If you were to build a bb stroker engine????????????? #1336753
11/17/12 09:46 PM
11/17/12 09:46 PM
TN
65racer Offline OP
2009 IHRA World Champion
65racer  Offline OP
TN
Just like the heading says, what would you build,
if you had blocks for all the combinations, I mean
383 blocks, 400, and 440's.
I am rolling around the idea of building 1, but
right now I am indecisive on which way to go,
will have to buy a rotating assembly for what
ever engine I decide to go with, and if it is
the 440 route will have to have an intake and pushrods,
for the rb engine, I have all the necessary stuff
for a low block application, so all I would
need for that is the assembly.
And who's kit would you go with ? I know this will
open a can of worms about whose is the better stuff,
but let's hear what every one has to say on this
subject.
The deal is not set in stone as of right now, just
looking at other options.
I have always ran a 383 engine in my stuff, but
the last 1 I have is at the shop being cleaned,
an checked, and I really don't think it is going
to be up to snuff. So I am looking at alternative
ways for next season.
Re: If you were to build a bb stroker engine????????????? [Re: 65racer] #1336754
11/17/12 09:52 PM
11/17/12 09:52 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Take the 440 and build a 543 with B1s.
Mopar to the bone!!!
Re: If you were to build a bb stroker engine????????????? [Re: 65racer] #1336755
11/17/12 09:53 PM
11/17/12 09:53 PM
AndyF Offline
AndyF  Offline
Re: If you were to build a bb stroker engine????????????? [Re: 65racer] #1336756
11/18/12 12:59 AM
11/18/12 12:59 AM
Look around for a early(June of 1971 to October of 1971 casting date) 400 block, hopefully one of the thick main web "cold weather" blocks, bore it the minumum needed to make the cylinder walls straight and buy a decent 4.25 stroke forged steel crank or kit, your choice As far as the main caps I liked and used the ductile iron main caps Mopar use to offer, buy them if you can find them If not a set of alumimum will probally work well also Lots of choices out there, many ways to skin the kitty
Re: If you were to build a bb stroker engine????????????? [Re: AndyF] #1336757
11/18/12 12:59 AM
11/18/12 12:59 AM
USA
hudsonhornet7x Offline
USA
Buy Andy's book that is listed above. I have read mine so much I am in need of a new one! That book is trulythe first engine book I have read that makes sense to me. In my opinion it is the first thing you should buy for an engine build.
Re: If you were to build a bb stroker engine????????????? [Re: hudsonhornet7x] #1336758
11/18/12 02:18 AM
11/18/12 02:18 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Will it be a racing eng only ? Or wil be it a street car driver ? And is money a limit or no option ? Ron
Re: If you were to build a bb stroker engine????????????? [Re: 383man] #1336759
11/18/12 12:25 PM
11/18/12 12:25 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
FWIW my next build is going to be a 500 wedge, 440 block, same heads (ported Stage VI) Custom solid roller, 950HP, and 12lbs of boost. No need for 13:1, big 700+ lift cam, fancy expensive heads, 5000 stall, 4:30 gears...none of it. But I guess it depends on what it's for, what class and how much street driving you do. I drive to and from the track, so I need a car that has good driving manners...
Coming soon!!!!
Re: If you were to build a bb stroker engine????????????? [Re: 65racer] #1336760
11/18/12 12:44 PM
11/18/12 12:44 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
If it were me and I've thought about this for a while,I would go with a 400 block and increase stroke to go 470".It's a great all around engine,the oil rings are not in the pin area,you can find a rod easily that is .990x2.200,and all of your 383 stuff will still work. I think I would piece this engine together using a 440 source crank Diamond pistons and good quality rods (K-1 or better).Engine would be a screamer and last a long time.It's what I'm going to do for a new build.
Nautilus Racing-
Re: If you were to build a bb stroker engine????????????? [Re: Chris2581] #1336761
11/18/12 02:03 PM
11/18/12 02:03 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well I just went and bought the book ! $19.00
Re: If you were to build a bb stroker engine????????????? [Re: 65racer] #1336762
11/18/12 02:23 PM
11/18/12 02:23 PM
gregsdart Offline
gregsdart  Offline
You can't beat cubic inches. 4.25 stroke, 4.375 bore for 512 cubes. What you plan to do in the future will dictate the piston choice next. By setting the motor up for a 2.25 valve and a big roller, you can upgrade simply by bolting on better flowing heads and or cam in the future. With this setup you can go all the way to 825 hp + with the right heads.
A small dome will allow decent compression. I don't like large dome pistons because of the added weight and at some point they start to restrict flame travel. Just like a house, build the foundation right the first time. You can add the higher hp parts at a later date if that fits your situation.
Re: If you were to build a bb stroker engine????????????? [Re: gregsdart] #1336763
11/18/12 02:56 PM
11/18/12 02:56 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I like the 4.25 stroke 4.375 bore myself. I ended up sticking a set of good B1 originals on top. What a good working combo.
Re: If you were to build a bb stroker engine????????????? [Re: Mopar-Al] #1336764
11/18/12 04:06 PM
11/18/12 04:06 PM
TN
65racer Offline OP
65racer  Offline OP
TN
This is not a street driver, this is for my
race car, I am just looking into another avenue
in case the block I have at the shop is not going to
cut it.
I am not looking to rotate the world or anything
like that, just want something that will be consistent,
and require very little maintenance, as in trouble
free, something to race every weekend, not something
I am going to have to live with in the shop all the time.
I have the book, and have read it through several times,
but am still undecided, but I am leaning toward the 470"
combo, I have gone as quick as 6.80's with the 383 engine
in the car, with a flat tappet cam, steel heads, nothing
really special, but this was with machine work by a guy
who really knew what he was doing, but he passed away a couple
of years ago, and since then I have had to go else where
for machine work, and not everyone knows the real tricks
of engine machining, I learnt a long time ago that there
is a big difference between someone who knows what needs to be done to
make an engine fast, and someone who knows just how to do
machine work, the same combination is in the car as when he was
doing my machine work, but it's not the same work, the car has been
consistently slow, by about 2 tenths, and I can't get it to run
any faster, so I am leaning toward building something with
a little more horsepower, so maybe it will pick it back up
et wise, that's what I am really after,
So thanks for the replies, gonna have to decide what I am gonna do
pretty soon, but that depends on what my wallet will stand, I race on a budget, always have and always will, for 40+ years, and the car has to pay for itself, I guess I am lucky in that respect, as I have
always been able to keep my ego in check, and not let it get the best of me, and have always and I mean always have been able to show a little profit at seasons end, since I have been racing, not braging
about it or nothing like that, I just watch my bottom line real close.
Re: If you were to build a bb stroker engine????????????? [Re: 65racer] #1336765
11/18/12 04:14 PM
11/18/12 04:14 PM
Renton Washington
Triple Threat Offline
Renton Washington
I think either a 383 with a 440 crank (438") or a 400 with 440 crank (451") would be a great combo for you. A little more cubic inch, light bob weight. Not a ton of torque so you wont be fighting spin on marginal tracks, but more than what you have now. 3.31 > 3.75
That would make a good bracket combo IMO. If you went larger like 511" it would take less rpm, but would be a total grunt engine with stock heads.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: If you were to build a bb stroker engine????????????? [Re: 65racer] #1336766
11/19/12 10:50 AM
11/19/12 10:50 AM
gregsdart Offline
gregsdart  Offline
65R, your comment on making the motor pay for itself tells me consistency is number one here. The following combo has been in my head for a number of years. I have two friends that race BB mopars and its the race that is important to them, not the speed. I felt a large bore short stroke motor could be built cheaply and the short stroke would keep traction manageable for consistency.
400 block, 383 steel crank offset ground to 2.200 rod bearings and a 6.76 rod , piston would have a 1.421 (Ross # 99906 flat top) compression height and the whole deal would be fairly light. put it together with cheap shim .020 head gaskets with a block deck height of 9.970 for a .040 quench. What you get is a 426 That should rev very well, be reasonable on cost and not hard to control on the starting line. Compression will be mid 10/1 depending on your head CC, so you won't have to spend a lot of money on expensive race gas. You could probably get by with a mix of 50/50 race/ pump.
Re: If you were to build a bb stroker engine????????????? [Re: Chris2581] #1336767
11/19/12 01:00 PM
11/19/12 01:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been beatng the hell out of my 400-470 combo for over 13 years w/a stock 413 off-set ground (3.900 stroke)crank, chevy 6.385 rods and it`s a beast and LOVES to rev and this is my street car that I race a few times a year these days..............Drove it several miles to College to show the younger generation what a real car looks and runs like and they loved it and of course I love driving it WAY more than racing.........good luck!
Re: If you were to build a bb stroker engine????????????? [Re: Thumperdart] #1336768
11/19/12 01:30 PM
11/19/12 01:30 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Low deck is the only way to go. IMO 470 or 499.
One day I will have something cool here.
Re: If you were to build a bb stroker engine????????????? [Re: sdaurity] #1336769
11/19/12 01:59 PM
11/19/12 01:59 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
build a 451 or a 470 2¢
Re: If you were to build a bb stroker engine????????????? [Re: jamesc] #1336770
11/19/12 03:05 PM
11/19/12 03:05 PM
fresno ca
mikeysmopars Offline
fresno ca
I like my 470 low deck. I have beat on it for the last 4 years and runs bottom tens 3200 lb car
Founder and CEO of the Central Valley Mopar Drag Pack
Re: If you were to build a bb stroker engine????????????? [Re: mikeysmopars] #1336771
11/19/12 06:55 PM
11/19/12 06:55 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Fresh MP crank, offset ground to 3.900 stroke, 2.200 rod journals ready to make 449 CID out of 383 and lots of torque and revability. Fully indexed too...
Re: If you were to build a bb stroker engine????????????? [Re: YYZ] #1336772
11/19/12 07:03 PM
11/19/12 07:03 PM
Weddington, N.C.
Streetwize Online content
Streetwize  Online Content
Weddington, N.C.
For a racer I'd keep the stroke shorter and rod longer so a 470 would work very well. I thought about destroking a 2.375 journal 4.15" to 2.200 4.00" and doing a 6.70-6.90 ish" rod low deck, kind of the opposite of the the 4.30" I did last time.
Side loading and ring seal for a round after round type motor are worth sacrificing some cubes....if it's going to be a stock block thin wall race motor you can make up the cubes with just a couple hun more RPM. In other words if you're going to raise the torque peak RPM beyond the 5000rpm range, (which you are) make it as easy on the block as you reasonably can.
WIZE
In Car:
