Re: Upgrading a Fairly Stock Suspension? [Re: MuuMuu101] #1332548
11/10/12 11:07 PM
11/10/12 11:07 PM
NY NY
3
340duster340 Offline
NY NY
I would go worh a complete 73-6 front end set up, upgrade to disc, sway bar and large bolt pattern all at once.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: Upgrading a Fairly Stock Suspension? [Re: 340duster340] #1332549
11/10/12 11:34 PM
11/10/12 11:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I considered posting this suggestion but knowing he already has discs I let it go....
But it would give him allot of upgrades..
1) Improved design Idler arm
2) Improved design motor mounts
3) Improved design sway bar
4) Large bolt pattern discs with much cheaper parts
I'd rebuild everything outside the vehicle, get the K member all welded & braced.. If you want a bigger sway bar I noticed the 72 & up is considerably cheaper than the 68 design...
Re: Upgrading a Fairly Stock Suspension? [Re: MuuMuu101] #1332550
11/10/12 11:34 PM
11/10/12 11:34 PM
Alberta
rustbuckett68 Offline
Alberta
If you have 'self serve' wreckers handy. look for S-13 on the body plate. that is the 340 suspension. I got my T-bars and 6 leaf springs from a 4 Dr. Dart. Best deal I did, other that the 75 Valiant I bought for parts, mainly for the front cross member and disc brake setup. Huge improvement.
