Re: Hooking a 4 speed car...what do I need? [Re: 68LAR] #1322505
10/21/12 11:18 AM
10/21/12 11:18 AM
sweden
sshemi Offline
sshemi  Offline
sweden
How do they feel on the street?
Also witch ones should i use at 3800lbs at the starting line?
Re: Hooking a 4 speed car...what do I need? [Re: sshemi] #1322506
10/21/12 06:28 PM
10/21/12 06:28 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
My car rides nice on the street. When I race I set my Rancho's on the "9" setting. On the street I set them on 2 or 3 to soften the ride a bit.
No sure what to tell you or suggest with your second question. The 002 & 003 springs are rated at 3000#-3200#. They lift the back end of my car up about 2". That's why I use the lowering blocks.
3800# HD springs actually drop the back end down. My friend uses them on his "65 "B" body.
Personal preference, I guess.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Hooking a 4 speed car...what do I need? [Re: 68LAR] #1322507
10/21/12 06:38 PM
10/21/12 06:38 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
I have 3800# springs on mine and it sits nice I think,here's a pic in street trim
Gus
64 Plymouth Savoy
Dana 60
Re: Hooking a 4 speed car...what do I need? [Re: 68LAR] #1322508
10/21/12 09:23 PM
10/21/12 09:23 PM
Connecticut
5126brl No more Offline
Connecticut
I too have tried most of the combos listed. My current set up has "A" body SS springs(002-003). I run Rancho 9 ways set on 9. NO SNUBBER. I also run the Centerforce "11" clutch assembly. A833 18 spline. From personal experience, SOMETHING has to slip, unless you plan on breaking parts. My car is set up to slip the slicks about 10 feet at launch. Radials with a stick car don't work. I run Hoosers (29" x12"). My 60' times are around 1.54-1.60, depending on track conditions, but my car is a street car that I take to the track sometimes. It's not an all out race car. Also, my car weighs 3726 without me in it. With my 200+ pounds, it's a load to get moving. My rear gears are 4.56 Dana's. Hope this helps you get pointed in the right direction.
Must say I love the look of this car
What rpm do you leave at and what is the Rpm at the stripe?
Re: Hooking a 4 speed car...what do I need? [Re: 5126brl No more] #1322509
10/22/12 12:26 AM
10/22/12 12:26 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
My car isn't really that much of a serious racer.
I have to make accommodations to keep it streetable. The 3.54's have to stay because I can't afford overdrive at the moment. I'd like to drive it 50 miles a day to work when the weather is nice, have stupid power on the street(easy 600rwhp on low boost and up to 800rwhp on high boost) and not break much along the way.
The controlled bog idea sounds to be the best thus far. I don't have a problem running ET Streets at the track and my radials whenever I'm driving around. I want to keep my ride height low, so the superstock springs are out of the question. I'm already running 2" lowering blocks to keep the stock springs where I want them. I'll have to work to keep the XHD springs where I want them for sure. I'm going to keep the Koni's.
Whatever it does with the components listed above, it does. I just have to hope it's about 1.60-1.70 to make me feel like its not all in vain.
This post has taught me a lot
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Hooking a 4 speed car...what do I need? [Re: 5126brl No more] #1322510
10/22/12 02:56 PM
10/22/12 02:56 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Thanks. I leave anywhere from 4600 -5600. Last week at T&T I was leaving at 4600 and pulling 1.54 short times. I have my shift lite set at 6000. I trap at around 6400.
I like the way yours sits, Gus. I actually have two friends that run the 3800hp springs and they both set way lower than mine does.
Re: Hooking a 4 speed car...what do I need? [Re: AlexP] #1322511
10/22/12 03:02 PM
10/22/12 03:02 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I'm trying to decide what suspension to complete out the rear of my car with.
Some thing that I just remembered about the rear suspension and a stick car. No matter which spring you end up using, try to get the front spring segment as close to parallel to the ground as possible.
