Re: Hotchkis Total Vehicle System Questions
[Re: ScottSmith_Harms]
#1883210
08/02/15 12:25 AM
08/02/15 12:25 AM
Posts: 16,139 Mesa, Arizona
dart4forte
Mesa, Arizona
I'll be using it for a mix of things from drag racing, autocrossing, to road trips like the Hot Rod Power Tour. I also understand that there will be compromises when targeting a general use type vehicle build. I plan to have multiple setups for the various uses which will primarily involve tire & wheel combos and basic suspension adjustments. I am used to driving pretty hardcore vehicles so I'm not a wuss when it comes to creature comforts or ride quality, niether matter much to me, performance is king. Is this for the yellow Duster?
Abe Lincoln
#1883426
08/02/15 11:36 AM
08/02/15 11:36 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Is this for the yellow Duster? That was the initial idea, but no, not anymore. The yellow car staying all original. I do have another 71 I'm doing, it's going to be the guinea pig. I started this post quite a while back, I still haven't seen any torsion bars offered to make this "Total" vehicle system offering complete? Any updates?
#1883440
08/02/15 11:57 AM
08/02/15 11:57 AM
dart4forte
Mesa, Arizona
Is this for the yellow Duster? That was the initial idea, but no, not anymore. The yellow car staying all original. I do have another 71 I'm doing, it's going to be the guinea pig. I started this post quite a while back, I still haven't seen any torsion bars offered to make this "Total" vehicle system offering complete? Any updates? No real updates. The 68 is about 90% complete. It's been too hot to work on it so it's a little at a time. My last day at work was this past Friday so I'm officially retired. Now it's packing boxes for the move to Mesa.
Abe Lincoln
#1883554
08/02/15 02:57 PM
08/02/15 02:57 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I have some of the parts of the TVS on my car and I live in Metro Detroit where there probably are the worst roads in the entire nation.
I have: -Hotchkis UCAs -Hotchkis F&R sway bars -Poly LCA Bushings -RMS Strut Rods (Hotchkis ones are close enough so I doubt it makes a difference for handling) -Hotchkis Subframe connectors -Hotchkis/Fox Racing Non-Adjustable Shocks -Firm Feel 1.06 Torsion bars -ESPO 6 leaf "340" Springs at stock ride height, offset shackles -Borgenson "first design" steering box -Currently 225-60-15 BFG G-Force Sports -1.5 deg camber/ 3 deg caster (will add more caster in the future)
I have to say that unless you're on a really, really rough road it rides better with this setup than the more OE stuff I had before. It corners extremely flat, and feels very balanced, like a totally different car. I'm not sure I'd go over the 1.06 torsion bars unless you're only autocrossing or road racing. I keep my rear bar in the middle setting for now, probably the most neutral for the street.
I do not have the rod end steering links or the rear springs so I can't comment on those. I do experience some minor bump-steer, but not terrible, and I haven't had any decel wheelhop or anything with the rear springs (poly bushings), so I'm quite unsure how much performance would be gained there.
I have a set of 275-35-18 tires for it but just need to get the wheels modified and I'll be set to go there.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: autoxcuda]
#1891341
08/13/15 09:54 PM
08/13/15 09:54 PM
Posts: 506 Utah, USA
1964superstock
Utah, USA
Do 62-65 B's take two unique spring front and rear segment lenght combinations? Here is a handy little chart from Mancini Racing with all the leaf spring dimensions. also a link for AR Engineering is attached for all new front hangers available. The leaf spring front section dimensions are shown for each style front hanger. http://arengineering.com/home-page/spring-hangers/Other differences for the frame connectors are the wheelbase changes in Dodges 116" for 1962, 119" for '63-'64, and 117" for '65. Plymouth stayed at 116 inches '62-'65.
