Re: Montessa Photo
[Re: montessa]
#1337101
11/20/12 08:35 PM
11/20/12 08:35 PM
The 30's and 40's were from last year when I was running basically the same setup except at 528 cubes and a little under 12 to 1 compression. For this past season I changed out the crank, rods and pistons and stepped up 14 to 1 compression. The best the old combo ran was 9.26 at 145, new best 9.08 at 147 for the additional 44 cubes and 2 points of compression.
Why didnt you go with the 572-13 cnc 385 heads? I bet you would be well into the 1000 plus horsepower range with your combo. You seem to really have a handle with making it all work.congratz.
Re: Montessa Photo
[Re: actionange]
#1337102
11/21/12 08:21 AM
11/21/12 08:21 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Perhaps the scale at that track measures using kilograms?
3700kg = 8140lbs I'm sure Jim meant 3700lbs
I've seen the car and it's all there, full interior, cage etc... But it does have a nice lightweight aluminum block.
The car is wicked fast ; Jim and I ran against each other and it was all over at the 60' mark....all I saw was tail lights all the way down the track.
Ron
Re: Montessa Photo
[Re: firefighter3931]
#1337103
11/21/12 08:24 AM
11/21/12 08:24 AM
Posts: 1,634 anywhere@ anytime
actionange
anywhere@ anytime
Ron
That would make it even MORE impressive!!!
Re: Montessa Photo
[Re: SCATPACK 1]
#1337106
11/21/12 05:46 PM
11/21/12 05:46 PM
What you shifting that bad boy at?
Re: Montessa Photo
[Re: 383man]
#1337110
11/22/12 01:52 AM
11/22/12 01:52 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
awesome combo! beautiful car! bad a$$ picture
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Montessa Photo
[Re: montessa]
#1337112
11/22/12 02:48 PM
11/22/12 02:48 PM
Now you got me thinking Montessa!!
Re: Montessa Photo
[Re: montessa]
#1337115
11/22/12 06:54 PM
11/22/12 06:54 PM
Hey bud, Do you got a picture of the enderle linkage side of the engine? I want to see how you set it up with on the tunnelram.
Re: Montessa Photo
[Re: montessa]
#1337118
11/25/12 06:26 PM
11/25/12 06:26 PM
per your request!
getting a red x montessa. maybe try photobucket or tinypic.com
Re: Montessa Photo
[Re: montessa]
#1337120
11/25/12 08:21 PM
11/25/12 08:21 PM
Gandhi, I am not very savy with loading photos. My daughter has loaded everything so far. I thought that I figured it out but, NOOOO! Sorry. I'll keep trying. Say, did you have any luck borrowing a tunnel ram? Have you dynoed the motor yet and what are you building? When Dwayne dynoed my motor he tried a 1050 with an Indy single plane manifold. I was not there, and I know the manifold was not the best Indy single plane. I think the tunnel ram was worth 30-40 HP and torque was about the same. If you what the hard numbers you can give Dwayne Porter, Porter Racing heads a call at 802-951=1955. He is also an Indy dealer!
Yes it made power but I know I'm leaving alot on the table. I want to try a tunnelram on the motor and hoping to see gains comparable to yours hopefully. I will be going over to jim kids dyno here in Michigan soon once I get my tunnelram manifold and Iam going to try 2 different cams.Good luck next year with your beautiful car and fantastic combo.Moe
