Page 3 of 4 1 2 3 4
Re: Montessa Photo [Re: montessa] #1337101
11/20/12 08:35 PM
11/20/12 08:35 PM
The 30's and 40's were from last year when I was running basically the same setup except at 528 cubes and a little under 12 to 1 compression. For this past season I changed out the crank, rods and pistons and stepped up 14 to 1 compression. The best the old combo ran was 9.26 at 145, new best 9.08 at 147 for the additional 44 cubes and 2 points of compression.
Why didnt you go with the 572-13 cnc 385 heads?
I bet you would be well into the 1000 plus horsepower range with your combo. You seem to really have a handle with making it all work.congratz.
Re: Montessa Photo [Re: actionange] #1337102
11/21/12 08:21 AM
11/21/12 08:21 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Perhaps the scale at that track measures using kilograms?
3700kg = 8140lbs I'm sure Jim meant 3700lbs
I've seen the car and it's all there, full interior, cage etc... But it does have a nice lightweight aluminum block.
The car is wicked fast ; Jim and I ran against each other and it was all over at the 60' mark....all I saw was tail lights all the way down the track.
Ron
Re: Montessa Photo [Re: firefighter3931] #1337103
11/21/12 08:24 AM
11/21/12 08:24 AM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Ron
That would make it even MORE impressive!!!
Re: Montessa Photo [Re: actionange] #1337104
11/21/12 11:16 AM
11/21/12 11:16 AM
JCFcuda Offline
JCFcuda  Offline
I scaled the car with a friends roundy rounds electronic scales.
Thats what it is 3700 lbs w/driver.
Jim F
Re: Montessa Photo [Re: JCFcuda] #1337105
11/21/12 01:38 PM
11/21/12 01:38 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Jim F
So what was the weight bias front to rear and left to right? Just curious as a black 68 Charger has ALWAYS been my dream car.
Old Geezer Racing
Re: Montessa Photo [Re: SCATPACK 1] #1337106
11/21/12 05:46 PM
11/21/12 05:46 PM
What you shifting that bad boy at?
Re: Montessa Photo #1337107
11/21/12 08:37 PM
11/21/12 08:37 PM
North Eastern New York State
montessa Offline OP
montessa  Offline OP
The balance is 51% on the front and 49% on the rear wheels. I didn't op for the 572 heads because we felt that with the weight of the car the 440-1's would pull better on the bottom end. Also, with the exception of custom made, there aren't any readily available headers. I am running TTI 2"x 2 1/8" step headers. I shift at 6600 and run out the back about 7200 RPM's.
Re: Montessa Photo [Re: montessa] #1337108
11/21/12 09:13 PM
11/21/12 09:13 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
MOTOR PIC PLEASE !!!!!!!
1.39 9.85 - 137 mph
Re: Montessa Photo [Re: Ari440] #1337109
11/22/12 12:55 AM
11/22/12 12:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Awesome shot ! Ron
Re: Montessa Photo [Re: 383man] #1337110
11/22/12 01:52 AM
11/22/12 01:52 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
awesome combo! beautiful car! bad a$$ picture
Re: Montessa Photo [Re: montessa] #1337111
11/22/12 02:05 PM
11/22/12 02:05 PM
montessa Offline OP
montessa  Offline OP
Here's a pic of the engine
Re: Montessa Photo [Re: montessa] #1337112
11/22/12 02:48 PM
11/22/12 02:48 PM
Now you got me thinking Montessa!!
Re: Montessa Photo [Re: tboomer] #1337113
11/22/12 04:49 PM
11/22/12 04:49 PM
iowa
rook440 Offline
rook440  Offline
iowa
oh yea ....great leave .....leaves just like mine does ,must be a charger thing .....
Re: Montessa Photo *DELETED* [Re: montessa] #1337114
11/22/12 06:18 PM
11/22/12 06:18 PM
montessa Offline OP
montessa  Offline OP
Post deleted by montessa
Re: Montessa Photo [Re: montessa] #1337115
11/22/12 06:54 PM
11/22/12 06:54 PM
Hey bud, Do you got a picture of the enderle linkage side of the engine?
I want to see how you set it up with on the tunnelram.
Re: Montessa Photo [Re: montessa] #1337116
11/25/12 12:06 AM
11/25/12 12:06 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice! Nice...car, performance, owner, engine builder.
Re: Montessa Photo #1337117
11/25/12 06:00 PM
11/25/12 06:00 PM
montessa Offline OP
montessa  Offline OP
per your request!
Re: Montessa Photo [Re: montessa] #1337118
11/25/12 06:26 PM
11/25/12 06:26 PM
per your request!
getting a red x montessa. maybe try photobucket or tinypic.com
Re: Montessa Photo #1337119
11/25/12 07:13 PM
11/25/12 07:13 PM
montessa Offline OP
montessa  Offline OP
Gandhi, I am not very savy with loading photos. My daughter has loaded everything so far. I thought that I figured it out but, NOOOO! Sorry. I'll keep trying. Say, did you have any luck borrowing a tunnel ram? Have you dynoed the motor yet and what are you building? When Dwayne dynoed my motor he tried a 1050 with an Indy single plane manifold. I was not there, and I know the manifold was not the best Indy single plane. I think the tunnel ram was worth 30-40 HP and torque was about the same. If you what the hard numbers you can give Dwayne Porter, Porter Racing heads a call at 802-951=1955. He is also an Indy dealer!
Re: Montessa Photo [Re: montessa] #1337120
11/25/12 08:21 PM
11/25/12 08:21 PM
Yes it made power but I know I'm leaving alot on the table. I want to try a tunnelram on the motor and hoping to see gains comparable to yours hopefully. I will be going over to jim kids dyno here in Michigan soon once I get my tunnelram manifold and Iam going to try 2 different cams.Good luck next year with your beautiful car and fantastic combo.Moe
Page 3 of 4 1 2 3 4
