Page 2 of 4 1 2 3 4
Re: Keith Black Block? [Re: Chris'sBarracuda] #1331598
11/07/12 08:39 PM
11/07/12 08:39 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Thank God Keith Black Racing made it thru some lean years. I hope all is going well.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Keith Black Block? [Re: pittsburghracer] #1331599
11/07/12 09:05 PM
11/07/12 09:05 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
Ken black is very helpful to me. An the block that I have is a old one. I can call for advise alway takes may call.
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Keith Black Block? [Re: maximum entropy] #1331600
11/07/12 10:57 PM
11/07/12 10:57 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
I wish I had a big blow-up picture of that to hang on my living room wall with all the race car pictures. No home interior crap hanging on our walls
i think i'll take down my tv and put a big print of that block up. stunning.
WOW that does look nice and the best thing about it.. It's going in my Dart with one of those Procharger things.
Thank you Ken Black
Thanks to Performance Only (Dan) for putting up with me!
Re: Keith Black Block? [Re: poisondart2] #1331601
11/07/12 11:24 PM
11/07/12 11:24 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Ken, definitely on my list for the new Racecar. Nicknaming it Willie, for our great friend Big Willie. Is it possible to have your small-cube water block with dual spark plug heads? Whose heads? Twin Turbo app. Keep up the great work.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Keith Black Block? [Re: sunroofgtx] #1331602
11/08/12 12:00 AM
11/08/12 12:00 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Ken (or Dan) maybe a stupid question but what's with the water pump holes? is this using a different cooling flow pattern?
Re: Keith Black Block? [Re: jamesc] #1331603
11/08/12 12:28 AM
11/08/12 12:28 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Bottom holes are casted top holes are drilled
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Keith Black Block? [Re: KB RACING ENG] #1331604
11/08/12 12:36 AM
11/08/12 12:36 AM
Delray beach, Florida
P
Performance Only Offline
P
Ken, Thanks for the update, with pictures no less. I'll give you a call next week.
None of the aluminum blocks on the market are inexpensive, but when you consider the options available with these blocks and the customer service that stands behind the product, I still firmly believe they are the only real choice for anyone that wants to make some serious horsepower.
Over the years i think i've had my hands on just about every name brand RB and Hemi block available and the KB block puts everything else to shame.
machine shop owner and engine builder
Re: Keith Black Block? [Re: Performance Only] #1331605
11/08/12 12:39 AM
11/08/12 12:39 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Great to know, Dan. What dual plug heads will work, or will it be a custom? (Hope not)
Re: Keith Black Block? [Re: bigtimeauto] #1331606
11/08/12 12:39 AM
11/08/12 12:39 AM
jamesc Offline
jamesc  Offline
that's what i was thinking, there was a machine operation left being that block isn't finished but wasn't sure and was too lazy to run out back and look to see what mine looked like..sides it's cold, wet and nasty out
Re: Keith Black Block? [Re: Performance Only] #1331607
11/08/12 12:41 AM
11/08/12 12:41 AM
jamesc Offline
jamesc  Offline
well i won't be making big HP but at least i feel i made the right choice
Re: Keith Black Block? [Re: Performance Only] #1331608
11/08/12 12:53 AM
11/08/12 12:53 AM
PA.
"Little"John
"Little"John
PA.
100%
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Keith Black Block? [Re: Performance Only] #1331609
11/08/12 10:15 AM
11/08/12 10:15 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have 2 KB cast blocks and have run just as fast as a billet block, but what about the BAE billet block?
They are quite a eyeful to look at.
Re: Keith Black Block? [Re: 604 Hemi GTX] #1331610
11/08/12 11:42 AM
11/08/12 11:42 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I'm in the process of collecting the parts for my 604ci Hemi. I'm planning on buying a KBRE aluminum block but not sure which block and what options i should get. I know the street hemi block won't work because i need the raised cam, so is it the stage 8 block i need is there anything else i should get done right now. Things after you got yours, you said i should of got this done.
Thanks for any and all info
Kevin
I'm not sure you need the raised cam block for a Hemi with a 4.50 bore and a 4.75 stroke, 2.20 journal crank.
On a wedge if you want to run any sort of decent lift you need a raised cam block. Are you using a 55mm cam and alloy rods? Do you want to go bigger in the future?
Re: Keith Black Block? [Re: Tig] #1331611
11/08/12 12:40 PM
11/08/12 12:40 PM
P
P
Kevin
I would highly recommend a raised cam block when using a 4.75 stroke crank and 54 MM cam. Rod to cam clearance can be a real and annoying issue if your planning on aluminum rods that are somewhat beefy, even if they're clearanced on the cam side. I've had to re-profile rods for clearance on those combos because most times we run a pretty beefy rod like a GRP pro-mod style. I won't say you can't do it without the raised cam, but why go through all the headaches? just put the raised cam and a gear drive on it and don't sweat the small stuff.
Re: Keith Black Block? [Re: Performance Only] #1331612
11/08/12 02:34 PM
11/08/12 02:34 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Consensus is you can with steel rods and stock cam tunnel position and diameter.
Good point though, you may as well tick the box for raised cam if you're starting from scratch.
Re: Keith Black Block? [Re: Challenger 1] #1331613
11/08/12 08:53 PM
11/08/12 08:53 PM
CALIFORNIA, USA
KB RACING ENG Offline
CALIFORNIA, USA
Challenger 1, Nothing against the BAE Billet (Forged) blocks but we prefer the KB Forged Blocks. We think they look pretty nice and they're 30% stronger than the other Billet (Forged) blocks on the market. Different alloy.
Re: Keith Black Block? [Re: KB RACING ENG] #1331614
11/08/12 09:07 PM
11/08/12 09:07 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Hubba , Hubba, that looks a true thing of beauty . . .
I must not look any longer, I must not look any longer
Re: Keith Black Block? [Re: KB RACING ENG] #1331615
11/08/12 09:12 PM
11/08/12 09:12 PM
Cincinnati, Ohio
Cincinnati, Ohio
Sweet!!
Re: Keith Black Block? [Re: KB RACING ENG] #1331616
11/08/12 09:43 PM
11/08/12 09:43 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Have you ever thought about casting a G3 hemi block?
Sorry for the hijack. Matt
Re: Keith Black Block? [Re: Challenger 1] #1331617
11/08/12 10:04 PM
11/08/12 10:04 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
looks too nice to use. now after seeing it, i want one.
Page 2 of 4 1 2 3 4
