Page 4 of 16 1 2 3 4 5 6 15 16
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327678
11/02/12 12:07 PM
11/02/12 12:07 PM
KillerCuda Offline OP
some 'before' firewall shots for reference for me later, when i was reassembling.......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327679
11/02/12 12:10 PM
11/02/12 12:10 PM
other side. i had already done the blower motor along with the interior. i know it's probably not zinc coated correct, it was done up with something gold-ish, so i just hit it with some 'eastwood carb renew' to make it fresh. in hindsight, i would have done this differently. i wasn't really thinking at the time. what are ya gonna do eh?
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327680
11/02/12 12:11 PM
11/02/12 12:11 PM
front area.......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327681
11/02/12 12:13 PM
11/02/12 12:13 PM
the other front......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327682
11/02/12 12:14 PM
11/02/12 12:14 PM
side.......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327683
11/02/12 12:15 PM
11/02/12 12:15 PM
other side......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327684
11/02/12 12:17 PM
11/02/12 12:17 PM
k-frame and company. i saw remnants of 'orange' and 'black' overspray down here. so, at some point in the cars history, there was an 'engine in' re-detailing of the car......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327685
11/02/12 12:20 PM
11/02/12 12:20 PM
i had some rattle can mixed up at the local auto paint store, in the closest hue they could match the body's red. everything got taped off, prepped, and shot with a couple coats of it. the k-frame and company were then prepped as well, and hit with some semi-flat krylon.......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327686
11/02/12 12:25 PM
11/02/12 12:25 PM
new re-pop battery on a freshly sprayed battery box. i love that the fill caps still screw off, and you can see the sealed cells inside. this battery of course came with a stack of warning labels:
DO NOT FILL THIS BATTERY WITH WATER, YOU WILL RUIN IT!!!!!!!
like the ol' label on the hair dryer, 'do not use in bathtub', you know someone did it at some point, hence the need for the label.
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327687
11/02/12 12:33 PM
11/02/12 12:33 PM
BOOM! all detailed and doned up, awaiting her new tenant! i know it's not all 'concourse' correct, but i did the best i could, without breaking the bank. nicely restored wiper motor, date coded voltage regulator, stock master cylinder, factory style wiring harness, all factory style clips, connectors, etc... all the nuts and bolts are not of the correct marking and style, but are all new, and don't jump out at you unless you are a knowledgable cat. (which most of you probably are!) i would love any tips, notes, etc, to make it look more proper if you have some constructive criticisms to add. (yeah, the electronic ignition doesn't belong there either, but it came with the motor. if i had it to do over again, and you will hear why later, i would have gone stock style distributor with a pertronix module......)
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327688
11/02/12 12:38 PM
11/02/12 12:38 PM
forgot one, the turn signal housings. i wasn't sure of the finish here either, so i blasted them, repainted the silver inside the reflector area, (these were painted black ALL over, everywhere) and again hit the outside with the ol' eastwood carb renew........
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327689
11/02/12 12:44 PM
11/02/12 12:44 PM
stay tuned for the next chapter, engine install! here is a sneak peak as to what's to come...
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327690
11/02/12 01:51 PM
11/02/12 01:51 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I like that you are using a syringe to put on the RTV on the valve covers. I can only hope that my charger looks as good as your cuda. Tim
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: astjp2] #1327691
11/02/12 05:27 PM
11/02/12 05:27 PM
wow! just found this link on our car, and at least a supposed builders name, i will have to try and look them up. getting closer on the back story, but still not sure what is what. i am kind of surprised at the selling price, i paid a little above half that for the car 2 years ago.....
http://www.barrett-jackson.com/application/onlinesubmission/lotdetails.aspx?ln=1050&aid=221
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327692
11/04/12 11:02 AM
11/04/12 11:02 AM
and here she is, the holy grail. an early mopar performance block, stock bore, stroker eagle cranked 472 hemi, done up all 1970 style. built by eddie haines. more on THAT one later....
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327693
11/04/12 11:03 AM
11/04/12 11:03 AM
this motor has stage V heads, rockers, and a single plane 2x4 intake.......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327694
11/04/12 11:05 AM
11/04/12 11:05 AM
it made 576hp, and 543 lbs.ft. of torque, all done by 5800rpm. mild comp hydraulic roller in there as well.......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327695
11/04/12 11:09 AM
11/04/12 11:09 AM
couple of build shots......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327696
11/04/12 11:10 AM
11/04/12 11:10 AM
rotating assembley ready for going in.......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327697
11/04/12 11:11 AM
11/04/12 11:11 AM
a shot of the aluminum heads and rockers........
