Installing a slapstick shifter... #133868
10/08/08 02:12 PM
10/08/08 02:12 PM
SmokinTire Offline OP
Howdy all, getting ready to convert my column shifter in my challenger to a slapstick.... I cut the brackets and shifter off an old junk cuda a few years ago and have been waiting on the time to do the swap... well its time lol.... Anyone have any good ideas or tips on doing this? I installed a Hurst floor shifter in to the car last year, but have not been to happy with it.
Thanks !!!!!!!!
Re: Installing a slapstick shifter... [Re: SmokinTire] #133869
10/08/08 03:16 PM
10/08/08 03:16 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I did the same for my '73 Roadrunner, and it was well worth it! My best advice is measure a LOT, and make sure that when the shifter is mounted to the back bracket, that the linkage rod fits in the front bracket before you tack weld everything. Just basically put the brackets as close to where they came off of the other one. Good luck!
Re: Installing a slapstick shifter... [Re: 4BBodies] #133870
10/08/08 03:58 PM
10/08/08 03:58 PM
Thanks for the reply.... that photo was what I was looking for
Re: Installing a slapstick shifter... [Re: SmokinTire] #133871
10/26/08 11:59 AM
10/26/08 11:59 AM
Does anyone else have any photos of where to weld the mounts? I have lost the notes i made when i cut this shifter out. Thanks for any help
Re: Installing a slapstick shifter... [Re: SmokinTire] #133872
10/26/08 03:02 PM
10/26/08 03:02 PM
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
Well, I would go out and measure for you, but that would be pointless on a B body.......I hope someone else can help you.
Re: Installing a slapstick shifter... [Re: 4BBodies] #133873
10/27/08 03:02 AM
10/27/08 03:02 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Everything should already be dimpled on your tunnel for the brackets. When I converted my sig car from column to floor shift I just cut the whole trans tunnel out of my donor car and screwed it down on top of my stock tunnel. Believe me it works great. Don't laugh it's been like this for 5 years. Next summer it's comming out in favor of a 4sp setup but I have had no problems with this combo as-is.
Re: Installing a slapstick shifter... [Re: DaytonaTurbo] #133874
10/27/08 08:25 AM
10/27/08 08:25 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I put one in a 69 Dart years ago. I started at the transmission and worked my way back. The flat area where the down rod goes through was already there, even the screw holes were dimpled. After installing the linkage on the transmission and the down rod I put the transmission in park. Then installed the linkage from the shifter to the down rod and put the shifter in park to locate it, spot welded it down to check the console fit and shifter operation. It looked cool in a A body and worked great. I wish I had one to put in the Dart I have now.
