Re: 383 / BB oil pickup confusion [Re: RapidRobert] #1308775
09/24/12 06:00 PM
09/24/12 06:00 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Yes there's different bends on the big block pickups and baffled/non baffled/depth pans etc but I didn't know there was a difference between B and RB in that area
There isn't a difference between a B and RB unless the RB is a Hemi and then it's only the size of the hole drilled and tapped in the block . They list pickups by application/year, but the parts catalog is not completely accurate. That's why it's best to come onto a web forum and ask, though it's up to person asking the question how he/she will use the info gathered.
I do owe evan an apology being he is a mopar newbie. ...
But why ask a question if one isn't going to use the info, and then say you received incorrect info when you did not?
The catalog posted above clearly spells out what the application of one of the pickups in question is clearly used with and I am sure both pickups will work with either pan.
Re: 383 / BB oil pickup confusion [Re: JohnRR] #1308776
09/24/12 06:13 PM
09/24/12 06:13 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I purchased the 4529565 which the MP catalog lists for an RB application.
Engine is 70 383 HP with windage tray.
Do I need to get the 4529564 pickup instead?
Re: 383 / BB oil pickup confusion [Re: rss] #1308777
09/24/12 06:29 PM
09/24/12 06:29 PM
U.S.S.A.
U.S.S.A.
What pan do you have ? The 565 is a straight tube and it is to be used with the 6qt HEMI pan , it will work with the 187 pan after a slight bend and/or adding a windage tray and gaskets .
If you have a 402 pan, which is what was installed on a 70 383, you need the 564 pickup.
This is where the applications in the catalog are screwed up because a 68-69 440 (RB) uses the 402 pan ... the 893 pan for the A body can use the 564 pickup I set one up with it earlier this year ..
Though the other pickup with it's thinner tube wall might be easier to bend ??? But be careful bending it, either use heat or some type of tubing bender, you don't want to break the boss off in the block.
Re: 383 / BB oil pickup confusion [Re: JohnRR] #1308778
09/24/12 06:34 PM
09/24/12 06:34 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I've got a 402 pan, so looks like I'll be ordering another.
Thanks for the help
