Re: Finally hit the 10's with the Charger
[Re: mshred]
#1322119
10/18/12 06:15 PM
10/18/12 06:15 PM
Posts: 8,191 Plymouth, MI
Blusmbl
Plymouth, MI
Absolutely awesome car, without a doubt the best B-body ever. I bet you were happier than a pig in poop after getting that 10.97 timeslip!!!
As mshred said, the high rpm shifting problem for 2nd and 3rd gear on the TKO's seems to be common. A few trans places have kits to fix it, some involve faceplating conversions but then it kinda sucks to drive on the street. It's also worth rechecking parallelism & runout on the bellhousing, and the air gap on the clutch.
One of our work cars was a generic Mustang with a 600-ish hp 427 SBF in it, in front of a TKO-600. It was notchy but powershifted like a champ. I think it had been sent to Liberty once to be modified, though.
[Re: Chargerfan68]
#1322121
10/18/12 11:15 PM
10/18/12 11:15 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
congratulations, you done good. what are your shift rpms? I never had luck shifting above 6500 with the TKO and it was hit or miss at 6000. ![](/ubbthreads/images/graemlins/drive.gif)
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: oldiron]
#1322122
10/19/12 12:09 AM
10/19/12 12:09 AM
Posts: 1,265 New York, USA
Chargerfan68
New York, USA
Thanks everyone....I am glad that it is not me with the shifting issue. Most times, it feels like I hit a wall trying to go into the 3rd gate. Just won't go in at all at 6700 . If I slow the shift up some (dropping the rpms) it will go in, but that is killing my et. I will be contacting Liberty for the upgrade parts to install. Overall, I am real happy with the performance of this motor and proud of it. Thanks again. I will be attaching the album of the outing with pics and vids for those who asked for more pics. Greg. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: mshred]
#1322126
10/19/12 02:51 AM
10/19/12 02:51 AM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Very nice car and excellent performance! That Charger is sweet man. ![](/ubbthreads/images/graemlins/thumbs.gif) Wes
"Any fool can know. The point is to understand"
- A. Einstein
[Re: 383man]
#1322128
10/19/12 11:42 AM
10/19/12 11:42 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Congrats....awesome car and great working combo. ![](/ubbthreads/images/graemlins/thumbs.gif) That 60' is impressive for the weight ![](/ubbthreads/images/graemlins/bow.gif) I have a 68 Charger that just recently squeaked into the 10's (10.99) with a 1.55 60' but i'm also 150lbs heavier @ 4200 raceweight. ![](/ubbthreads/images/graemlins/tongue.gif) Mine ran a 10.99@ 121.5mph and recently has gone as fast as 124 but traction has now become an issue. Might be time to consider some slicks and weight reduction. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Once the trans issues are worked out your's should go mid 10's i would think with that MPH ![](/ubbthreads/images/graemlins/beer.gif) Ron
[Re: firefighter3931]
#1322129
10/19/12 08:26 PM
10/19/12 08:26 PM
Chargerfan68
New York, USA
Congrats....awesome car and great working combo. That 60' is impressive for the weight ![](/ubbthreads/images/graemlins/bow.gif)
Ron
Ron, Your Charger is GREAT looking. Wow!! My Charger runs as good as it does thanks to you! I used a Camshaft recomendation that you gave to someone on another board that I kept in my notes. After looking around and listening to everyone talking about cams for a stroker motor, I ended up using a recommendationt that you made for a 512 motor with slightly higher compression 11.5.
Mine is 10.4 , so I modified my LSA to 110 from 114 (I think you spec. for his engine).
If you recall, they were the 7071 and 7073 lobes from Comp solid XX family. I couldn't be happier with the performance.
So, Thank you for your wisdom...I always pay alot of attention to what you say on any post that I see you made.
'Respectfully, Greg.
[Re: RobX4406]
#1322135
10/22/12 12:57 AM
10/22/12 12:57 AM
Chargerfan68
New York, USA
Thanks very much. New question: the first 5 runs were made with the HP 950 Holley that was jetted up. I reached 10.98 @ 105.8 with that carb. I then switched to a new 1050 dom. 3 circuit jetted up and all 5 runs with this carb was between 105+ to 106.1 MPH. without any jet changes, it ran slightly faster than the tested/jetted 950. What is your guess to how much I can pick up with more testing/jetting up etc.. The plugs still looked very very light in color. I think it may have another 2MPH in it. What does your experiences say? Thanks. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Chargerfan68]
#1322136
10/22/12 08:16 AM
10/22/12 08:16 AM
firefighter3931
Ontario,Canada
Thanks for the kind words Greg ! ![](/ubbthreads/images/graemlins/thumbs.gif)
Yep, those XX Comp solid lobes work real nice ! ![](/ubbthreads/images/graemlins/wink.gif)
Luv those 68's and yours is a beauty ![](/ubbthreads/images/graemlins/bow.gif)
Ron
