Re: backfire only out drivers side exhuast [Re: RapidRobert] #1315357
10/06/12 10:42 PM
10/06/12 10:42 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
Those plugs are shot. throw in a new set & see if it straightens out. Is that wet oil or dry carbon?
it was a mix of each. they cleaned up okay so i reused them. im going to put new ones in once i get my first check
Re: backfire only out drivers side exhuast [Re: 72d100] #1315358
10/06/12 10:53 PM
10/06/12 10:53 PM
i did notice some up in down play in the distributor, not sure if that's normal or not?
Most have alot of lower shaft axial play which is too much. Can drive out the roll pin, slide off the plastic collar and add 1/2" ID shims/washers to reduce it to .005" If using washers check/slightly bevel the sharp edged side on them.
Re: backfire only out drivers side exhuast [Re: RapidRobert] #1315359
10/06/12 11:09 PM
10/06/12 11:09 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
if you guys can bear my ugliness i did get a video of it running. what do you guys think? youtube
Re: backfire only out drivers side exhuast [Re: 72d100] #1315360
10/07/12 12:44 PM
10/07/12 12:44 PM
Tulsa, Oklahoma
Wagonmaster Offline
Wagonmaster  Offline
Tulsa, Oklahoma
I'm probably going to get flamed for this, but, IMHO, get rid of the Champions. I've run Autolite copper plugs in my MOPARS since my first one, back in 1969. No issues with them, ever.
For your application, plug number 85. $1.60 at your friendly Autozone.
Re: backfire only out drivers side exhuast [Re: Wagonmaster] #1315361
10/07/12 12:53 PM
10/07/12 12:53 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
I've used 85s for over 25 yrs, but that carb looks to be
fouling the plugs..fix that first. May be float level or rich
idle mixture.
Re: backfire only out drivers side exhuast [Re: Dan Halen] #1315362
10/07/12 02:55 PM
10/07/12 02:55 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
plugs look badly oil fouled, take a close look at intake manifold sealing. You could take the carb off and you may be able to detect oil in the plenum.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
