Re: Cost of a Hemi ???
[Re: quickd100]
#1330521
11/05/12 04:38 PM
11/05/12 04:38 PM
Posts: 2,648 USA
max
super gas
super gas
USA
It can be done much cheaper IF you don't mind waiting for deals to come along. Even so...if you start keeping track of all the costs of one, you'll end up in the loony bin. Dave
That is how I built mine and it took about a year to gather all the parts. I came in a few grand under the price of a crate engine and I knew how it was put togeather since I did the assembly myself.
[Re: max]
#1330522
11/05/12 05:51 PM
11/05/12 05:51 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Yes one can do it on the cheap if theey scrounge for parts , does your cost total include traveling to car show after car show looking for the cheap parts ?
and like this state from above ...
Like other free market items, the price is determined by the most foolish buyer.
One person claims they did it for pennies on the dollar everyone else thinks they can too.
[Re: DakFink]
#1330523
11/05/12 06:16 PM
11/05/12 06:16 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Mine is a 9.5-1 pump gas hemi with a mechanical fuel pump. It looks bone stock and since I was spending the money for a Hemi, why not get the best parts available? Heads are not much more to get the stageV, cranks are the same for a 3.75 eagle/k1/scat as a 4.5, rods are the same for them, cam and lifters are a no brainer to goto roller, with the lack of ZDDP in the oil, why risk a 20K motor for 800 extra in a roller. Stock Hemi Rockers suck, scrub and ratio's are almost alway way off, I had rockers that were 1.3-1.4 ratio when they should have been 1.52 so I spent the money for stageV. Tim Quote:
DOH!!!
I guess I really stepped into this one!!
My apologies guys BUT what I was really questioning is the Street-able Pump Gas Hemis.
From what I have seen so far these are pretty much race pieces and actually decent prices for what you're getting.
My question is the ones I have looked at as complete engines the prices look like those ya'll have quoted for race Hemis.
Another question arises: More than a few times I have seen people say they have had major issues with Hemis after being built. This is the reason I was looking more at complete engines. Have the builder run it and inspect it before I take it. To make sure there are no underlying issues with it.
[Re: astjp2]
#1330524
11/05/12 06:23 PM
11/05/12 06:23 PM
Triple Threat
Renton Washington
The two Itemized builds here are $18K and $23K respectively.
Not a cheap venture.
[Re: astjp2]
#1330525
11/05/12 07:21 PM
11/05/12 07:21 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
What I want to see is that $900 air cleaner..... ![](/ubbthreads/images/graemlins/shock.gif) Quote:
Ok, lets compare mine. world block 2500 stageV heads 3800 crank 500 rods 700 pistons 280 cam/lifters 700 timing chain 125 head studs 295 intake 500 valve covers 250 rockers 2600 (stageV roller, dichelles shafts, dvorak stands) Carbs 1200 fuel pump (racepumps 2000) 400 Misc. hardware 350 oil pan (Milidon 31581) 350 External oil line 145 oil line 145 oil pump drive 150 valve spring 200 magnafuel shear plates 200 fuel lines 100 fuel pressure regulator 155 throttle linkage 100 air cleaner 900 balancer 275 flywheel 120 machine shop 2000 Al Debevek K-membeer 900 paint, 280 for 1 quart for original PPG formula Gaskets 400 Bearings 375 spark plug wires 180 distributor 150 (includes recurve)
This does not count shipping or travel to get some things done. Its not cheap. I could have bought for cheaper but I know what is in my engine. Many of the parts are similar in cost to what is listed below, I did some shopping around for some things to save a buck. It also does not count any mistakes in parts fitment. Tim
Just the long block to my Hemi has cost me over $22K in parts ![](/ubbthreads/images/graemlins/violin.gif)
Block $5000 Heads $5500 Rockers $2500 Crank $3641 Rods $1300 Pistons $1000 Valve covers $450 Gear Drive $550 Camshaft $400 Lifters $700 Pushrods $300 Bearings $150 Damper $360 Oil Pan $300 Intake $550 Head gaskets $200
And there are other misc like hardware, etc.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: JohnRR]
#1330529
11/06/12 12:48 AM
11/06/12 12:48 AM
Posts: 2,648 USA
max
super gas
super gas
USA
I actually bought two pieces of the puzzle at one car show, the crank was a local part and the rest came from on line.
[Re: Dragula]
#1330531
11/06/12 07:03 AM
11/06/12 07:03 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
DOH!!!
A race hemi is not 16K if those are the prices your refering to...A used race hemi is a bunch more!
And as far as underlying issues, we were not aware of some of the rather odd changes to the after market block we recieved, nor was there any warning included. We have built blocks from this manufacutrer before, and never had these particular issues before. We caught most of the changes, but missed one major one that's not really somthing you can vissually see, and now we know. Most builders will already know about all the updates, so stick with one that builds them on a regular basis. It will save you headaches later.
As for me, I think I am done with CI blocks based on the initial cost, and then the cost to fix it and nobody seems accountable even though their name is all over it. Not been real happy with mine and the issues, but its almost back togather as a short block.
NOPE!! try adding another $10k to the $18-23K that has been stated here. For the prices I have seen for a simple pump gas 426-528 Hemi.
In that some of the builders MIGHT have Aluminum Heads at most.
Far as the underlying issues. I have heard many people had ordered Crate Hemis back in the late 90's- early 2000's and they pretty much had to rebuild them out of the crate. LOTS of issues.
I thought it was a Mopar thing. Then as the years go by I have seen many people Including Reputable Builders having issues as well.
But as you have stated changes were made for better or worse? No one mentioned these changes to the builders and now it bites them in the butt.
To me it sounds like if a person decides to build a Hemi, any way they go about it they better have a reputable current Hemi builder in their corner.
I guess I better get the Book that someone mentioned from AR Engineering and do some reading before I decide if I want to tackle this or not.
[Re: DakFink]
#1330532
11/06/12 07:15 AM
11/06/12 07:15 AM
Posts: 625 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Agreed Hemis aint cheap ![](/ubbthreads/images/graemlins/eeek.gif) But have you guys looked at the cost of some of the nasty, mondo cube SB builds out there ![](/ubbthreads/images/graemlins/flame.gif) Im putting the finishing touches on my 572 - I can tell you from experience that shopping intelligently can go a long way to making a lot of difference in the total outlay. ![](/ubbthreads/images/graemlins/biggrin.gif) MP block Bryant crank Saenz rods Barton pump w/swinging pickups Diamond coated pistons Bullet roller stick Isky Red Zome EZ rollers Stage V rockers Ported Indy Legend heads Milodon gear drive Indy RP intake Pro Systems 1200 Dom Im into this engine for less than many might think and Im happy about that !! ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: nz383man]
#1330533
11/06/12 07:24 AM
11/06/12 07:24 AM
Posts: 912 London, England
mopar_mark
London, England
People like myself that try doing this on the other side of the world (New Zealand) need their head seen to. ![](/ubbthreads/images/graemlins/nervous.gif)
Hemi builds just seem to get out of hand. ![](/ubbthreads/images/graemlins/shruggy.gif)
You can say that again, I'm in the midst of coverting my Hemi from a blown 14-71 set up to Twin Turbos. Complete refresh, new pistons, rings, cam, manifold, etc, etc, etc.
Its best if I dont add the costs up ![](/ubbthreads/images/graemlins/laugh.gif)
Old Set Up
![](http://i378.photobucket.com/albums/oo230/mopar_mark/Bob-Cuda2-Brklands09.jpg)
New Set up - Part way through
![](http://i378.photobucket.com/albums/oo230/mopar_mark/HEMI%20CUDA%20-%20TWIN%20TURBO/DSC00691.jpg)
Mock up stage
![](http://i378.photobucket.com/albums/oo230/mopar_mark/HEMI%20CUDA%20-%20TWIN%20TURBO/DSC03177.jpg)
[Re: DakFink]
#1330536
11/06/12 11:53 AM
11/06/12 11:53 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Why are Long Block Hemis (gen2) so expensive?? because it's a Hemi... $ for $ a wedge is a much better value for about 90% of folks here. It can be built for about 1/2 of the Hemi and much less that that R2D2 P7C3pO SB.... I guess you just have to really want it. Like those guys who buy a six-pack...is it better? Not really but it looks cool. ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: Mr.Yuck]
#1330537
11/06/12 12:31 PM
11/06/12 12:31 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
I have built both. I don't see where a comparable wedge costs half as much. Rotating assembles are practically the same cost. Hang on parts are the same. Oiling system is the same/similiar. Cam/lifters are compairable. Hemi head Castings and rocker gear is more expensive. Also the blocks cost more. Unless you have a machine shop in the shed, most of the machine work costs the same. A hemi is worth a lot more money and will give you a much better return on investment. Also the block is much better then a traditional 440 because of the cross bolted mains. Its more money up front, but if you are building a car from scratch the hemi will yield a lot more money on the investment. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: DakFink]
#1330538
11/06/12 12:35 PM
11/06/12 12:35 PM
JohnRR
I did just see 528 Ray Barton with about 300+ miles on it in the Engine For Sale section here. Asking $16000
I'm sure he is getting offers for 5k from Moparts members for it .
[Re: JohnRR]
#1330539
11/06/12 12:44 PM
11/06/12 12:44 PM
DakFink
LOL no doubt!!! I'm a tite-axx BUT I won't insult someone with a LowBall offer. If I can't afford or don't want to pay their asking price I just move on. Especially when it's that LOW compared to what I have been seeing else where and when Ray Barton touches it, the price goes up even more.
[Re: DakFink]
#1330540
11/06/12 12:46 PM
11/06/12 12:46 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Not sure why they cost so much but I will have about 26000.00 in mine ![](/ubbthreads/images/graemlins/bawling.gif) .Some of the parts so far. Callies Crank Oliver Rods Ross Pistons New Indy aluminum Block Steve Morris/Bullet Cam .712 276 @.050 on 114 Dick Landy rocker arms kb heads with titanium valves MSD pro billet distributor Milodon drive Mezeire 55 gph water pump Milodon magnesium valve covers powdercoated Indy blower manifold powdercoated 10-71 blower hard anodized/teflon stripped rotors 8mm polished drive kit clear powder coated Two Quick fuel dominators Bds carb adaptor Enderle linkage Charlies aluminum oil pan Tti ceramic 2 1/4...4 inch headers with bungs
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
