Re: when to upgrade from an 8 3/4?
[Re: mikeysmopars]
#1324964
10/24/12 08:23 AM
10/24/12 08:23 AM
Posts: 20,698 in a cattle trailer down by th...
Guitar Jones
Honestly if I had it to do over I'd go with a Dana. I have a lot of money in my 8.75 with a spool, the MP aluminum case and pro gears that are only available in one ratio, a 4.86, so in hindsight if you are going to have to narrow it, buy axles and all that just get a Dana and be done with it. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: racerx]
#1324968
10/24/12 05:34 PM
10/24/12 05:34 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I use an 8-3/4 in my 63 and so far have run 10.70's and it still has stock axles in it. Its an auto car that goes just over 3700 lbs and other then the Detroit Locker it is all stock. Now I only race my car 2 or 3 times a year at the most and usually just a test & tune where I only make a few passes. I did not race it at all this year because of some personal problems. But I want to go to a Dana and would have if I had the money when I built my 493. If you have the cash go with the Dana as its good insurance. And if you blow the 8-3/4 you will be pulling the trans to fix the overrunning clutch (sprag). I am pushing my luck everytime I race my 63 and I know it but I can not afford a Dana right now or I would have one. Ron
[Re: Thumperdart]
#1324974
10/24/12 10:39 PM
10/24/12 10:39 PM
Posts: 437 south central pa
bdaz smblk
south central pa
I've been 9.0's 150 at 3,200 with a 8 3/4 with 1.20 couple 60 ft.
I`ve seen your responces to this kind of post before and am curious if you`d shoot your bad-azz combo for us to see..............
What all would you like to know about it.The car has a nice w8 smallblock with a 727 true 29.5 x10.5 tire with exhaust full interior including a back seat all lights work could drive it on the street if i trusted all the idiot drivers now days (LOL).If u want to know more just say.Thanks Kenny
I`ll say..........NICE is an understatement..........9.0`s, small block n/a, 3200lbs..........that doesn`t happen everyday.........
Thanks your car runs dang good too.I didn't even have the car out this year but hope to lighten the car up and be racing again sometime.If i wasn't broke as a dang on joke i would have a chrome moly cage in this car and save alot of weight.LOL
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: dirt]
#1324975
10/24/12 11:05 PM
10/24/12 11:05 PM
Posts: 8,374 fredericksburg,va
cudaman1969
fredericksburg,va
I am working on a scamp for a friend and its going to be a race car. I am back halfing it probably with ladder bars. The motor is a 440 and used to run 11.60 in a stock weight 70 cuda. With an automatic. He asked what i thought about the8 3/4 he has. It needs narrowed yet but he allready has it. I thought it would be fine. But now he is talking about stroking the motor and getting better heads. So at what point would you say the 8 3/4 needs changed out for a dana 60? If there is a point. Thanks, kenny [/quote
Right after you brake the 8 3/4 .Put a dana in and forget it for years ![](/ubbthreads/images/graemlins/Twocents.gif)
