Re: 318 LA to 360 Magnum Swap [Re: Fury Fan] #1311431
09/30/12 03:23 PM
09/30/12 03:23 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
How does that cam snout extension fail if the bolt is torqued correctly?
I've used a few of them the first one I bought has almost 100k on it
I wondered that too. Combination of high RPM and higher-ouput fuel pump, maybe? And maybne not torqued properly so teh clamp force between button & cam was low, causing the little key to carry more load?
I've got a friend that has used his extension for almost 5 racing seasons using my Carter (made for NASCAR) fuel pump & his motor stays between 4000-7000 RPM & it's never failed
Re: 318 LA to 360 Magnum Swap [Re: BulletBob] #1311432
10/01/12 02:46 PM
10/01/12 02:46 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline OP
Thanks for the input so far,
I'm hoping for input from those who have actually done such a swap and what they did to make it work.
Thanks again,
Mike.
Re: 318 LA to 360 Magnum Swap [Re: moparmike1] #1311433
10/02/12 03:22 AM
10/02/12 03:22 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I've done an A-Body & 5 1st Gen trucks with Mag engines
I can tell you exactly which fuel pump & line combo it takes to clear the correct Denso alt brackets I can post the pics of what you need to look for
I'm getting ready to Mag motor my 75' B-Body wagon
As far as the drivers side mount. Get one for a 340-360 & spend the Schumacher money somewhere else on your project
Put the Crosswinds intake on it & forget about it
Myron Pyotek? (A member here)can most likely enlighten you on hooking the 904 up to it & any balance questions
You can find him over in the racing section
Are you going to be using A/C?
