Page 2 of 3 1 2 3
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321749
10/17/12 03:17 PM
10/17/12 03:17 PM
TN
'84 D150 Shorty Offline OP
Pickup Man
Pickup Man
TN
And not to be forgotten, the main case all prettyfied:
Re: Project Rookie: A833 OD rebuild (Pics) [Re: JohnRR] #1321750
10/17/12 03:19 PM
10/17/12 03:19 PM
TN
Pickup Man
Pickup Man
TN
Looks good so far, post up a picture of the cluster gear pin .
Will do, and a pic of the reverse gear shaft is coming as well
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321751
10/17/12 05:10 PM
10/17/12 05:10 PM
TN
Pickup Man
Pickup Man
TN
Tonight when I get home I will take more pics of stuff...in the mean time, this is the 3rd/OD syncro assembly and the second speed gear removed from the main shaft assembly. To remove, I simply removed the snap ring and slid everything off the shaft.
As shown in the manual:
The parts (note:The clutch gear and shift struts and springs are still located in the clutch sleeve)
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321752
10/17/12 05:24 PM
10/17/12 05:24 PM
TN
Pickup Man
Pickup Man
TN
OK now here is question for the experts: The clutch gear (I think some call it the syncro inner drum?) Show signs of wear on one side and one face of the teeth (see pic). There is a slight step at the end of the wear point...can I use a file and deburr it, or is it a no-go?
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321753
10/17/12 05:26 PM
10/17/12 05:26 PM
TN
Pickup Man
Pickup Man
TN
Additional pics:
Shifter mount plate cleaned and painted:
And shifter stick redone:
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321754
10/17/12 07:01 PM
10/17/12 07:01 PM
TN
Pickup Man
Pickup Man
TN
Great big shout out to Wayne at Brewers Performance..got parts on the way..rebuild kit, bellhousing, inspection cover, and clutch fork. Brewers is awesome
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321755
10/17/12 09:13 PM
10/17/12 09:13 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
you could stone that down , that's in the OD position and what you can expect to find from running the factory fluid fill , where's that picture of your cluster gear pin , I hope you got a new one ?
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321756
10/17/12 11:00 PM
10/17/12 11:00 PM
TN
Pickup Man
Pickup Man
TN
So here is the countershaft...which looks to me to be in greatshape. One thing I've observed is that I've not seen the damage to the countershaft bores that I've heard about happening to aluminum main cases....which surprises me because I am NOT gentle on the throttle..
Here is the pile of rollers lol, and the spacer rings, and thrust washers:
And this is the spacer:
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321757
10/17/12 11:02 PM
10/17/12 11:02 PM
TN
Pickup Man
Pickup Man
TN
Reverse gear shaft:
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321758
10/17/12 11:05 PM
10/17/12 11:05 PM
TN
Pickup Man
Pickup Man
TN
Here is the reverse spring and ball I mentioned earlier:
The ball goes in here followed by the spring:
The spring sticks out and then seat in this hole on the side cover
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321759
10/17/12 11:27 PM
10/17/12 11:27 PM
TN
Pickup Man
Pickup Man
TN
Here are my speedo pinion parts cleaned up..mine is a 36 tooth
Inner seal removed awaiting its replacement:
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321760
10/17/12 11:28 PM
10/17/12 11:28 PM
TN
Pickup Man
Pickup Man
TN
Side cover cleaned up and painted
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321761
10/17/12 11:41 PM
10/17/12 11:41 PM
TN
Pickup Man
Pickup Man
TN
Bearing retainer cleaned and painted
OK...dummy rookie mistake, but I nicked the seal bore on the retainer..will that causes sealing problems?
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321762
10/17/12 11:46 PM
10/17/12 11:46 PM
JohnRR Offline
JohnRR  Offline
I can't really tell but I wouldn't call that great shape since you can clearly see the wear pattern of the rollers in it , the shaft isn't that expensive , do yourself a favor and change it now while it's apart. ATF does not have the viscosity of gear oil which you can see by the condition of the 3/4 syncro hub.
Re: Project Rookie: A833 OD rebuild (Pics) [Re: JohnRR] #1321763
10/17/12 11:58 PM
10/17/12 11:58 PM
TN
Pickup Man
Pickup Man
TN
Okie doke, I will order one in the morning!
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321764
10/18/12 04:30 AM
10/18/12 04:30 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Order new roll pins too since your changing out the shaft.
Re: Project Rookie: A833 OD rebuild (Pics) [Re: jbc426] #1321765
10/18/12 09:00 AM
10/18/12 09:00 AM
TN
Pickup Man
Pickup Man
TN
The kit I ordered includes the rollers, all the gaskets, thrust washers, spacer rings, input seal, output seal, yoke bushing, speedo pinion seals, and both main bearings
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321766
10/18/12 09:38 AM
10/18/12 09:38 AM
JohnRR Offline
JohnRR  Offline
Make sure there are no burrs on the shift levers in the side cover before pulling them all the way out to change the o-rings on the shift levers .
Re: Project Rookie: A833 OD rebuild (Pics) [Re: JohnRR] #1321767
10/18/12 12:23 PM
10/18/12 12:23 PM
TN
Pickup Man
Pickup Man
TN
Noted. I assume that is so the bores don't get scratched and cause a leak with the new seals?
Re: Project Rookie: A833 OD rebuild (Pics) [Re: '84 D150 Shorty] #1321768
10/18/12 01:02 PM
10/18/12 01:02 PM
JohnRR Offline
JohnRR  Offline
correct
Page 2 of 3 1 2 3
