If the rear band doesn't apply when downshifting to 1st it won't hurt the sprag but throttling back up hard will.
Back to the original subject, as long as the area around the front pump suction port seals against the extension it doesn't matter if the rest of the extension mates perfectly against the valve body. You're worrying about nothing.
