Page 2 of 16 1 2 3 4 15 16
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: Stewpar] #1327638
10/30/12 07:45 PM
10/30/12 07:45 PM
KillerCuda Offline OP
Slant 6, 3-spd trans, bucket seat, AM Radio, Built to US Specs, FE-5 Red with a white top and interior!
nice! thanks for the throwdown, that looks about what i was told it originated from.....
oh, here is a pic of the vin from the TA motor i am trying to reunite with it's owner as well. the motor is almost finished, .040 over, comp stock specs replacement cam, original valve covers, intake, need to check to see if the carbs ar 1970 vintage as well. any tips on that? which numbers mean what, and where on the carbs? thanks again in advance for any info.....
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327639
10/30/12 08:01 PM
10/30/12 08:01 PM
got the interior stripped out, things looked pretty good. i am able to save most everything, but the rear interior panels are shot. original, but in too sad of shape for me to take on. all of the plastics will be re-dyed using sem 'firethorn red'. it's what matches my dashpad, which i can tell used to be black. as i am looking, it appears several trim pieces were black, so i am assuming the original interior was a little toasty.......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327640
10/30/12 08:02 PM
10/30/12 08:02 PM
the gauge cluster went out for rebuild, the engine is being built, so, time for some interior action......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327641
10/30/12 08:16 PM
10/30/12 08:16 PM
all the vinyl interior is in good shape, but is covered in tons of dye jobs. it looks great underneath that dye, so i plan to remove all of that, and just treat them with a good vinyl care product. inside of the seat material reads "legendary, 1994". so, something happened to this car around then, but not sure all what yet, still piecing it together......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327642
10/30/12 08:17 PM
10/30/12 08:17 PM
and as it turns out, brake clean comes to the rescue again. stripped them clean as a whistlem not hurting the vinyl at all.
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327643
10/30/12 08:21 PM
10/30/12 08:21 PM
got all the malfunctioning locks, mirror remote, all sorted, everything lubed, and ready to get covered back up when i am done dying door panels.......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327644
10/30/12 08:29 PM
10/30/12 08:29 PM
i took this time to also repair all the heater box functions. all works again. but somehow, i screwed up the 'off heat defrost' section, it's backwards now! so, if i want heat, 'off' it is!
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327645
10/30/12 08:30 PM
10/30/12 08:30 PM
all the red bits dyed!
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327646
10/30/12 08:35 PM
10/30/12 08:35 PM
all the white bits dyed! i used performance years brand, with the slight pearl in it..... i also replaced the rear interior panels, got a screaming deal on a set of palco's, i know people don't really care for them, but my fronts were an older set, not original like i thought. so, the price was right, the fronts were already fitted, and the rears didn't take too much modding to fit as well. i replaced the seat backs as well. i will probably sell all the interior parts i replaced, as all of them are original mopar pieces......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327647
10/30/12 08:37 PM
10/30/12 08:37 PM
all of the dash/steering metal got re-dyed in firethorn red as well. ready for some re-assembly!
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327648
10/30/12 08:38 PM
10/30/12 08:38 PM
heater controls fixed and complete!
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327649
10/30/12 08:39 PM
10/30/12 08:39 PM
radio working and complete!
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327650
10/30/12 08:40 PM
10/30/12 08:40 PM
floors cleaned and prepped for a little sound/heat mat....
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327651
10/30/12 08:41 PM
10/30/12 08:41 PM
rears as well.....
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327652
10/30/12 08:42 PM
10/30/12 08:42 PM
BOOM! all doned up.......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327653
10/30/12 08:46 PM
10/30/12 08:46 PM
rear panels fit, only problem, i had to really offset the rear window crank hole, it was a no go, not even close. the right side went right on. you can actually see the offset to the right of the handle. i had to transfer the holes for the new snap studs for the tonneau cover as well......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327654
10/30/12 08:49 PM
10/30/12 08:49 PM
i managed to just steam clean the carpets and re-use them, they looked ok after a good cleaning. installed seat belts too, man, a full, matching set of seat belts for a 70 'cuda was really expensive! i was surprised at that. actually, this is my first mopar, quite a few parts were spendier than i thought they would be. what are ya gonna do eh?
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327655
10/30/12 08:50 PM
10/30/12 08:50 PM
the devil is in the details......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327656
10/30/12 08:51 PM
10/30/12 08:51 PM
backseats complete!
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327657
10/30/12 08:53 PM
10/30/12 08:53 PM
all door panels fitted and complete! still waiting on the dash cluster though.......
