Re: 572 hemi won't start and run
[Re: Big Squeeze]
#1316666
10/07/12 09:03 PM
10/07/12 09:03 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
its an msd system it only hooks one way and i bought everything new
That doesn't mean it's right...
The ones who assemble those units don't speak english.. ![](/ubbthreads/images/graemlins/shruggy.gif)
Wouldn't be the first time they were wired wrong..
Chris.. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 68528hemi]
#1316667
10/07/12 09:06 PM
10/07/12 09:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you set the crank(damper) at 34* on the compression stroke and drop in the dist pointed at #1 it'll start... if you set the crank at 0 and install the dist its ZERO timing and you end up turning it to 34 or there abouts if its a locked dist.... if it has advance set it at 20* then drop in the dist ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1316669
10/07/12 09:17 PM
10/07/12 09:17 PM
Posts: 25 California
Mad Dart
California
Listen to this advice and I bet it fires right off!
[Re: MR_P_BODY]
#1316670
10/07/12 09:22 PM
10/07/12 09:22 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: 68528hemi]
#1316672
10/07/12 11:19 PM
10/07/12 11:19 PM
MR_P_BODY
you do mean 34* before tdc. my msd distributor is a mechanical advanced.
For your mech advance dist set the crank at 20* before TDC ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1316679
10/08/12 02:10 AM
10/08/12 02:10 AM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
I am going to relate a story and I doubt this is your problem but something to check... This one time late at night thrashing to get a 440 started I installed the wires on the cap in the correct firing order...clockwise. After many swapped parts and much head scratching my partner in the project ( the missus ![](/ubbthreads/images/graemlins/hammer.gif) ) was reading the factory service manual and pointed out that a big block distributor turns counter clockwise. ![](/ubbthreads/images/graemlins/pity.gif) Just a thought that I can't seem to get out of my head for some reason. ![](/ubbthreads/images/graemlins/laugh2.gif)
