Re: ET vs Weight
[Re: crazyjjk]
#1321689
10/17/12 09:45 AM
10/17/12 09:45 AM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
You cannot go by the old school 100lb is a tenth mess unless you have a 11 sec bracket car. In my small tire car running mid 8's in 1/4 100 lbs would slow it down about 3 numbers at most.
One day I will have something cool here.
Re: ET vs Weight
[Re: crazyjjk]
#1321690
10/17/12 10:25 AM
10/17/12 10:25 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Hypothetically if someone had a 4000 lb car and gave it a diet removing a total of 500 lbs how much would this lower ET per 100 lb loss of weight assuming everything else was the same?
only advice I can give you is this. I had a 67 coronet w/ a mild 440. It ran 12.90's, I lost the power steering, switched from heavy heavy cragars in the front to 14x5.5 rims and smaller lighter tires, removed the ac stuff and the car went....12.90. My 60 foot was a tad better but et and mph were pretty much the same. At that point the car weghed 3850 w/ me and 1/2 tank of gas.
Re: ET vs Weight
[Re: Mr.Yuck]
#1321691
10/17/12 11:01 AM
10/17/12 11:01 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Here is how I look at it. No matter what removing weight is always a smart move in a drag car to go faster but I think its is over inflated some times as how much et you will pick up up. All I have for info is in my old 340 Dart that I had in the very early 80's at the track one day I ran 12.15 on a time trail run. It was a Co-driver day where you could take a pass for a ride with proper seat belts. I put my 115 lb girlfriend in my 340 Dart which was a 4-speed and ran 12.16 with her in the car. So I only picked up .001 that day instead of the normally claimed .010. The car ran in the 12.12 to 12.17 range the rest of the day. So yes any weight lost helps but I would not bet the house on a tenth for 100 lbs every time. Ron
Re: ET vs Weight
[Re: crazyjjk]
#1321692
10/17/12 11:18 AM
10/17/12 11:18 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You have to stipulate a ET to start with... as the car gets light it takes more power to run .1 quicker... its on a bell curve... also the .1 for every 100# is on a sorted out car... just because some say they didnt go quicker doesnt mean anything, because they werent running a sorted out car... spend a few bucks and get a Moroso Power Speed Calculator 89650 and play with it to see what it should run ![](/ubbthreads/images/graemlins/wave.gif)
Re: ET vs Weight
[Re: MR_P_BODY]
#1321693
10/17/12 11:25 AM
10/17/12 11:25 AM
Posts: 3,505 DFW
mr_340
DFW
I use the formula: ET^3=200*Weight/HP It's not perfect, but is close for most bracket cars. ![](/ubbthreads/images/graemlins/Twocents.gif)
Floyd Lippencott IV
Re: ET vs Weight
[Re: mr_340]
#1321696
10/17/12 03:23 PM
10/17/12 03:23 PM
Posts: 16,934 NC
440Jim
NC
I use the formula:
ET^3=200*Weight/HP
Good for estimates.
4000 lb original weight 500 lb change Assume 13.00 at original weight
(ET2)^3 / (ET1)^3 = Weight2/Weight1 other numbers cancel (ET2)^3 = (13.00)^3 x 3500/4000 = 1922.375 ET2 = (1922.375)^0.3333 = 12.43
Re: ET vs Weight
[Re: crazyjjk]
#1321698
10/17/12 04:24 PM
10/17/12 04:24 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
66 belvedere vert jerico 3950 lbs w/me, 4.10 gears best 10.57 @129 relocated engine/trans to barracuda 3340 w/me, 4.56 gears best 9.95 @135
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: ET vs Weight
[Re: fullmetaljacket]
#1321699
10/17/12 05:45 PM
10/17/12 05:45 PM
Posts: 4,213 New York
polyspheric
New York
all of a sudden the car reacts amazingly to the weight loss just because you breached that tipping point
And the reason is...?
Boffin Emeritus
Re: ET vs Weight
[Re: polyspheric]
#1321700
10/17/12 05:52 PM
10/17/12 05:52 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
i do have to agree with full metaljacket. as i reduced weight,wheels tyres glass front bumper liteweight battery it seemed to do little with 20-30 odd lbs but when i got to around 60 plus lbs it became noticeable with et gain. in the last month i have reduced race weight by around 80-90 lbs i picked up around 0.06.
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: ET vs Weight
[Re: oldiron]
#1321701
10/17/12 06:07 PM
10/17/12 06:07 PM
Posts: 1,628 anywhere@ anytime
actionange
anywhere@ anytime
Maybe I need to get a Cuda too...LOL ![](/ubbthreads/images/graemlins/whistling.gif)
Re: ET vs Weight
[Re: actionange]
#1321702
10/17/12 06:13 PM
10/17/12 06:13 PM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
Ive taken weight out an really never seen anything.
Shawn Jennings
Re: ET vs Weight
[Re: 572_dup2]
#1321704
10/17/12 06:24 PM
10/17/12 06:24 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
My '67 Satellite with iron-headed 440, full interior, full exhaust, all steel, steel wheels weighs 3600 pounds.
Guy at the track I talk to has a '67 Belvedere with aluminum heads, gutted interior, open headers, fiberglass hood, fiberglass trunk lid, aluminum wheels weighs 3400 pounds.
So it seemed to me like a lot of money and bother for two tenths at best.
Re: ET vs Weight
[Re: 67Satty]
#1321705
10/17/12 06:27 PM
10/17/12 06:27 PM
Posts: 13,415 Marion, South Carolina [><]
an8sec70cuda
Way too many variables in that one. Different scales, different cars, not a good comparison any way you slice it.
Re: ET vs Weight
[Re: an8sec70cuda]
#1321706
10/17/12 07:03 PM
10/17/12 07:03 PM
67Satty
Vista, California
Well, the only variable is the scale. A '67 Satellite is the same car as a '67 Belvedere. A '67 Satellite, a '67 GTX, a '67 Belvedere, they are all '67 Belvederes, just different trim lines of a '67 Belvedere.
They guy with the '67 Belvedere with 'glass hood, trunk lid, gutted interior, etc...is the one who told me he thought it was a waste of effort for only a couple hundred pounds and I kind of agree from a best bang-for-your-buck point of view. If you add up the cost of a 'glass hood, 'glass trunk lid, aluminum wheels, it seems like there might be better ways to spend that same amount of money to get you more than a few tenths off your ET.
Re: ET vs Weight
[Re: 67Satty]
#1321707
10/17/12 07:47 PM
10/17/12 07:47 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I dont know how fast you car is but it might matter more to you, if you were an et chaser and your car was running 11.1. My car is going on a diet over xmas. LOL Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
