Re: Edelbrock Carb Heat Soak Issue.
[Re: TimS]
#1311873
10/07/12 09:56 AM
10/07/12 09:56 AM
Posts: 5,446 Indiana
YO7_A66
Indiana
""We are not talking those POS cool carb spacers."" ""But If you having trouble with this, then I change the manifold to something without a heat riser or block yours before going any farther."" That is good advice for both the Edy-9266,the Cool Carb members, and anyone trying to drive on todays crapty gas blend.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: TimS]
#1311876
10/08/12 06:37 PM
10/08/12 06:37 PM
Posts: 101 South Carolina
warpspeed
South Carolina
Wow! I cant believe I am doing this again. When there is a "vapor lock" does that mean that the carb won't allow any more fuel into the carb? If that is the case, just how do you fix it? I have a 318 engine, with an edelbrock carb, a dual plane intake, a circulating fuel system from the filter just down stream from the mechanical pump, a clear filter at the carb, (just to make sure I can tell whether the fuel is moving), and the fuel lines are away from any heat sink. The carb isn't that hot, that is too hot to touch. There is the 1/2" gasket you mention to insulate it from the manifold, (yes it really is hot). But, we ran with the car for over a year without any problems before even insulating the carb from the manifold.
Noticed the coil, a new one, is really hot. Is that normal?
Noticed that the fuel was slowly getting less and less in the clear filter bowl. Especially as I would test the acceleration pump. This pump was squirting lightly but not putting out much fuel. Yeah, I get it may be lean. I will fix that. When it quit, it was 1/4 mile from the house. I left it in a parking lot while I worked on it. Changed out the fuel pump, didn't help. Then eight hours later, I went back by and it started up so I could drive it the rest of the way home. But it was completely cooled off.
This is getting really frustrating! I know the carb is the culprit and I am getting really mad at it, but, I just feel that it will run fine if I can just get this problem eliminated. Just need to see if the vapor lock is the problem and how to stop it. It just didn't seem to be a really heat problem.
[Re: warpspeed]
#1311879
10/09/12 11:14 AM
10/09/12 11:14 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Since most complain about the Eddy and it's problems which I never had,why not get a good used AVS or AFB that suits your needs,rework it and be done ? There are enough for just about any application. Carb._________Venturi dia._________Bore dia. CFM__________Pri.____Sec._______Pri._____Sec. 750 ................1 7/16.....1 9/16 ......1 11/16....1 11/16 625.................1 3/16.....1 9/16.......1 7/16......1 11/16 575.................1 1/4.......1 9/16.......1 9/16......1 11/16 500.................1 3/16.....1 1/4.........1 7/16 .....1 11/16 400 ................1 1/8.......1 1/4.........1 7/16......1 7/16
[Re: YO7_A66]
#1311881
10/09/12 02:11 PM
10/09/12 02:11 PM
Challenger 1
Cincinnati, Ohio
My
If you use a manifold without a heat riser or have them blocked, then you really don't need a carb spacer to keep the carb cool. So that's why I think so poorly of the cool carb things, because they only can be used on a cool engine. What good is that??
As you know I have a very good running 340 with a victor340 manifold with no heat risers with my 1405 eddie carb sitting right on the manifold with only a gasket.
And my car runs great even in 110 degree temps in Vegas and in 100 degree heat that we had here this summer. It has idled for over a 1/2 hour on a 100 degree day just recently with no issues and it starts with a flick of the key.
Like I said in the past, I thinks it's the dumbest thing in the world to use aluminum to isolate heat. I want to be on record saying this.
Get your tuneup in order and enjoy your cars without overheating like I do almost everyday.
[Re: lilcuda]
#1311882
10/09/12 02:49 PM
10/09/12 02:49 PM
Challenger 1
Cincinnati, Ohio
I cured all of my Edelbrock 1406 issues by unbolting it and installing a Holley 650 DP. Problems solved. Sold the Edelbrock to a friend and never looked back.
I'm sure you learned nothing!! way to go!!
[Re: TimS]
#1311884
10/10/12 09:40 AM
10/10/12 09:40 AM
warpspeed
South Carolina
I bought a phenolic (1/2") spacer for a few bucks off ebay. It was here really fast. Look it up, it wasn't expensive. Speaking of which, I started to take the carb off the engine last night to replace the Edelbrock spacer with this thicker spacer and found the nuts on the carb loose. The back left one was so loose, it was moving up and down from the vibration from the motor. I replaced the spacers and started it up. Didn't hear or feel any difference, but, I assure you I can't help but think this is the reason for the last issues. Last Saturday, the car ran fine for hour or so, stopping and starting here and there until I was coming back to the warehouse. Don't understand why it would restart and run well enough to drive it back to the warehouse, 1/4 mile away, but, THIS has to be the reason why I was having the last problem. Anyway, the spacer is there, fuel lines have been routed around all hot spots, the carb is tuned and I am going for a run to see if this stops the shut downs.
[Re: warpspeed]
#1311885
10/10/12 10:39 AM
10/10/12 10:39 AM
RapidRobert
I would have tightened the nuts as is to see if that was it but yes holler if it's all good now
