Re: 71 -72 B body window louvers [Re: 71birdJ68] #1337415
11/21/12 11:47 AM
11/21/12 11:47 AM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Louvers were a 71 only thing, 70s had a whole different body line. And from what I've been told only black and white cars got black louvers. I've seen a orange car with orange louvers, so the black trim would stick out like a sore thumb. It would be nice to know when the holes were added to the roof and 1/4 panel, were they drilled after the fact or stamped during the panel mfg. process.We found evidence that my car was taken off the line and had some more paint work done, but don't know what or why.
To clarify, '70-'71 E-bodies, '71 B-bodies
As far as I'm concerned Chrysler was fairly sloppy with how they handled louver-equipped cars, particularly E-bodies.
Theoretically, E-bodies should have Rivnuts in the roof where the louver hinges would mount (much like the ones used for outside mirrors).
However, I had an original J68 '71 Challenger coded for and equipped with louvers (and backed up by the original fender tag & build sheet), yet there were no Rivnuts in the roof - just some small, crudely punched holes to hold a sheetmetal screw.
Oddly enough, another Moparts member across the country wound up with the car built immediately after mine (1 VIN number off), identically equipped and with the same deficiency with respect to the mounting of the louvers.
Ditto for Challenger rubber bumpers - they generally don't show up on the tag, just the build sheet.
So it's not implausible that the same kind of sloppiness carried over to the B-body lines. Did the EL5 car come with louvers from the factory? Maybe - but we'll never know for sure...
Re: 71 -72 B body window louvers [Re: YYZ] #1337416
11/21/12 02:50 PM
11/21/12 02:50 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Yes and some could be differences from plant to plant. Now the B bodies don't have hinges like E bodies, and my car had rivnuts in it. What does EL5 stand for? Some of the guys over on road road runnernest might know about this.
Re: 71 -72 B body window louvers [Re: scatpacktom] #1337417
11/21/12 02:59 PM
11/21/12 02:59 PM
Canada
demon Offline
demon  Offline
Canada
Window Louvers come with the textured trim.
My 71 Charger R/T came with louvers from the factory. It has the stainless window mouldings. I personally have never seen the textured black mouldings on a factory louver car before.
Re: 71 -72 B body window louvers [Re: demon] #1337418
11/21/12 03:25 PM
11/21/12 03:25 PM
YYZ Offline
YYZ  Offline
EL5 is the code for Butterscotch/Bahama Yellow which is one of the cars being discussed in this thread
Only Plymouth seemed to bother with the textured trim for louvers - not Dodge. (Challengers don't get special trim with louvers, only 'Cudas)
Re: 71 -72 B body window louvers [Re: YYZ] #1337419
11/21/12 03:36 PM
11/21/12 03:36 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
If you haven't done so already, track down Jimmy Boros in MN as he's held the title of key '71-up B-body specialist since Ray Kerkhoven passed away several years ago.
Jimmy is a good guy to deal with and if he doesn't have any louvers may be able to give you some leads.
Ray, before he passed away, had made moulds for both Charger & RR louvers that were quite respectable. If you can find a set of those they would be a great substitute.
Originals have a latch mechanism which is not easy to duplicate, and very few '71-up B-bodies came equipped with louvers (as compared to E-bodies)
Good luck!
My buddy had a set for sale at Carlisle this past July that he removed from a '71 318 Charger and the only person that was even remotely interested in them was Jimmy. He paid some good money for them.
Re: 71 -72 B body window louvers [Re: 70440+6bbl] #1337420
11/22/12 06:34 AM
11/22/12 06:34 AM
P
PasiR Offline
PasiR  Offline
P
I have scene a B5 GTX with body color louvers and painted bumpers and the car looked absolutely bada$$!
Like this one
Re: 71 -72 B body window louvers [Re: PasiR] #1337421
11/22/12 11:13 AM
11/22/12 11:13 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I wonder if that is a factory louver car, the trim is polished and not black. I have seen that car before. They really look good body color, but then again so does black like the car above. I kinda don't like the wing, makes it too cluttered looking, kinda what do I look at first the wing or the louvers. There was an orange car in Year Ones catalogue once with body color louvers. I remember when I saw my car in 1974, I was 19, the car was Black, with louvers and air grabber, very sinister looking, I just had to have it. Paid $1400 or $1500 for it can't remember.
Re: 71 -72 B body window louvers [Re: 71birdJ68] #1337422
11/22/12 11:28 AM
11/22/12 11:28 AM
Waterford, MI
PRPLHAZ Offline
PRPLHAZ  Offline
Waterford, MI
The EL5 car was purchased out of Canada by a friend. It is original paint & didn't have spoilers or the rear window louvers at that time, he added them. I was with him when he picked up the car & when he drilled the holes. The louvers are reproduction by a guy out of NV that found them to be to labor intensive to continue.
My 71 RR came with both spoilers & rear window louvers. Polished trim on the back window.
Re: 71 -72 B body window louvers [Re: PRPLHAZ] #1337423
11/22/12 11:31 AM
11/22/12 11:31 AM
Waterford, MI
PRPLHAZ Offline
PRPLHAZ  Offline
Waterford, MI
another pick from during the resto
Re: 71 -72 B body window louvers [Re: PRPLHAZ] #1337424
11/22/12 09:50 PM
11/22/12 09:50 PM
YYZ Offline
YYZ  Offline
PRPLHZ - are you saying that the EL5 car has had 2 tours of duty in Canada? If so, I'm curious what the approximate dates were?
btw - your GY3 car looks awesome!
Re: 71 -72 B body window louvers [Re: PasiR] #1337425
11/24/12 02:42 AM
11/24/12 02:42 AM
IL
71383beep Offline
71383beep  Offline
IL
Like this one
Yep...like I said BADA$$!
'73 GK6 Challenger Rallye - 340 4-Speed
Re: 71 -72 B body window louvers [Re: PRPLHAZ] #1337426
11/24/12 02:49 AM
11/24/12 02:49 AM
IL
71383beep Offline
71383beep  Offline
IL
WOW! PRPLHAZ you have a PM!
Well one question answer with much more questions to follow.
It just proves that it truly is a small world when it comes to mopars.
Re: 71 -72 B body window louvers [Re: 71383beep] #1337427
11/24/12 01:17 PM
11/24/12 01:17 PM
Waterford, MI
PRPLHAZ Offline
PRPLHAZ  Offline
Waterford, MI
Yes, the car came out of Canada about 10 years ago, was in Michigan for a few years, then back to Canada (Ian) for a few years, then Dante bought it & owned it for several years, then to the guy that ebayed it this past summer.
