Re: 904 torque convert problems [Re: Evil Spirit] #1318220
10/11/12 11:25 PM
10/11/12 11:25 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Thanks for all this information guys! I have searched high and low for this stuff and never found anything about the different pump gears mentioned, or the different updated hub. When I order the converter I will more than likely just go the A-500 hub route with the later pump gears, especially if they almost totally eliminate the broken hub issue that the standard style seems to have
A bit of advice - have a set of the flat drive style gears in your hands before you have the converter built for them. There have been times my supplier hasn't been able to get them - they were back/ordered.
will do! I plan on disassembling the entire trans first just to double check what it has, what it needs, what I thought it needed but doesn't need, etc. before ordering anything
Re: 904 torque convert problems [Re: mshred] #1318221
10/12/12 03:24 AM
10/12/12 03:24 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Anyone know where I can get the late convertor neck by mail order?
Re: 904 torque convert problems [Re: onig] #1318222
10/13/12 04:46 PM
10/13/12 04:46 PM
Canada
onig Offline OP
onig  Offline OP
Canada
Great info here.
Thanks guys.
Onig
69 Dart
