Re: The dreaded "pick a cam for me" thread. well, which one
[Re: VITC_GTX]
#1336293
12/09/12 02:49 AM
12/09/12 02:49 AM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
Did you get a cam card with it? If they gave you seat-to-seat events for it, like intake opening, closing, etc., am curious to know what they are.
That cam looks similar to factory RR cam, except on 112 LSA instead of 115.
68 Roadrunner. 383 4-spd. Beat up.
[Re: VITC_GTX]
#1336294
12/09/12 05:12 AM
12/09/12 05:12 AM
Posts: 75,126 A Banana Republic near you.
JohnRR
I ended up buying the smaller Summit cam (6400, not the 6401). Here are the specs, anyone see a problem in using this cam?
You have , use it .
[Re: JohnRR]
#1336295
12/09/12 10:38 PM
12/09/12 10:38 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
You'll do fine with that cam.
[Re: Mebsuta]
#1336296
12/10/12 03:40 AM
12/10/12 03:40 AM
Posts: 4,931 Tri-Cities, Washington
VITC_GTX
Here is a link to the cam card.
http://static.summitracing.com/global/images/instructions/sum-6400%20cam%20card.pdf
[Re: VITC_GTX]
#1336297
12/10/12 10:07 AM
12/10/12 10:07 AM
It will run great and still melt tires--it will just sound like a stock 318 ---It will have enough vacuum to pull the booster off the firewall ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: VITC_GTX]
#1336298
12/10/12 10:14 AM
12/10/12 10:14 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
it'll work, might be leaving a little on the table as far as power and/or drivability due to the relatively lazy ramps and longish duration...
[Re: patrick]
#1336299
12/10/12 01:19 PM
12/10/12 01:19 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
Crower 271HDP. 222/234@.050 .496/486 lift in 112's in at 107. run the 3.23's and you'll be fine with just a standard 383 converter. If you had more compression or 915 closed chamber heads get it cut on 108 centers.
Crabman (David K's) cam also is a great cam for the $$$, it's the old General Kinetics grind that PAW also sells as their House grind, it's very close to the Crower in duration but has a little less lift. The Crower 271 is one of those Natural cams that just does everything great.
383's love to rev but the trick is to not kill the bottom end, it has to be cammed more like you would a smallblock.
This is an AWESOME cam, maybe the best all-around BBM hydraulic cam ever made. It's also a great stock replacement cam for a 440 six pack or magnum.
[Re: Streetwize]
#1336300
12/10/12 02:08 PM
12/10/12 02:08 PM
JohnRR
Bobby , which cam the Crower you list above or the little summit cam ?
[Re: Skeptic]
#1336303
12/10/12 05:45 PM
12/10/12 05:45 PM
$58!!! On sale now--my pick wins!! ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: ]
#1336305
12/11/12 12:28 AM
12/11/12 12:28 AM
VITC_GTX
Ding, ding, ding, we have a winner!!! ![](/ubbthreads/images/graemlins/laugh2.gif)
Re: The dreaded "pick a cam for me" thread. **Update**
[Re: JeffL]
#1336307
12/29/12 08:39 PM
12/29/12 08:39 PM
VITC_GTX
Which brand pistons did you use?
I used an older, new, set of TRW 2257P that I bought from another member.
[Re: VITC_GTX]
#1336308
04/13/13 01:06 AM
04/13/13 01:06 AM
Mebsuta
Khemi, Stygia
How did this turn out? Have you run that cam? I'm curious.
