Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: fullmetaljacket] #1317061
10/10/12 02:39 PM
10/10/12 02:39 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
What do you guys think of using HP 340 exhaust manifolds with a 2-1/4 dual exhaust all the way to the back would do on bone stock 318 or 360?
http://www.moparmusclemagazine.com/techa...st/headers.html
the HP340 manifolds will do nearly squat....5th ave's have 360 sized exhaust manifolds, so in this article, ~1hp and 2 lb-ft on a mild 360...
and I am not sure if the HP340 manifolds will clear the huge brake booster on these cars.
magnum manifolds, you'd probably see the same miniscule power improvement, and when I was eyeballing the magnum manifolds on my '96 ram and the engine compartment on my 5th ave, I'm 99% sure they'd either hit the firewall, or potentially interfere with the shift linkage of the column shifter.
notel, the long tube headers only gained 16hp over 318 manifolds, and 5hp over 360 manifolds, but the torque gains were 20 and 16 lb ft. respectively
the duals replacing the stock 1 7/8" single will do more to add power and efficiency than the manifolds or headers
2017 Grand Cherokee Overland
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: patrick] #1317062
10/10/12 10:03 PM
10/10/12 10:03 PM
Lubbock, TX
E
Erics5th Offline
UsedtobeSatellite6
Erics5th  Offline
UsedtobeSatellite6
E
Lubbock, TX
I don't run headers, but I (actually the PO) did install a Y pipe from an Aspen R/T to a 2.5" pipe, Flowmaster (I know, I know) 44 muffler and 2.5" tail pipe.
Eric
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: 76dodgeboy] #1317063
10/10/12 11:34 PM
10/10/12 11:34 PM
Washington State, USA
W
Winchester 73 Offline
W
cant believe no ones jumped on this one-gas milage is as much about not throwing power in the trash as it is about making it efficiantly in the motor,but most forget that
electric fan
smaller crank pulley
manual steering
drop lbs(theres 500 lbs of junk hiding in that car)
hot air to the carb will net better miles WHEN TUNED FOR IT
headers dont help alot but getting rid of the 3 cat conv and the drinking straw exhaust that comes with those cars will!( i think magnum manifolds will fit!)
light 16" rims /low profile low resistance tires
synthetic oils/greeses/tranny fluid
new wheel bearings
alighnment
remember gas miles is something not to thaught as 1 or two miles per gallon but a tenth or twentieth of a mile per gallon compuonded over a year of driving!
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: Winchester 73] #1317064
10/10/12 11:42 PM
10/10/12 11:42 PM
Iowa
76dodgeboy Offline OP
Iowa
The 16s would have to be Narrow. a 215/75 15 is my plan. I never thought of the fan with will be in the plans now. Wheres a good place to get the pullies at a reasonable price? I don't know that I want manual steering on it but will give it some thought..
Is 2.5" duels just as good as 3" single?
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: patrick] #1317065
10/10/12 11:50 PM
10/10/12 11:50 PM
W
W
i can say ive seen magnum manifolds on an e body but i think headers wouldent hurt mileage and would add fun factor to a commuter.
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: Winchester 73] #1317066
10/11/12 12:25 AM
10/11/12 12:25 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
In all honesty, I would get another car. My F150 posted better mixed numbers than these things put out. Don't get me wrong, I love mine, but they're just not mileage makers.
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: Winchester 73] #1317067
10/11/12 12:40 AM
10/11/12 12:40 AM
fullmetaljacket Offline
Which manual steering box fits the 80's Diplomats and Fury's?
What about the Magnum exhaust manifolds, do they fit the 80's Diplomats and Fury's with out trouble as well.
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: MarkZ] #1317068
10/11/12 03:14 AM
10/11/12 03:14 AM
Iowa
Iowa
If your going to buy me another car that's better on gas and won't crumpled like a pop can in a collision Id like a Magnum wagon or a New Durango.
18-24mpg is perfectly fine with me. My 84 Toyota pickup with a 22r and 5spd gets around 20mpg. I got the car cause Im not putting a baby in the Toyota. 5th aves and dippys do Extremely well in demos.
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: fullmetaljacket] #1317069
10/11/12 03:23 AM
10/11/12 03:23 AM
W
W
a body or b body or f body manual box will work but will need a steering collumn adapter or the correct column from a manual car or lenghten your steering column (welding)i would bet magnum manifolds fit becus the motors sit very far fwd from the firewall in these cars.
ive gotten rediculouse gas mileage from slant six f body wagons before,it cant be too hard w/a 318.
is yours a roller cam motor?
what rear?
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: Winchester 73] #1317070
10/11/12 08:25 AM
10/11/12 08:25 AM
2.25 rear. 318 engine.
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: 76dodgeboy] #1317071
10/11/12 02:15 PM
10/11/12 02:15 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
cross sectional area of a 3" single is about the same as dual 2 1/4" pipe. one advantage of a 3" single over a 2.5" dual is only having 60% of the steel in the pipe, so it'll be lighter.
another thing with magnum manifolds, IIRC they interfere with the PS box.
one thing that may help town mileage and fun factor would be a higher stall converter (like a high stall slant6 converter)
what would work real well would be 2.94-3.23 gears and an A833OD. the horrible town mileage is due to trying to get 3800-4000 lbs moving with a 2.24 rear end.
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: MarkZ] #1317072
10/11/12 02:18 PM
10/11/12 02:18 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
they're OK if they're biased towards highway. getting 2 tons moving with a 2.24 rear sucks the gas in stop and go. mine, in-town mileage was as good or better after all the mods that more than doubled HP with the 3.55's/A500. the 3 speed tranny is a big limitation. personally I think an A833OD (with it's 3.09 first, .73 OD) and 2.94-3.23 rear gears would drastically improve mileage in these beasts.
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: 76dodgeboy] #1317073
10/11/12 02:37 PM
10/11/12 02:37 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Don't compare demo derby durability with real-life car accidents, the dynamics of both the crash and the cars is drastically altered. If your babyseat is in teh center of the backseat almost any car above compact-size should be OK. The momentum of the vehicle hitting you is the biggest consideration, and a newer car will crush more at the edges and absorb that energy better than an older car. **My point - a 300M or mid-90s Buick Century/Regal, etc will give much better MPG and probably be safer.
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: Winchester 73] #1317074
10/11/12 03:39 PM
10/11/12 03:39 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I'll come back to this.
Modifying an old car as an MPG project, for the purpose of saving $$, requires some well-planned assumptions and then some calculations.
I have an AHB Dippy that gets around 15-16 mpg mixed driving. I looked at putting in an A500 and assumed it would take me from 15.5 to 18.6 (a 20% increase) and cost $500 (a conservative amount, even if DIY). At 3.85/gal, it would take 12,077 miles to pay itself off. Not bad.
But...
Be aware that the higher your starting MPG, the longer the same mpg increase takes to pay off. Let's take the same $500 and $3.85, going from 15 to 20 mpg has a 7800 mi payoff. That's low-hanging fruit, and would be worthwile. To take the same 5mpg increase, but from 20 to 25, has a 13,000 mile payoff. To get the same 7800-mile payoff requires going from 20mpg to 30!!!
And the higher your base mpg, the more expensive/less return for your modifications.
To be realistic, let's say we can find 3 more MPG (I think planning/expecting to get more than 23 mpg mixed from a boxy M is unrealistic). Going from 20-23 (a more difficult phase of the project) at the same cost/gas price has a 19,900 mile payoff. (and after the OD, I don't think there's another 3 mpg to be had for only $500, so that 19,900 is suspect).
Oh, and going from 15 to 15.1, if you did that for just $50, it would take 29,400 miles for payoff. From 20 to 20.1 takes 52,200 miles.
All food for thought.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: Fury Fan] #1317075
10/11/12 05:36 PM
10/11/12 05:36 PM
Iowa
Iowa
I've 35000 moles on my Toyota in just over a yr. Anything we do is 30miles away so Its being built more for highway. 30 miles to town 98% interstate. My work is maybe a mile off the interstate. Ill drive my Toyota when I don't have the baby.
As for comparing to demo cars it depends on the class you refer to. Chained class is pretty much what's driven on the street. Only reinforcing is drivers door. A newer car cost too much to purchase and to repare. With this era of car I can carry a spare fuel pump or thermostat etc and have it fixed in no time. New crap you gotta drop the tank and spend over $100 for a fuel pump.
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: 76dodgeboy] #2793554
07/06/20 05:51 PM
07/06/20 05:51 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
If you are looking for mileage in a 4bbl upgrade your search should begin and end with a thermoquad. Stock 4bbl intake is fine, or Eddy performer. If it is just about mileage though, if the lean burn is working leave it be. Get rid of the factory exhaust, it is one of the worst (most restrictive) I have seen. New y pipe with 2.5 single run out the back will be more than enough for stock configuration 318.
Re: Headers for a 5th Ave? 360 2bbl or 4bbl for 318 [Re: mgoblue9798] #2793589
07/06/20 06:56 PM
07/06/20 06:56 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You realize the last post in this thread before yours was almost 8 years ago?
