Page 2 of 3 1 2 3
Re: Edelbrock Carb Heat Soak Issue. [Re: Supercuda] #1311853
09/29/12 07:59 AM
09/29/12 07:59 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I traded all of my Edelbrock 1406 problems for Holley 650 DP problems.
There you go.
Hardly. I've had ZERO problems with my Holley. Why? I run two fuel filters. I fought and fought and fought to avoid swapping to a Holley. My former co-worker kept telling me to do it. When I finally did, I gained a TON of throttle response, gobs of torque and HP which translated into .22 and 4 MPH in the 1/4 mile with no other changes.
Your next thought is probably going to be "Yeah, but you lost mileage." Nope. Gets the same exact mileage.
I've since gotten a friend to swap out his Carter for a Holley on his 340. It's like a different car. He loves the power.
Also, the old wives tale about the power valve blowing out only applies to ancient Holleys. All new ones have check valves that prevent that.
I been running Edelbrocks for years, my 750 since 1988. The 600 since 97, zero problems and I bet it get's way hotter here, zero heat soak issues. If you are having a loss of power you ain't tuning it right. In one of the recent Car Craft's they had a big shoot out comparing carbs, the information is interesting, read it.
So, making a long story short, what were the shoot out results from Car Craft?
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Edelbrock Carb Heat Soak Issue. [Re: TimS] #1311854
09/29/12 10:40 AM
09/29/12 10:40 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not much of a difference between the carbs once they did a basic tune (jets and maybe power valves). Out of the box there was a larger variance. The edelbrocks were leaner at cruise than the Holleys, but booster design varied the Holley's. So many variables that could be tweaked with a more serious tune (air bleeds, booster types, etc). Basically, it boiled down to this, not enough difference to make a recommendation based on the observed data.
http://www.carcraft.com/techarticles/ccrp_1210_seven_budget_carburetors_tested/viewall.html
Don't be the exception.
Re: Edelbrock Carb Heat Soak Issue. [Re: lilcuda] #1311855
09/29/12 10:55 AM
09/29/12 10:55 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
The edlebrock wasn't tuned properly if it was the same CFM rating .
Re: Edelbrock Carb Heat Soak Issue. [Re: JohnRR] #1311856
09/29/12 12:59 PM
09/29/12 12:59 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I had small problem of fuel boiling in my carb and sometimes after a very hot start it would flood and I would have to keep the pedal on the floor to get it started and then get moving to cool it down some. Its because of the cheap pump gas fuel that they added more ethanal to this year as I have never had this problem until this year and I have run this same basic fuel system for years. Oh and my carb is an 850 DP. I already had a 1/2" phenolic spacer so I added a heat shield below the carb and actually put a cool can back on the car. I only use it it very hot humid weather but I will throw an ice pack in the cool can when I cruise on them very hot days and I have not had the problem at all anymore. And my eng never overheats as it will get up to 190 to 200 tops on even the most brutal hot days. Ron
Re: Edelbrock Carb Heat Soak Issue. [Re: Supercuda] #1311857
09/30/12 06:26 AM
09/30/12 06:26 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Thanks very much for this info. It proves as I suspected from my past experiences with both the Holley and Edelbrock carbs. There truely is very little difference out of the box and if you want to improve drivability or try to rate one over the other, tuning factors and replacing out of the box components comes in to play. Great article from Car Craft.
Re: Edelbrock Carb Heat Soak Issue. [Re: 383man] #1311858
09/30/12 06:39 AM
09/30/12 06:39 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Thanks Ron. I ordered a heat insulator from Jegs Friday so I'm going to try that first. I put an old .200 phenolic spacer that I had under the Carter and it helped so I'm hoping the .320 spacer kit will take care of it. I've got a Moroso .500 insulator but I'm a little leary about installing that and raising the carb up too high. I've got all that Ramcharger duct work and air cleaner. If the .320 insulator doesn't help, I may go head and block the crossovers. What seems odd to me is that the Edelbrock and Carter is basically the same carbs and I didn't really see this with my old Carter Comp on it.
Re: Edelbrock Carb Heat Soak Issue. [Re: TimS] #1311859
09/30/12 07:10 AM
09/30/12 07:10 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I bet you the reason the eddie carb run hotter and boils the fuel is because it's leaner than your old carter.
The 1406 is lean from the factory, use the jetting chart from the 1405 and richen it up.
Been tuning the 1405 since the 90s and have changed mine and driven it all over the country from Key West and sea level to Pikes Pike at 14110'.
My manifold with no heat risers, I have driven this car in Reno and Vegas in July and Aug and to the top of Pikes Pike on a 95 degree day. That's huge, please go try it someday.
Re: Edelbrock Carb Heat Soak Issue. [Re: Challenger 1] #1311860
09/30/12 07:23 AM
09/30/12 07:23 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I'll try that. You happen to have the 1405 chart handy? That 1406 does seem a little doggie at part throttle. Probably the reason.
Re: Edelbrock Carb Heat Soak Issue. [Re: Challenger 1] #1311861
09/30/12 07:37 AM
09/30/12 07:37 AM
Cincinnati, Ohio
Cincinnati, Ohio
Checkout my pipes after running the car out in Wendover Nv and Bonniville Ut. It's 4400 feet out there and like 600 feet where I live. I have been to bonneville 3 times now and have always leaned it out to go there. We also go to Reno and drive in the Serria mountains going from Kings Beach to Truckee Ca between 6000-7000 feet.
I ran it over 100 mph for miles at a time which puts everything to a serious test just this past June. That's salt all over the car.
web page
web page
Re: Edelbrock Carb Heat Soak Issue. [Re: TimS] #1311862
09/30/12 07:58 AM
09/30/12 07:58 AM
Cincinnati, Ohio
Cincinnati, Ohio
Been looking for a better picture of the tunning chart for a 1405 and have not found one yet. I keep looking or see if I can get a better picture if someone else don't post it.
Here's the car in San Francisco facing the Pacific ocean. It got a good salt spray from the ocean within a few hours, this RV park allowed you to use as much water as you want to wash your RV. Some people washed there stuff every morning.
If you look hard enough you can see Hawaii off to the left.
Then a day or so later were at 4400 feet, I change the carb all the time and don't leave it the same.
Like driving on the moon.
Re: Edelbrock Carb Heat Soak Issue. [Re: BDW] #1311863
09/30/12 08:40 AM
09/30/12 08:40 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Had same issue, this cured it.
http://www.summitracing.com/parts/EDL-9266/
I used this and it helped a bunch on my Thunder AVS.
I also have an electric fuel pump however, the spacer helped more with vapor locking with 91oct and very hot ambient temps.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Edelbrock Carb Heat Soak Issue. [Re: Challenger 1] #1311864
09/30/12 08:44 AM
09/30/12 08:44 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
The whole instruction manual including the chart is available on Edelbrock's website
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: Edelbrock Carb Heat Soak Issue. [Re: runinonmt] #1311865
09/30/12 09:18 AM
09/30/12 09:18 AM
Cincinnati, Ohio
Cincinnati, Ohio
Ron
web page
Re: Edelbrock Carb Heat Soak Issue. [Re: Challenger 1] #1311866
09/30/12 02:00 PM
09/30/12 02:00 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Ron
web page
Thanks!!
Re: Edelbrock Carb Heat Soak Issue. [Re: TimS] #1311867
09/30/12 02:46 PM
09/30/12 02:46 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
the internal spec of the Ebrock has to be different from the carter , the similarity is only on the surface . Don't get to carried away with spacers with your ductwork.
I can't understand why you haven't put the rebuilt carter back on , or would that be too easy ?
Re: Edelbrock Carb Heat Soak Issue. [Re: JohnRR] #1311868
09/30/12 05:42 PM
09/30/12 05:42 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Yep. Too much spacer and I could end up crunching that under hood duct work. Right now, I really don't know how much is too much spacer. I've got the stock intake on it that's low profile but I really need to calculate that especially if I start messing around with the .500 Moroso spacer that I have.
I haven't put the Carter back on cause I would really like to get this issue worked out. The Carter is on my 68 right now and would have to put that Edelbrock on that. Same issue is probably present. I sold the old 600 Holley I had on my 69 back when I was putting a new cam and lifter set in. I've ran Holleys off and on over the years and as I mentioned earlier they have their quirks too like leaking around the pump. Friend of mine was in need of a carb and wanted a Holley so I rebuilt that one and sold it to him. I expected to get the orginal AVS for the 69 going as well but I'm still toying with that thing.
Re: Edelbrock Carb Heat Soak Issue. [Re: BDW] #1311869
10/07/12 07:23 AM
10/07/12 07:23 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I got that 9266 spacer but when I saw it the material made me question if it would stand up to the stock manifold heat crossover. I should have read the instructions before buying it appears. It's not recommended for stock manifolds like mine. To use that, I'll need to block the crossovers.
Re: Edelbrock Carb Heat Soak Issue. [Re: TimS] #1311870
10/07/12 07:31 AM
10/07/12 07:31 AM
Cincinnati, Ohio
Cincinnati, Ohio
Where did you read this? I didn't see it. We are not talking those POS cool carb spacers. Nylon can handle ther heat.
Re: Edelbrock Carb Heat Soak Issue. [Re: Challenger 1] #1311871
10/07/12 07:57 AM
10/07/12 07:57 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
It's in the instructions for the 9266 spacer.
Re: Edelbrock Carb Heat Soak Issue. [Re: TimS] #1311872
10/07/12 08:06 AM
10/07/12 08:06 AM
Cincinnati, Ohio
Cincinnati, Ohio
Wow the listing says extreme under hood temps, That's kind of BS. Then just get a good ole old fashion phonelic spacer, they work fine.
But If you having trouble with this, then I change the manifold to something without a heat riser or block yours before going any farther. My
Page 2 of 3 1 2 3
