Re: What type of front seats are you using in your rod????? [Re: poorboy] #1319429
10/25/12 02:52 AM
10/25/12 02:52 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
A 40 should have plenty of room to put a nice set of bucket seats into, its the mid 30s and earlier that is too narrow. Gene
gene i agree, there is some thing out there that will fit a 40 dodge coupe with out touching,,as soon as other things on the fix list are done ill be on the hunt,, i bought the buckets out of my old ram with the guy i sold it too totaled it,,sorry to say they are too wide they touch each other i cant have that look,may as well keep a bench
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: What type of front seats are you using in your rod????? [Re: fstfish66] #1319430
10/26/12 02:10 AM
10/26/12 02:10 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I would think any seats out of a Dakota will fit, and I hear the center bench seat from Mini vans work well if you don't need access to the area behind the seat. Full size trucks and full size vans are pretty wide, C body cars would be too wide as well. I'd be tempted to measure some 5th Ave seats, and most of the front drive Mopars will have seats that should fit. Take a tape measure and head for a pull-a-part. Long as the windows are intact and the doors have been closed, seats usually are OK for several months lounging around in yards. Gene
Re: What type of front seats are you using in your rod????? [Re: poorboy] #1319431
10/26/12 11:02 AM
10/26/12 11:02 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
one seat i found was in a base trim level ramcharger---it was a low back-- split back bench seat in fabric---it was 1 inch narrower than a stock 64 plymouth seat---so i put it in my 64 and drove it for years---it had modern/firm foam/springs and it looked like it belonged....bob
Re: What type of front seats are you using in your rod????? [Re: savoy64] #1319432
10/27/12 12:31 AM
10/27/12 12:31 AM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
1998 nissan maxima Buckets going in the Fargo
