`62 Dart brake upgrade
#1329211
10/31/12 06:08 PM
10/31/12 06:08 PM
Posts: 1,671 Caldwell, Idaho
67R/T4speeder
Caldwell, Idaho
I have a big 440 under the hood and little itsy bitsy manual drum brakes....bad idea. Has anyone had experience with putting a kit and from who would you recommend for this. Street driven but do need to stop....allot better. I do have 15" wheels so I think I have room for it ![](/ubbthreads/images/graemlins/sawzall-smiley.gif) . Thank you Andy
Re: `62 Dart brake upgrade
[Re: AndyF]
#1329214
11/01/12 11:18 AM
11/01/12 11:18 AM
67R/T4speeder
Caldwell, Idaho
A '62 Dart is a B-body isn't it? If so, then it should be easy to bolt the factory 11.75 inch setup on there. That works better than the kits when using a 15 inch wheel.
I thought it was a B body that year also
[Re: 67R/T4speeder]
#1329215
11/01/12 03:35 PM
11/01/12 03:35 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
'62 Dart is a B-Body. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: jcc]
#1329217
11/02/12 12:37 AM
11/02/12 12:37 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Except the "b body" nomeclature was not introduced until 1963.
Touche!
[Re: MuuMuu101]
#1329218
11/02/12 11:15 AM
11/02/12 11:15 AM
67R/T4speeder
Caldwell, Idaho
Touche!
So its a ?????????????? Poor lil one year Dart all by itself ![](/ubbthreads/images/graemlins/pity.gif)
[Re: 67R/T4speeder]
#1329220
11/02/12 03:16 PM
11/02/12 03:16 PM
Posts: 22,812 Bitopia
jcc
Bitopia
A freak? It is IMO for all intents and purposes, a named after the fact, one year only, Dart "B body", and always has had this nebulous pedigree, just to be clear. ![](/ubbthreads/images/graemlins/grin.gif)
[Re: 67R/T4speeder]
#1329224
11/03/12 08:21 PM
11/03/12 08:21 PM
Speedway motors has a nice kit that includes everything from the spindles to the splash shields.
Personally, I wanted to save weight so I went with the slightly more expensive Wilwood kit that bolts to the existing drum spindles. Find someone that can safety wire and you're all set!
