Re: Excessive crank case pressure frustration [Re: 64Post] #1320503
10/17/12 01:17 AM
10/17/12 01:17 AM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
I’ll ask again, if you take the car up to 4-5k rpm and let it coast down in gear do you get poor/good/very good engine breaking? Does your exhaust show any blue under engine breaking?
Sorry I forgot to address your question. Honestly, I only took the car down the road once because it needs an alignment and the brake rotors still had paint overspray on them (bad braking ability). From what I remember, it seemed to have good engine braking... normal, I'd say, based on the memories of driving the car before all this BS. As far as the "blue exhaust".... I don't know.
Don at FBO told me today that I can't run an evac systen on a street car due to the mufflers and back pressure that would cause the nasty gases to feed back into the motor/oil and it would just ruin the oil prematurely. I already had an order with Mancini because the tech there told me it would fix my problem. Don gave me some tips and will be working with me to address my problems if the leak down test shows no problems. I'll let you guys know.
BTW here's the car that is giving me hell.
Re: Excessive crank case pressure frustration [Re: PAINT IT BLACK] #1320504
10/17/12 01:26 AM
10/17/12 01:26 AM
Houston Texas
Houston Texas
This was a good day... wish I would have known there was a gremlin inside that orange box.
Re: Excessive crank case pressure frustration [Re: PAINT IT BLACK] #1320505
10/17/12 01:33 AM
10/17/12 01:33 AM
Houston Texas
Houston Texas
The motor from hell. I am going to light myself on fire if I have to break this motor down and repaint it AGAIN.
Re: Excessive crank case pressure frustration [Re: PAINT IT BLACK] #1320506
10/17/12 01:35 AM
10/17/12 01:35 AM
Houston Texas
Houston Texas
Who knows, maybe I'll get lucky and we'll find the problem before I get 3rd degree burns.
Re: Excessive crank case pressure frustration [Re: PAINT IT BLACK] #1320507
10/17/12 02:43 AM
10/17/12 02:43 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
and maybe not..
sorry, I had to do it..
I am truckless..
Re: Excessive crank case pressure frustration [Re: 340SHORTY] #1320508
10/17/12 04:35 AM
10/17/12 04:35 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
and maybe not..
Hey, All I'm sayin' is turn on the camera, never know what you'll see on You Tube...
Re: Excessive crank case pressure frustration [Re: 1_WILD_RT] #1320509
10/17/12 05:28 AM
10/17/12 05:28 AM
Houston Texas
Houston Texas
No joke, but during all this I accidentally shorted my ECU, and I found the spare I couldn't find before today. So after I made my last post (insomniac), I went out & swapped the bad one out. I cranked the car - had the hood open - and watched/ heard/ felt a big explosion. My timing is way off. The backfire bulged both mufflers & actually dropped one off the head pipes! Well, there goes a couple hundred bucks for new high flow AAR-T/A mufflers. I hope that's all it hurt. I'm going to set the timing from scratch again. I never had it dialed in before because of other lingering issues (tach hook up, throttle cable bracket//spring problems and a very leaky power steering pump). But the timing was pretty close... or so I thought. I have parts on the way and the tach & pump issues are fixed.
Hopefully this is just a timing related/ ignition system issue.... Or a bad dream..... Builder is coming over in a few days. I won't crank it again until I have some supervision. I'm learning though, so that is at least good, right?
Re: Excessive crank case pressure frustration [Re: PAINT IT BLACK] #1320510
10/17/12 08:55 AM
10/17/12 08:55 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Yes! Knowledge saves money and aggravation! Unfortunately, learning can be expensive and aggravating as you know. Sorry for your troubles, definitely a nightmare, but you're in good company. Many of us have been through it before...more times than I can remember...
..you'll get it figured out though
Re: Excessive crank case pressure frustration [Re: bobs66440] #1320511
10/17/12 11:33 AM
10/17/12 11:33 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i dont care how much hassle your havin THAT SWEET CAR IS WORTH IT
Re: Excessive crank case pressure frustration [Re: bonefish] #1320512
10/17/12 04:16 PM
10/17/12 04:16 PM
Houston Texas
Houston Texas
Thanks. It's the only thing keeping me going. The car is so close to being the 'ultimate' to me. Can't come cheap or easy.
Re: Excessive crank case pressure frustration [Re: PAINT IT BLACK] #1320513
10/17/12 04:26 PM
10/17/12 04:26 PM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
I'm glad your still working on it....even after it nearly killed you. It's just an engine. The hard work is done.
Re: Excessive crank case pressure frustration [Re: burdar] #1320514
10/18/12 12:04 AM
10/18/12 12:04 AM
Houston Texas
Houston Texas
ha... surprised you remember that. I think about it almost daily and its been a few years now. Lucky to be here.
