Re: The dreaded "pick a cam for me" thread. well, which one [Re: VITC_GTX] #1336293
12/09/12 02:49 AM
12/09/12 02:49 AM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
Did you get a cam card with it? If they gave you seat-to-seat events for it, like intake opening, closing, etc., am curious to know what they are.
That cam looks similar to factory RR cam, except on 112 LSA instead of 115.
68 Roadrunner. 383 4-spd. Beat up.
Re: The dreaded "pick a cam for me" thread. well, which one [Re: VITC_GTX] #1336294
12/09/12 05:12 AM
12/09/12 05:12 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I ended up buying the smaller Summit cam (6400, not the 6401). Here are the specs, anyone see a problem in using this cam?
You have , use it .
Re: The dreaded "pick a cam for me" thread. well, which one [Re: JohnRR] #1336295
12/09/12 10:38 PM
12/09/12 10:38 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
You'll do fine with that cam.
Re: The dreaded "pick a cam for me" thread. well, which one [Re: Mebsuta] #1336296
12/10/12 03:40 AM
12/10/12 03:40 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Here is a link to the cam card.
http://static.summitracing.com/global/images/instructions/sum-6400%20cam%20card.pdf
Re: The dreaded "pick a cam for me" thread. well, which one [Re: VITC_GTX] #1336297
12/10/12 10:07 AM
12/10/12 10:07 AM
It will run great and still melt tires--it will just sound like a stock 318 ---It will have enough vacuum to pull the booster off the firewall
Re: The dreaded "pick a cam for me" thread. well, which one [Re: VITC_GTX] #1336298
12/10/12 10:14 AM
12/10/12 10:14 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
it'll work, might be leaving a little on the table as far as power and/or drivability due to the relatively lazy ramps and longish duration...
2017 Grand Cherokee Overland
Re: The dreaded "pick a cam for me" thread. well, which one [Re: patrick] #1336299
12/10/12 01:19 PM
12/10/12 01:19 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Crower 271HDP. 222/234@.050 .496/486 lift in 112's in at 107. run the 3.23's and you'll be fine with just a standard 383 converter. If you had more compression or 915 closed chamber heads get it cut on 108 centers.
Crabman (David K's) cam also is a great cam for the $$$, it's the old General Kinetics grind that PAW also sells as their House grind, it's very close to the Crower in duration but has a little less lift. The Crower 271 is one of those Natural cams that just does everything great.
383's love to rev but the trick is to not kill the bottom end, it has to be cammed more like you would a smallblock.
This is an AWESOME cam, maybe the best all-around BBM hydraulic cam ever made. It's also a great stock replacement cam for a 440 six pack or magnum.
WIZE
In Car:
Re: The dreaded "pick a cam for me" thread. well, which one [Re: Streetwize] #1336300
12/10/12 02:08 PM
12/10/12 02:08 PM
JohnRR Offline
JohnRR  Offline
Bobby , which cam the Crower you list above or the little summit cam ?
Re: The dreaded "pick a cam for me" thread. well, which one [Re: JohnRR] #1336301
12/10/12 02:31 PM
12/10/12 02:31 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The Crower
WIZE
In Car:
Re: The dreaded "pick a cam for me" thread. well, which one [Re: Streetwize] #1336302
12/10/12 05:37 PM
12/10/12 05:37 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
That Crower grind sounds a lot like the old Crane 302H 232/242 @ .050" .504"I/528"E 112 LSA. maybe one step down
Re: The dreaded "pick a cam for me" thread. well, which one [Re: Skeptic] #1336303
12/10/12 05:45 PM
12/10/12 05:45 PM
$58!!! On sale now--my pick wins!!
Re: The dreaded "pick a cam for me" thread. well, which one [Re: Skeptic] #1336304
12/10/12 09:25 PM
12/10/12 09:25 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I never cared much for those Crane Hydraulics with their generic 'SBC' lobes. I had a buddy with a 69 GTX and he put that 278 Energizer in it. That thing wouldn't Fall out of a Tree with an Energized kick in the Bawlz
Stick with the Crowers , they have several Mopar grinds that just flat out work.
WIZE
In Car:
Re: The dreaded "pick a cam for me" thread. well, which one [Re: ] #1336305
12/11/12 12:28 AM
12/11/12 12:28 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Ding, ding, ding, we have a winner!!!
Re: The dreaded "pick a cam for me" thread. **Update** [Re: VITC_GTX] #1336306
12/29/12 05:40 PM
12/29/12 05:40 PM
Shelby, Ohio
JeffL Offline
JeffL  Offline
Shelby, Ohio
Which brand pistons did you use?
Re: The dreaded "pick a cam for me" thread. **Update** [Re: JeffL] #1336307
12/29/12 08:39 PM
12/29/12 08:39 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I used an older, new, set of TRW 2257P that I bought from another member.
Re: The dreaded "pick a cam for me" thread. **Update** [Re: VITC_GTX] #1336308
04/13/13 01:06 AM
04/13/13 01:06 AM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
How did this turn out? Have you run that cam? I'm curious.
