Re: PRW Roller Rockers any good [Re: BulletBob] #1313246
10/02/12 08:58 AM
10/02/12 08:58 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Even when we bicker there's info for everybody
It's the Moparts way sometimes
It's not officially bickering until there's a double or triple quote followed by a interesting rebuttal
Any bushed rocker requires a hardened shaft with banana grooves & hardened or chroe moly pushrods
I'm running prw stainless rockers on my LA smallblock. I had an adjuster come loose two different times. A little loctite fixed it for the past year or so.
I understand why needle bearings want a hardened shaft. Why would a bronze bushed surface need a harder shaft than stock? Unlike a hardened bearing the bushing is softer than steel and has more surface area than stock. Also, I have hardened pushrods for insurance against rubbing but why would an adjuster wear the pushrod faster than stock steel on steel? It does get oiled, right?
I went with prw because I saw durability in the bushed stainless and coming to mopars from building mostly harley shovel motors (very bad pushrod geometry) the common wisdom with them is to go to a roller tip rocker at .5+" lift to avoid side loading the valve.
Also and this is a big one- I can change cams and adjust the rockers to get the right lash (or preload).
Re: PRW Roller Rockers any good [Re: radar] #1313247
10/02/12 12:02 PM
10/02/12 12:02 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I'm using SS PRWs since Jan, daily driver car, and I haven't advertised anything bad.
I was scared about them because have known the CAT rockers getting premature failures on bushings. These PRWs looks EXACTLY the same pieces than CATs... maybe same casting but diff assembly and pieces quality ? dunno.
note is A DRIVER and I travel around the country ( I have driven 10 continues hours twice last month on a small vacation trip )
lifters have failed twice before the rockers. Today will be installing my new HLJ lifters and can check for any weird play on rockers bushings if you care
Re: PRW Roller Rockers any good [Re: NachoRT74] #1313248
10/02/12 03:14 PM
10/02/12 03:14 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
My report:
I could feel some rocker play, so removed some of them... conclusion: rocker bushings are begining to fail BUT, not everyone, just front ones ( pistons 1 and 2 ). I can notice burnt oil layer around, everything dark there. Including on bushing top area and rocker
Some oiling failure ?
dunno, but I have allways got oil gauge between half and top reading, never less than that, which is better than any average reading. I got half gauge reading just when got lifters failure, but the rest of the new engine life gauge has got 2/3 and top readings.
Re: PRW Roller Rockers any good [Re: NachoRT74] #1313249
10/02/12 05:21 PM
10/02/12 05:21 PM
dogdays Offline
dogdays  Offline
So W7's reporterd valve lifts work out to:
.480 / .344 = 1.395 True ratio stock rocker, paper ratio 1.5
.512 / .344 = 1.488 True ratio with the 1.6 paper ratio rocker
Here's where the LA lifter orientation bites us. The lifter doesn't point at the rocker end, and the result is you get less lift than you think you should. The factor is the cosine of the included angle.
I remember a few years ago RobbMcC was a board member and he asked the question should he make his design for the new Erson rockers for LA be the ratio of just the rocker, paper ratio, or should he make the ratio larger than advertised to take into account the weird geometry. He had to go past 1.65 to get a 1.6 ratio between valve lift and lobe lift.
One thing that the stamped rockers have over their sexier brothers is less rotating mass. The extra inertia of the beefier rockers requires more valvespring to maintain the same max rpm. This has been noted by Steve Dulcich and others, a set of stainless roller rockers subtracted about 500 rpm from the stock flimsy rockers' redline.
So what we need is a 1.65 paper ratio stamped rocker with the top over the shaft closed in to give the rocker some more stiffness with little added moment of inertia.
R.
Re: PRW Roller Rockers any good [Re: dogdays] #1313250
10/02/12 07:12 PM
10/02/12 07:12 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Some great info here........Thanks!
I'm currently pricing around for a set of budget adjustable rockers for a big block Mopar. Don't really want overseas built stuff that has bad metallurgy (see it enough in the airsoft guns my sons buy). And have had enough cheap bearings fall apart from lawn equipment.
The bronze bushings, at the fulcrum, with a single large roller at the tip, seem like a good fit for my needs and with good oiling should last a long time.
Nobody has mentioned yet...........the trouble with non-adjustable rockers is what to do with a new combo that has had block decking, head milling, several valvejobs and the 509 MP has a smaller basecircle too.
Did someone say the Harlen Sharp adjusters fit the PRW's??? An American made replacement part???
Re: PRW Roller Rockers any good [Re: Dean_Kuzluzski] #1313251
10/02/12 11:50 PM
10/02/12 11:50 PM
Amherst,NY
challengermike Offline
Amherst,NY
Yep that was me. I didnt have problems with them the first 500 miles which included many passes at the strip. HS was the only company i could find that sold 7/16 cup end adjusters. I wasnt going to order another set of prws. Also someone posted above about them looking like CAT rockers, Well my set when i got them had a faint stamp on the bottom of the cat symbol. So im pretty sure they are the same rockers. Im not bashing them in any way, i like mine just want to put the word out there what is good or bad about them.
Re: PRW Roller Rockers any good [Re: challengermike] #1313252
10/03/12 12:13 AM
10/03/12 12:13 AM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Mine look more polished compared to the other pics...
I bought a set because I have a small base circle cam that left the
rockers @ zero lash with no preload. I went with 1.6s because they
were the same $ and I have pistons with decent valve reliefs.
So far so good...knock on wood.
One caveot with aftermarket rockers not addressed so far.....
These have to be shimmed one cylinder at a time to center the roller
over the valve tip...very tedious and way more difficult if the motor
is already installed.
