Bulb Type/Qty for 1971-1974 B-Body Ralley Gauge Cluster #1319405
10/12/12 11:12 AM
10/12/12 11:12 AM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Hey Guys,
I am anticipating my cluster coming back from Instrument Specialties soon and I want to go ahead a get bulbs for my harness so I am ready when my gauges arrive.
My cluster is from a 1973 Charger but I think its the same for all 71-74 B-body cars with the Ralley Gauges.
Can anybody here give me an accurate count of the type (i.e. GE type 57) bulb and the color? I think most of the bulbs were white but I need the colors they will show up as if I order LED bulbs (i.e. 2 greens for turn sign indicator, one blue for hi beams, etc).
I need to know if possible:
- all gauge cluster bulbs/colors
- seat belt warning light bulb type (72-74 only?)
- map light
- ashtray light
- glove light
- auto shifter indicator light
I know you can look this up but sometime information like this can be wrong. I don't want to piss away $10+/LED bulb from wrong information. Any guidance here is appreciated.
If anybody here knows this information, it would aid me greatly in orderign the proper bulbs the first time for my cluster!
Re: Bulb Type/Qty for 1971-1974 B-Body Ralley Gauge Cluster [Re: cjskotni] #1319406
10/13/12 10:54 AM
10/13/12 10:54 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
some bulbs were changed, like the seatbelt light on map light insert. will depend if you got metallic or plastic socket there. Plastic socket got wedge bulbs, and metallic socket got bayonet
Colors are all white and given by the lense on cluster assembly, but if you care:
-turning lights are green.
-warning lights are red.
-high beams light were red on earliers but turned blue in between 73 and 74 and lates.
-Brake light red
-All the rest of lights around are behind blue lenses.
-Glovebox is whithout color lense
a color bulb behind a color lense will dim out the light intensity
Re: Bulb Type/Qty for 1971-1974 B-Body Ralley Gauge Cluster [Re: NachoRT74] #1319407
10/13/12 09:17 PM
10/13/12 09:17 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Common sense is a flower that does not grow in everybody's garden
