Re: Much (any?) advantage to a higher rocker ratio here?
[Re: AndyF]
#1321825
10/18/12 10:23 PM
10/18/12 10:23 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
i have some 1.7 t&d,s on one of my motors. it,s only a street car. would it be worth it to change out the exhaust rockers to some 1.6,s? i know it would help with the springs and lifters, any other benefit? my cam is a solid roller: 272/276@.050 .609" can you buy just 8 rockers?
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: BradH]
#1321826
10/19/12 12:38 AM
10/19/12 12:38 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Brad: ... Dwayne: Brad: Dwayne: Brad: Dwayne:
Thats funny!! Glad its not just me!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#1321827
10/19/12 02:06 AM
10/19/12 02:06 AM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
Hey, I've had that same conversation with Dwayne.
I've got 1.7 t&d's on the victor max wedge heads on the coronet. 264/268 @ .050, .630 lift (about .700 with the 1.7's)
[Re: Old School]
#1321831
10/19/12 04:16 PM
10/19/12 04:16 PM
Posts: 52,972 Romeo MI
MR_P_BODY
thanks mr p body. if i change all of my exhaust rockers, i guess i would help reduce my valve spring and lifter failures by 50%...
Was your cam ordered for 1.5 specs...I have never seen bigger exhaust rockers help make ANY difference in HP
[Re: MR_P_BODY]
#1321832
10/19/12 05:47 PM
10/19/12 05:47 PM
Posts: 4,213 New York
polyspheric
New York
X2 - if it helps, the exhaust lobe was too mild.
Boffin Emeritus
[Re: MR_P_BODY]
#1321835
10/19/12 08:33 PM
10/19/12 08:33 PM
Old School
Virginia Beach, VA
they just give the specs on 1.5 and 1.6 ratio rockers.
