Page 2 of 3 1 2 3
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334139
11/13/12 10:12 PM
11/13/12 10:12 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Lifters are Comp 98829's. Heads are Stage V Millenniums. Cam is about 280 @ .050 at about .685 lift on intake. The spray oiling remains to be proven on the street, but I think 572Charger has used this setup quite a bit on the street with no problems. There is really quite a bit of spray up in the valve covers at pressure. I'll be watching it closely while driving the car next year during testing, if necessary we will add some oil to the top end, either via pushrods or more spray.
why do you think you will have problems with oiling on the valve train? I thought that Barton Rocker setup should be problem free???
You got a "mild" cam and dnt think you will be pushing the RPMs too hard...so why do you think it would be a problem???
Re: Drag Week 2013 Hemi on Dyno [Re: domingo] #1334140
11/14/12 01:17 AM
11/14/12 01:17 AM
Indiana
Scott58 Offline OP
Scott58  Offline OP
Indiana
Seems like the captions on the curve were confusing so I edited them and put the peak numbers on the graph.
As to the oiling, I don't really expect problems, but there is a lot of street driving during Drag Week, including idling and low RPM operation in traffic, etc. It will find any weaknesses! My plan is to do a fair amount of similar driving and check the valvetrain to make sure there are no dry spots getting hot under the valve covers.
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334141
11/14/12 02:11 AM
11/14/12 02:11 AM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Oh,,,I gotcha!!!
killer engine BTW.....I need one like that!!!
Re: Drag Week 2013 Hemi on Dyno [Re: BBR] #1334142
11/14/12 03:27 PM
11/14/12 03:27 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
The engine is going into a 67 Belvedere chassis. I plan to run in the Street Race class, big block normally aspirated category.
x2!!!!
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Drag Week 2013 Hemi on Dyno [Re: mcat4321] #1334143
11/14/12 03:41 PM
11/14/12 03:41 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
How much static compression do you have???
Re: Drag Week 2013 Hemi on Dyno [Re: domingo] #1334144
11/14/12 05:57 PM
11/14/12 05:57 PM
CA
Joe Dokes Offline
Joe Dokes  Offline
CA
That engine is truly awe inspiring, those ports look like they could swallow a small child!
Can't wait to see it run.
Regards,
Joe Dokes
Re: Drag Week 2013 Hemi on Dyno [Re: domingo] #1334145
11/14/12 07:11 PM
11/14/12 07:11 PM
Indiana
Scott58 Offline OP
Scott58  Offline OP
Indiana
Static CR is 11.7:1. The ports were that size when I bought the heads, they were enlarged some time in the past. Ideally, they could be smaller and that would probably bring the torque up some down low, but as it stands at 900+ ft-lbs in a NA narrow tire class it should do fine. On top I think the engine is making everything it can with that cam, the oversize ports don't seem to be hurting it. I'm curious to see how it drives on the street.
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334146
11/15/12 02:36 AM
11/15/12 02:36 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Kim behind the wheel, you with the camcorder...
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Drag Week 2013 Hemi on Dyno [Re: MoparBilly] #1334147
11/15/12 09:52 AM
11/15/12 09:52 AM
Indiana
Scott58 Offline OP
Scott58  Offline OP
Indiana
Too scary for me....how about Rachel behind the wheel and YOU with a camcorder?
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334148
11/25/12 10:47 AM
11/25/12 10:47 AM
pa
572charger Offline
572charger  Offline
pa
mine has the spray bar oiling with no problems in 10 yrs !!!! my cam is bigger ive got regular stage V heads mine is about 900 hp ive run 9.60s at 142mph on pumpgas at 3910lbs mine is out of the car for the 1st time in 5 yrs for a freshen up for 1213 drag week !!! maybe i'll get some millenium heads
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334149
08/08/13 09:45 AM
08/08/13 09:45 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Bump for checking in on Drag Week MOPARS....you guys still planning on going?
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Drag Week 2013 Hemi on Dyno [Re: 67HEMI] #1334150
08/08/13 10:09 AM
08/08/13 10:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I'm gonna be there.... I'm putting the new engine
in today.. I did a little fine tuning of the front end
so its easier to get the starter out in case it breaks
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334151
08/08/13 01:54 PM
08/08/13 01:54 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Reached a long awaited milestone in my Hemi build this week. After collecting parts and slowly progressing through the build for the past year and a half, the engine finally found its way to the dyno cell last week. I had hoped to run the engine in 2012, but the schedule did not work out. I am now targeting 2013 to have engine and car at Drag Week.
I am in luv....
You know, that is about everything I would do to my Hemi, and then some...Saweet...You got to post some vids on how that runs!
Re: Drag Week 2013 Hemi on Dyno [Re: 67HEMI] #1334152
08/08/13 07:55 PM
08/08/13 07:55 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Im still in, I had what ended up being some valve seals that werent working well. I changed them and my smoke show is gone and I have finally gotten to drive it. Still needs a few little things like the tach quit working, radiator leaks now, etc. I hope to actually get some miles on it this weekend.
For drag week last year it was together for almost a whole year....this time it will only be a month or so.
Are you in? I look forward to seeing that car.
Considering the average car population drag week is pretty mopar heavy. Just from the top of my head I can think of 8 mopars going and I know I am missing several. Thats a good mopar to brand X ratio lol.
68 Barracuda Formula S 340
Re: Drag Week 2013 Hemi on Dyno [Re: Bad340fish] #1334153
08/08/13 11:52 PM
08/08/13 11:52 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Still in, leaving three weeks early driving to Michigan to see my Mom and sister then onto Bowling Green.
I need to do some testing before DW[both of the tracks here are closed] so the plan is to stop at Tulsa for there Saturday night drags on Aug 17 to test and then more testing at Mid Michigan drag strip[the last time I ran a car there it was called central Michigan]
Its a good thing I do not mind driving.
Re: Drag Week 2013 Hemi on Dyno [Re: Darryls-Demon] #1334154
08/09/13 12:08 AM
08/09/13 12:08 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Maybe I will see you in at the track in Tulsa, I need to get some testing in myself.
Re: Drag Week 2013 Hemi on Dyno [Re: Darryls-Demon] #1334155
08/09/13 12:10 AM
08/09/13 12:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Where does your mom live... if your near the north
Detroit area let me know... maybe you can swing by
Re: Drag Week 2013 Hemi on Dyno [Re: MR_P_BODY] #1334156
08/09/13 01:07 AM
08/09/13 01:07 AM
Glendale Az
Glendale Az
Mom lives 250 miles north of Detroit[little town called Alpena my home town] so I will have to drive 220 miles one way to test at Mid Michigan.
Hope everything goes well with your car mike.
Re: Drag Week 2013 Hemi on Dyno [Re: Darryls-Demon] #1334157
08/09/13 01:15 AM
08/09/13 01:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Alpena is 45 miles north of my other house (Oscoda)..
I should be buttoned up tomorrow and get on the
road this weekend for testing
Re: Drag Week 2013 Hemi on Dyno [Re: Bad340fish] #1334158
08/09/13 01:55 AM
08/09/13 01:55 AM
Glendale Az
Glendale Az
I will be looking for you at the track Clark, I hope the weather is nice.
Page 2 of 3 1 2 3
