Re: dash light blue diffusers fried [Re: 471Magnum] #1330827
11/10/12 10:10 PM
11/10/12 10:10 PM
Space Station #5
471Magnum Offline OP
Space Station #5
Got my replacement LEDs today and installed them. Photo attached.
Fuel and Oil Pressure gauges were a little dimmer than the speedometer before I did the swap. That's just an issue with the bulb location.
Airgrabber switch still has an incandescent.
I guess there is a blue diffuser inside the heater control. Might have to dig that out of there.
GREEN is from the display on the aftermarket stereo. Aftermarket tach still has whatever incandescent bulb it came with.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: dash light blue diffusers fried [Re: 471Magnum] #1330828
11/16/12 07:05 PM
11/16/12 07:05 PM
Ohio
dobie Offline
dobie  Offline
Ohio
Well, I finally put mine in today. I have somewhat of an issue though...
By accident, i hit my horn after I was done with everything. I noticed that when I did, i could see light coming from the turn signal indicators, and the brake and oil warning lights....
What the heck is going on??? I hit the horn, these 4 spots light up.... I kid you not... NEVER did that before, so its gotta be the LED lights...
1968 Plymouth Road Runner 383 4 speed
Re: dash light blue diffusers fried [Re: dobie] #1330829
11/16/12 07:24 PM
11/16/12 07:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Not the LEDs but a ground issue. Make sure the dash is grounded good through the screws that hold it in and make sure the steering column is grounded to the dash frame. There is no connection between the horn and the lights other than ground.
Re: dash light blue diffusers fried [Re: stumpy] #1330830
11/16/12 07:27 PM
11/16/12 07:27 PM
Ohio
dobie Offline
dobie  Offline
Ohio
Ok. Everything works as it should though. I'd think that with ground issues something wouldn't be working right.
I'll keep looking into it.
Thanks.
Re: dash light blue diffusers fried [Re: dobie] #1330831
11/16/12 07:36 PM
11/16/12 07:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Lights light up when you hit the horn. Sounds like something isn't working right to me.
Re: dash light blue diffusers fried [Re: stumpy] #1330832
11/16/12 09:11 PM
11/16/12 09:11 PM
Space Station #5
Space Station #5
You need to fix the ground wire on your steering column.
-Jim
Re: dash light blue diffusers fried [Re: 471Magnum] #1330833
11/16/12 11:33 PM
11/16/12 11:33 PM
Ohio
dobie Offline
dobie  Offline
Ohio
All grounds are good. I went back out and looked everything over again. Here's where its gets really weird...I started it up and noticed that it wasn't charging. The ammeter showed discharge and my volt meter showed way low. All the wires looked to be fine.
So, on a whim I took out all the LED's and put the old bulbs back in. Oddly enough, everything is back to normal. Everything works as it should.
Apparently my car doesn't want the LED's. I'll send them back as I can't use them.
Weird huh?
Re: dash light blue diffusers fried [Re: dobie] #1330834
11/16/12 11:47 PM
11/16/12 11:47 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Bummer, I still have 3 of the diffusers if you want them...
I am truckless..
