Re: 1970 Hemi 'Cuda AAR Convertible Project........
[Re: Southern Wolf]
#1327758
11/18/12 10:55 AM
11/18/12 10:55 AM
Posts: 778 Dry Heat AZ
AAR#2
Dry Heat AZ
Completely agree that once it's set . . it's not being removed.
Since someone was good enough to leave the hood pins out prior to a drive around town, the backing was busted loose and repaired with a nice fiberglass patch, a piece of angle iron, and a couple bolts. This made the decision easy for me to repair it. I started by making templates traced from the fender contours, and set them the width of the hood, creating a tool to be able to work the hood. Not gonna lie, took me a lot of time and some careful planning to correct the hood, but it turned out VERY well.
The reason the hoods warp is a combination of load, time, and resin cure. When composite parts are cured there is much to consider. Unsure if we had any of it down in the US (or world) in 1970. The basic idea that when a bend angle or contour is layed up and cured, the resin drying (shrinking) closes the angle or contour, even though the tool is trying to keep it in it's perfect form. While each company has their own proprietary formulas for figuring the amount it will close, often trial and error prevail. So if Ma MOPAR would have thought this out better, they would have created a tool that was less contoured than the final desired shape. It was appearent this was not the case when I broke the stiffening structure off the back of mine. I had to clamp it to the tool to get it to come down. Then bonding the structure to the back again, the bonding system helps to account for the variations, leaving me a pretty good hood.
Picture the stresses already in the hood, now add load in the direction the hood wants to bow, over years, with additional curing of the resin system (yes they continue to cure, and become brittle) . . . . bang, big open gap.
Sorry for the long disertation, but figured if you understood why, and were presented with a solution, it's easier to fix.
And if it's warped as hell, all AAR savy will just accept it for being what it is
[Re: AAR#2]
#1327759
11/18/12 11:13 AM
11/18/12 11:13 AM
Posts: 784 SC
Southern Wolf
SC
[Re: AAR#2]
#1327760
11/18/12 12:36 PM
11/18/12 12:36 PM
Posts: 294 Oregon
KillerCuda
this is what i love about this site, the 'real world' input from folks. thank you all for your insight on this issue, now i have a much better knowledge of how things are working in that lovely bulge of fiberglass. well, maybe i will still keep the prop rod, but in your opinions, do you think leaving the really warped side spring out will help at all? maybe i jumped the gun and was just 'optimistic', but it seems to sit a little bit better? either way, thank you all for chiming in, now it's here for everyone to learn from.... D
[Re: AAR#2]
#1327763
11/18/12 09:31 PM
11/18/12 09:31 PM
Posts: 294 Oregon
KillerCuda
Taking the spring out will help take the additional load out of the already warped hood (So you may have a LITTLE less bow in it) If you fix the bow, leaving the springs out will help keep it its best for a longer period of time, but these hoods are notoriously off, so in my world, any true MOPAR contisour expects to see a bit of warp, a badge of honor so to speak. If perfect, it just doesn't look right to me (as long as you cant see in the engine bay)
You can always try the illusion of adjusting the hood lower at the window, bringing the center lower . . . unsure how bad yours is but sometimes this can help.
i am all about the 'badge of honor', and have had to explain to EVERYONE non mopar that "that's the way they all are", lol, but few get it. it doesn't bother me to have some bow at all....
anyway, it was/is very severe. you could see into the engine compartment, and i already have the window edge upper corner 'dipped' down below the driver fender, hence the reason for looking to lessen it a little bit if possible. i don't need it 'flat', just a wee bit better than it was. seems like it will be, without the spring. (may not have anything to do with the actual hood flattening without it in, but just letting it relax onto the car more, who knows, but it does look better to my eye right now, so i will take it....)
thanks for the tips!
[Re: KillerCuda]
#1327764
11/20/12 01:02 PM
11/20/12 01:02 PM
Posts: 294 Oregon
KillerCuda
well, here we go again. engine back from builder, installed, go for maiden voyage of 15 miles, and drip drip drip. this is ridiculous. i can't believe it ran on the dyno and didn't leak, according to him.
i put dye in the oil, to really confirm the leaking area, (appeared to be rear main), and sure enough, no oil anywhere except coming down from the rear main. so, out it comes again.......
[Re: AAR#2]
#1327767
11/20/12 10:43 PM
11/20/12 10:43 PM
Posts: 294 Oregon
KillerCuda
This is testiment to using people you can get to within a 1/2 day drive. Sorry to hear your having issues.
amen, everyone learn from my mistake PLEASE!
he is no longer returning calls, emails, nothing. he stated in a final email, "the agreement between buyer and seller has been met". eddie haines feels ok about this, ie, 'sleeps at night' knowing he is royally screwing me over after paying top dollar for this engine. it runs great now, but come on. it is far from right at this point, and i was willing to work with him on a resolve. i am a very unhappy customer, for practical reasons, and he is not willing to do anything about it. completely unacceptable behavior as a vendor in my opinion.....
note to everyone, BUYER BEWARE.
[Re: KillerCuda]
#1327773
11/26/12 11:41 AM
11/26/12 11:41 AM
Posts: 294 Oregon
KillerCuda
edited for 'family viewing', (hope it's ok) just a pic (that i REALLY wanted to send to the builder) showing my feelings about having to dig into a new motor myself, that i paid a poop ton of money for, wear and tear on a freshly resto'd engine compartment, not to mention wrecking the new paint on the engine, oh, and that last little thing, all my money, free time, and patience i had left in me. such is life, carry on!
[Re: JohnRR]
#1327775
11/26/12 01:58 PM
11/26/12 01:58 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
I was just going to post that thread. Sorry to here of you troubles.....it sucks, I know.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#1327776
11/26/12 02:06 PM
11/26/12 02:06 PM
Posts: 294 Oregon
KillerCuda
haha, thanks guys! i was just going to post it up as well, as i learned a lot from your situation troy, and applied it to mine.....
this thread is slightly behind in 'real time', but almost caught up. rope install is next!
[Re: Troy]
#1327777
11/26/12 03:45 PM
11/26/12 03:45 PM
Posts: 27,650 So Cal
autoxcuda
So Cal
You have an Eagle Hemi crank also, correct?
