want to stay low deck. No stroker kits(yet), and either one will have a forged crank in it to use common balancer/flywheel, etc.
1969 Dart GTS 340 1969 Coronet R/T X9 N-96 1999 Dodge Dakota R/T RC 2015 Dodge Dart GT 2019 Ram 2500 Big Horn
Re: 383 budget build?
[Re: Mr.Yuck]
#1338975
11/21/12 02:07 PM
11/21/12 02:07 PM
Posts: 2,826 NY usa
540challenger
NY usa
where are you going to find a 400 steel crank? Anyway I think the general conclusion is pistons are going to be your downfall. Low 12's w/ 3.55's is going to be hard w/ a "mild" 383. I guess you could go with the "standard" MP build. Try and get as close to 10:1 as you can, ported heads, 509 cam (or a better modern grind), headers, Torker II intake, and the usuall upgrades. That should get you into the 12's.
Maybe he means a 383 steel crank in a 400
[Re: Mr.Yuck]
#1338976
11/21/12 02:08 PM
11/21/12 02:08 PM
OhioMopar
Mt.Gilead, Ohio
Mid 12's is fine. A 400 is the same stroke, so I can get a 383 steel crank from my engine 'supplier'. To be honest, 12.99 out of a 'mild' budget 383 would make me perfectly happy. I am not opposed to 3.91's or 4.10's. With a decent sized tire, it wouldn't be terrible on the freeway. My Swinger has 3.91's and a kinda short 14" tire and I had no problem living with the revs @ 70 mph if I wasn't driving too far. Thanks for the recipe.
[Re: 540challenger]
#1338977
11/21/12 02:11 PM
11/21/12 02:11 PM
OhioMopar
Mt.Gilead, Ohio
Yeah, what he said!
[Re: OhioMopar]
#1338978
11/21/12 04:51 PM
11/21/12 04:51 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if it were me, I'd probably go KB flat tops, 0 deck'ed, some eddie RPMs, maybe cut .050 or so for compression, and .039" head gaskets. eddie RPM intake, your headers, 650-800 CFM carb of your choice, and a lunati voodoo 60303 cam
[Re: patrick]
#1338979
11/21/12 09:25 PM
11/21/12 09:25 PM
OhioMopar
Mt.Gilead, Ohio
Sounds good, but Eddies won't be in the budget. Unless I pick them up used off someone. My budget will probably include a set of 906/452's with new seats and guides and the purchase of a MP porting template kit and some grinding stones! I know the compression is going to be pretty important. Maybe I can pick up a good set of well done iron heads, or Eddies or Stealth heads that someone has upgraded from.
[Re: OhioMopar]
#1338981
11/21/12 10:24 PM
11/21/12 10:24 PM
Posts: 10,146 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Find a good 400 block. If it will bore to 4.375, great. The extra cubes help. The minimum on heads is to have a competition three angle valve job done and have the bowls blended. A solid cam will allow you the rpm to make decent power where a hydraulic with enough duration to get into some serious power may actually hold you back. I have seen them fall off drastically as low as 5600 rpm. If you are willing to put up with a rather wild cam, elevens are possible even at 3850 race weight. You will just need enough gear to make it all work. With a four speed, the more gear you can put up with the better. A single plane intake, a set of forged pistons with 1/16 rings that are file fit, and 1 7/8 headers along with a cam of roughly 260 duration at .050 on the intake will do the job. If you feel the cam duration of 260 is too much, then go as much as you think you can tolerate. An old Mopar direct connection cam test in a low compression 400 equipped Duster kept getting faster with each increase in cam size all the way up to the .590. They went from the small hydraulic all the way up testing all their cams, and if I recall correctly each step up was worth a .10+
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#1338982
11/21/12 10:43 PM
11/21/12 10:43 PM
OhioMopar
Mt.Gilead, Ohio
I'm pretty open for 'old school' lopey cams. The car won't be running power brakes, no power steering. I can fit a pretty tall tire on the back, so a 3.91/4.10 is not something I can't live with. I also think I could live with a solid cam, never run one before. I ran a .509 in a 383 in my '66 and loved the sound. Also loved the way it ran with good(decent) converter in it. But with a stick I get to choose my own stall speed! Thanks!
[Re: BSB67]
#1338984
11/21/12 11:41 PM
11/21/12 11:41 PM
OhioMopar
Mt.Gilead, Ohio
You'll spend a bunch of money going from a 3.55 to a 3.91 (almost no performance gain), but won't spend the money for a good set of heads (probably worth 30-40 hp).
Really? Define a 'bunch of money'. A Richmond ring and pinion for an 8.75 3.55 is $236. A 3.91 is $229. So I would actually be saving money? is right. A set of Eddie heads is $1500. A set of 4.10's right here on Moparts is $525. Soooo, let's say I can't sell the 3.55's at all. I am out $525. I have to lose $975 on the gear change to make the head purchase EVEN. When you figure out what numbers I need to use to make the heads MORE economical than the cylinder heads, let me know. Maybe it is just that your idea of budget and mine differ. That's fine. I don't have $1500 to put out for cylinder heads. That's the bottom line. I can set up a $250 ring an pinion for myself for free. It doesn't matter if the heads make an extra 200 horespower if they are on the shelf at Jegs. I have access to all the factory big block stuff I could ever want at very reasonable prices. I just want to get the thing on the road and running decent, I will upgrade later.
[Re: Cab_Burge]
#1338986
11/22/12 12:53 AM
11/22/12 12:53 AM
OhioMopar
Mt.Gilead, Ohio
The guy I get most of my engine stuff from had over 400 big blocks at one time. I'm sure I could find a few 400's and a couple steel cranks from a 440. Wondering how cost effective it would be. I would like to stay away from strokers, but not opposed to it.
[Re: Cab_Burge]
#1338988
11/22/12 01:50 AM
11/22/12 01:50 AM
Posts: 168 Washington State, USA
Winchester 73
I would see if you could swing a forged steel BB crank and have the mains down for the 400, a set of BB LY rods and a set of shelf pistons to make a 451 or 452 C.I. low deck Single pane M1 or a Eddy Performer RPM and a 850 carb. your there on pump gas
how much et would a stroker make given the same top end and valvetrain?ive always heard that an engine will make the same hp with less cubic inches as with more but at a higher rpm but on this site before a question gets asked on how to build an engine peaple are ready to tell u what stroker crank to use. for that matter i dont think you are better off strength wise building a stroker at this hp level-the rpm goes down but the piston speed and side loading goes up does anyone have any track testing on this?
any way heres my spin on a 383 budget build and i bet itll be different than anyone elses:
used chevy 427 flat tops -bore yuor block to fit 440 long stock conn rods forged 383 crank used solid cam/lifters (evryone has an extra cam-send to get resurfaced if nessisary) 906 heads!think about it -closed chamber heads are junk for anything but getting a littl bit of compression out of a budget 383 build-if you decide to build a 440 or 451 later on,these same peaple will be telling you to throw those heads away so how are they a budget piece?
[Re: OhioMopar]
#1338989
11/22/12 06:38 AM
11/22/12 06:38 AM
gregsdart
One reasonably cheap option is offset grind a 383 crank to chev 2.20 bearings, run an Eagle hbeam with 2.200 big end and 6.760 length. Ross 99906 flat tops, 4.375 bore and you wind up at 426 cubes with an offset grind stroke of 3.54. The rods and pistons are the only costly part of this build, other than the balancing and crank work. Run a cheap stock .020 steel gasket, and you will be at 9.5 compression with a small head cut to bring them down to about 82 cc. The main thing is if you go too cheap, the results will be poor.The low deck 426 is about as cheap as it gets to build some good torque and hp. The only extra expense over a 383 rebuild is offset grinding the crank rod journals, and the Eagle rods. You mentioned you were willing to go forged pistons anyway. Now subtract the cost of reworking a set of stock rods, and having a 383 crank cleaned up on a grinder, and there isn't much difference in cost at all.
[Re: OhioMopar]
#1338990
11/22/12 09:22 AM
11/22/12 09:22 AM
Posts: 4,333 Prospect, PA
BSB67
Prospect, PA
My bad.
Thought the 3.55 was complete, assembled and in the car. Most cannot set them up themselves. Buying a fresh pig is more than a set of Stealths.
[Re: BSB67]
#1338991
11/22/12 11:43 AM
11/22/12 11:43 AM
OhioMopar
Mt.Gilead, Ohio
My bad.
Agreed. I've done a few pigs, and even though it has been a while, I have done a couple automatics and a couple 4-speed rebuild as well. Got away from it by spending my way into things, but that just isn't an option right now. It's gonna be elbow grease and pocket change for me! Lol.
[Re: OhioMopar]
#1338992
11/22/12 11:45 AM
11/22/12 11:45 AM
OhioMopar
Mt.Gilead, Ohio
I don't want anyone to think that I'm blowing their opinion off. I'm looking at all options. I appreciate everyone's input and would never blow someone off that is trying to help me. It's much appreciated...
[Re: Winchester 73]
#1338993
11/22/12 12:11 PM
11/22/12 12:11 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Yup. that's been my experience as well.
head flow = HP. Cubic Inches = RPM where peak power is reached.
if your heads flow 300 CFM, your motor can make 600 hp.
if you have a 383, it's going to need to spin 7000 RPM to make 600 hp. in a 440 it's going to need 6500 RPM to make 600 hp, but both motors will make 600 hp.
but...the reason most people say "build a stroker" is because you have to remember what you said you're building.
street motor with some occasional TnT sessions and Mopar events. key word: STREET MOTOR
if you need 7000+ rpm to make your Hp goals and run the number you want to run, that's just fine and dandy on a car that only sees 1/4 mile at a time, but if you're driving it on the street all the time, are you going to leave it in 1st or 2nd gear to keep it tach'd up at 4500 rpm "in the sweet spot" for playing around on the street? or do you want more cubic inches to bring the torque/hp peak down lower in the RPM, so that you can be cruising along at 2200 rpm nice and smooth, then give it WOT and instantly go up in tire smoke?
Real life example:
when I got my blue Dakota, it had a 318, 220/230° .507" lift, 114 LSA. M1 intake, stock TB, cheap edelbrock headers and 4.56 gears. it ran 14.6 at 97 mph, and pulled hard up to 6,000 rpm.
I put a 360 into it with the same heads, same intake, same headers/exhaust, but with a 222/228° .544, 107LSA cam. I also went back down to a 3.92 gear to bring my RPM back down some--I got tired of running 3,000 rpm at 65-70mph on the highway.
the truck now runs 14.3 at 98-99 mph, and only pulls to about 5200 rpm.
This tells me that my 360 is making the same Hp as the 318, but that the 360 is making it lower in the RPM range. both motors ran within 1 mph of each other, and to me, that's well within the "noise" of atmospheric changes from one night to the next.
however, the .3 lower ET tells me that the 360 has a lot more torque, especially since I went from 4.56 to a 3.92 and went faster.
Which one is more fun to drive? hands down, the 5.9 is WAY more fun!
Anyway...you're also on a budget, so I would not spend ANY money on a stroker, unless you're reconditioning all factory parts, such as an RB crank turned down, and reconditioned rods.
if you take factory iron heads and do a little bowl work on them, they should easily support 500 hp. Look at Ron's Son's dart. I'd copy that build for a cheap yet strong running stock stroke 383.
**Photobucket sucks**
[Re: OhioMopar]
#1338996
11/25/12 04:53 PM
11/25/12 04:53 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
Thanks Tom. I was kinda eyeing Ron's build. Because it ran a number where I would like to be(although with a heavier car I know it won't go that fast) and it is pretty simple, even without aftermarket pistons. Also because it seems whatever Ron screws together runs like (insert your injured, scared, burned animal reference here).
Never to put down anyone else's build (they are ALL great from different approaches ), but Ron's build is a basic low buck setup , which is very functional for what you MAY want to do and still enjoy street/highway driving the car. His build is a bit different due to car weight (his is 400-600 lbs less than yours). So where his runs a bit stronger from midrange and up, you have concentrate on having a bit more low end and VERY strong midrange due to the car being slightly heavier. Meaning the right choice in parts will net you great power! An EDDY 383 RPM and 750 carb (holley or carter) is a good choice. A good cam choice would be profiles between the 68-71 383 Magnum spec and MP 280 degree .474"/.474" (Street Hemi) cam spec BY ANY choice of cam manufacturer. Remember, when you buy the cam, it is best to buy the WHOLE KIT or complete compatible components for the cam. But, check your valve to piston clearances, ALWAYS!! Pocket port the heads and you will gain some power. Gears? 3.91's - 4.10's should be okay. Careful tire size selection is the key. The torque multiplication in the drivetrain is different between a 4speed and a automatic, so tires play a big part in engine rpm vs car speed vs et/60' times. And by all means get the car to HOOK WELL with the suspension you presently have. If you have a bit MORE thought in performance, an article in 2009's Spring Edition of Engine Masters may help. Titled "383 Power Play" and written by Steve Dulcich, this is a wealth of information on basic 383 modifications. It's another CLASSIC example of carefully selecting parts to make good power. However, I strongly believe you are looking for something that FALLS between Ron's build and Steve's build. Good luck!
[Re: HYPER8oSoNic]
#1338997
11/25/12 05:17 PM
11/25/12 05:17 PM
OhioMopar
Mt.Gilead, Ohio
Never to put down anyone else's build (they are ALL great from different approaches ), but Ron's build is a basic low buck setup , which is very functional for what you MAY want to do and still enjoy street/highway driving the car. His build is a bit different due to car weight (his is 400-600 lbs less than yours). So where his runs a bit stronger from midrange and up, you have concentrate on having a bit more low end and VERY strong midrange due to the car being slightly heavier. Meaning the right choice in parts will net you great power! An EDDY 383 RPM and 750 carb (holley or carter) is a good choice. A good cam choice would be profiles between the 68-71 383 Magnum spec and MP 280 degree .474"/.474" (Street Hemi) cam spec BY ANY choice of cam manufacturer. Remember, when you buy the cam, it is best to buy the WHOLE KIT or complete compatible components for the cam. But, check your valve to piston clearances, ALWAYS!! Pocket port the heads and you will gain some power. Gears? 3.91's - 4.10's should be okay. Careful tire size selection is the key. The torque multiplication in the drivetrain is different between a 4speed and a automatic, so tires play a big part in engine rpm vs car speed vs et/60' times. And by all means get the car to HOOK WELL with the suspesension you presently have. If you have a bit MORE thought in performance, an article in 2009's Spring Edition of Engine Masters may help. Titled "383 Power Play" and written by Steve Dulcich, this is a wealth of information on basic 383 modifications. It's another CLASSIC example of carefully selecting parts to make good power. However, I strongly believe you are looking for something that FALLS between Ron's build and Steve's build. Good luck!
Well said, and I agree. I did a search the other day and found an old stroker thread and found an article by him (I think) about rebuilding a stock 383 and then how they upgraded and the horsepower results. Good article. I still have some time to decide. Looks like I can find ported 906's, even on here, for next to nothing. So I will shop wisely and see what I can find.
[Re: HYPER8oSoNic]
#1338999
11/25/12 05:57 PM
11/25/12 05:57 PM
OhioMopar
Mt.Gilead, Ohio
If you want to know some basic milling tips and issues with 906 heads, go to the thread titled "Milling 906 Heads". Some interesting thoughts on that topic.
I'll read everything I can find. Thanks for the guidance. I've been looking around and doing searches on old threads. 383 builds. 400 builds. Strokers. Now I think I will start looking around at components. Cams, heads, intakes, etc. Anything I can find to get a good idea of what direction to head.
