440 mega block #1310476
09/25/12 06:26 PM
09/25/12 06:26 PM
napa ca
P
procharged 484 Offline OP
P
napa ca
How do you figure out who made it or if its a good one? By casting year? 7C20 or number? 2468330-m It's new so hope you guys can help.
Re: 440 mega block [Re: procharged 484] #1310477
09/25/12 08:25 PM
09/25/12 08:25 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Easy enough to tell the mopar blocks look like a regular 440 for the most part , the world does not.
Easiest way to tell is world block has a freeze plug on the front face of the block on either side of the waterpump mounting points
Re: 440 mega block [Re: JohnRR] #1310478
09/25/12 09:52 PM
09/25/12 09:52 PM
napa ca
P
P
napa ca
It's a mopar block not world. From what I understand several foundries tried some failed to cast the block over the years. What are the good ones??? Also this is a siamese block
Re: 440 mega block [Re: procharged 484] #1310479
09/26/12 02:30 PM
09/26/12 02:30 PM
napa ca
P
P
napa ca
Thank you guys for all your help and wisdom
