Re: Hedman B/RB shorty headers, 383 Challenger...
[Re: Pale_Roader]
#1338890
11/25/12 10:17 AM
11/25/12 10:17 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Have them in my 72B which is the same motor bay as your E. I have a 440 so yours will sit in and down abit. Mine hit the P/S box just a little but should not hit your manual box. They don't capture the starter a like long tubes do.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#1338891
11/25/12 10:18 AM
11/25/12 10:18 AM
moparmarks
[Re: bordin34]
#1338894
11/25/12 10:42 PM
11/25/12 10:42 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
How did you guys get the dipstick tube to fit? Mine wants to go right where the header tubes are.
Hmmm. Mine fit without any modification. You can see it in my pics. you may be able to bend it as mentioned or get a different style...just make sure you keep the same length tube or the dipstick won't read correctly...
[Re: Pale_Roader]
#1338897
11/26/12 12:10 AM
11/26/12 12:10 AM
Posts: 842 Urbana, MD
bordin34
Urbana, MD
They bend.
Im afraid of bending it too far and cracking it. I guess I'll keep going.
[Re: Nukechargerboy]
#1338898
11/26/12 08:44 AM
11/26/12 08:44 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
I'd hafta check, but I sorta remeber changing the last 2 numbers to '38' gets the ceramic coating from the factory. I have them at my fathers house, I could check tomorrow if you want me to. 78038 gets the shiny ceramic coating, if memory serves me correctly.
I have the very trendy 'rat rod rusty' versions. As long as they flow as well...
[Re: Pale_Roader]
#1338899
02/20/13 11:25 PM
02/20/13 11:25 PM
Posts: 457 Hightstown, NJ
njdevil2
Hightstown, NJ
The shorties I found were Hedman 78070, from streetsideauto.com for $200.99. I got a discount code for 10% off and it's $190.99 delivered. With all the part numbers bandied about, I want to be sure it's 78070 before I go all in. It says manual steering, but I see them fitting being dimpled and all that. If these are the ones, then the next call is to Eastwood for semi gloss black coating.
1970 road runner Convertible 1 of 179
