Page 23 of 25 1 2 21 22 23 24 25
Re: new Moparts fastest car list, post yours! [Re: an8sec70cuda] #13074
11/05/06 09:32 PM
11/05/06 09:32 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
---6 second Zone ---
6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi
6.49 1/4 4.45 1/8 1.03 60' 85 ss 526 blown alan johnson hemi gator(jerry Farmer va)
---7 second Zone ---
7.16 @206mph 15psi of boost, TwinTurbo Daytona, Mike T
7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner
7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster.
7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330#
7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed
7.92 @ 173, 1.15 60' ,70 Cuda 3150# 500 inch Larry Morgan hemi torqueflite
7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383
---8 second Zone ---
8.02 @ 174+, The Haze, twin turbo 452",
8.10 @ 169, TS3303, 91 Daytona, 2470# 572 , glide, just motor
8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni
8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda
8.178@ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide
8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only.
8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005#
8.48 @ 160, sp6162, 80 Omni, 2170#, 500cu, Indy-1,/glide.
8.51 @ 157, hemi al588, 588 Hemi, single 4, '69 Dart, #3250
8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A
8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#
8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340#
8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650#
8.76 @ 156 OUTLAWSSAA 1.25 60FT 3120# HEMIDART
8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04
8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car.
8.78 @ 153.71 mph, Pittsburghracer, 91 daytona 499 rb 440-1 unported .690 roller 2400# with driver
8.781@ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER
8.859@ 151.00, 1.264 60’,Mopar_Racer_99, 68 Charger 572ci 440-1 heads,2880# 2065 den altitude
8.902@ 148.53, 1.244 60', 1974 Beeracuda, 2870 lbs, 499/PG 8 3/4
8.908@ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
8.94 @ 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s
8.97 @ 150.9 70dustmite440 70 duster 451 3300lb. lots of spray street driven homebuilt hotrod.slowest car in the 8's
---9 second Zone ---
9.04 @ 147.6 Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking
9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540
9.100@ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy
9.11 @ 145,Bill_LBSR, 68 Dart 3400 lbs 499/PG
86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS 9.14@148 ONLY 3 PASSES,WILL BE IN THE 8`S NEXT TIME OUT
9.14 @ 147mph, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs.
9.16 @ 147.78, Bigcube '69 Dart , 2975#, all motor, Indy -1 557cid
9.20 @ 148, 9secondsatellite, '71 satellite, 499" w/ 350 hp nitrous, 3976#
9.27 @ 144.50, 572charger 3850#, pump gas, 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car !
9.32 @ 141, 440Jim, 1.260 60', 5.874 @ 115.37, '69 Dart GTS 3160#, 511 CID NA, no roller cam, footbrake
9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys,
9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers
9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle
9.41 @ 148, hemitime, 1.39-60' 5.95 - 1/8 mile Car weight 4,020 lbs, '66 Dodge Charger, stock suspension - 100 shot of NOS - 549 c.i. Hemi - run on True 10.5 tire
9.43 @ 126, sloride, shutoff @ 1000', testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99 @ 136 on motor
9.44 @ 145.3 DusterDave '73 Duster 528 HEMI DOT's 3350# Street car
9.47 @ 142.5, MR P BODY, 395 ci W-2 2430#
9.48 @ 140.08w/1.270 60 ft, SKR8PN,470 low deck, 1993 Daytona,3000#,ALL MOTOR, street tires,thru the mufflers w/ POWER WINDOWS!!
9.513 @ 139.32 Dartsport505, #2755, 505cu.in. 1.283 - 60-foot
9.582@ 140.82 Eric, 81 Arrow 2354# tired 440 SR motor..:)
9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear
9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075 with me in it
9.61 @ 138, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire
9.72 @ 137.5, a10sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials
9.79 @ 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings!
9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire
9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker
9.85 @ 135 398-W2 Duster398
9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turobcharged 12# of boost EFI on Methanol
9.86 @ 137.95, maxwedgemandra63, 1.35 60 ft', 1965 dodge coronet 557 CI stroker 3104 lbs
9.89 @ 136.42, ProSport, 73' Dart sport, 451, E-heads, 727, 1.37 60 ft, 3035#, all motor
9.91 @ 142 mph,440 906 heads, Mrsixpak
9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet
9.94 @136.2, 1.43 60 ft,Cudabin, 67 Cuda, 470, Indy-1's, 2,870#, 727 Dana 4.56, 10.5W-31
9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs
9.952@ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs
9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA
9.97 @ 133.88 340RICK 70 Challenger 416 W5's leafs and street tires all motor
9.97 @ 135.46 1.36 60ft 493 john, 493" pump gas,street driven, foot brakin and no nitrous
9.978@ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor
9.994 @ 131.63 1.351 60 ft. (RBDuster) 73 Duster 446
9.995 @ 131.57 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it.
---10 second Zone ---
10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers
10.018 @ 131.09, almost in 9's
10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda
10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400
10.08@ 133 BigGreenDodge, 64 Dodge 440
10.088@ 137.53, 1.556 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3892# W/D, N/A.
10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads
10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb
10.12 @ 133.78 1.36 60' Dustinu 71' 340 duster W5398 3250+
10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake.
10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake
10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake.
10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA
10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA
10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda
10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam
10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400#
10.325@ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430#
10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630#
10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5"
10.43 @127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs
10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor.
10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's
10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#.
10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor
10.50 @ 127.00, daron 73 duster, sb street car
10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas
10.53 @ 128.5, DaveS 73 Swinger 446 906's auto, S/S springs
10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude
10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies
10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads
10.64 @ 124.50, 1.49 60', RVA, 440ci 3165#
10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers.
10.65 @ 123.43 1.45 60ft 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 11secdart
10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx
10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust
10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs.
10.70 @ 125 60' 1.50 3700 race weight 10secGTX
10.72 @ 125.41 1.507 60' 1974 Duster,446, Dap
10.76 @ 124, Mopartony, 68 Dart 470cid, 727
10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA
10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR
10.80 @ 123.1, Hemiallen, '66 Charger, 3450# w/ his son Michael driving
10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off)
10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX
10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
---11 second Zone ---
11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver
11.17 @ 120.56 1.56 60' super451b , 70 Superbee 383 , 3460 lbs.
11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs
11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs
11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI,
11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs
11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas
11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam
11.37 @ 122.19 1.808 60' 67 Charger 383 ironhead RemCharger
11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto
11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver
11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection.
11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver
11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim
11.489 @ 117.81, G-bob, 1.63 60', 3650 lb 67 Coronet, 91 octane pump gas
11.533 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425#
11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car.
11.598 @ 106.690 1.67 60' 67 Charger 440 3600# 8to1 iron head pump gas RemCharger
11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK
11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill
11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane.
11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles
11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto
11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears...
11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street
11.76 @113.8, 1.588 60', 77 Volare, 400/727 3660#
11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires
11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane
11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car
11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car
11.934 @ 113.187, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3710# w/ me
11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam
psyco goofed.
---12 second Zone ---
12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal.
12.02 @ 110, 1.58 60', cudadan
12.03 @ 111, 1.72, '66 Fury, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver Sportfury440
12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim
12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727
12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8
12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8
12.7 @ 107 69 M Clone 69 Dart 440/727/4.10 full street trim
14.025@ 96.08 BigGreenDodge, 72 Dart Swinger 318 Auto
9.14@148
Re: new Moparts fastest car list, post yours! [Re: 2QUICK4U] #13075
11/06/06 01:18 AM
11/06/06 01:18 AM
Lenox, MI
gj69charger Offline
gj69charger  Offline
Lenox, MI
10.80 @ 124.86, gj69charger, '69 charger, 500cid
psyco goofed.
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #13076
11/07/06 10:25 PM
11/07/06 10:25 PM
California
I
imin269 Offline
imin269  Offline
I
California
69 340 S
395 CU 11:1 CP Pistons, Stock Eddy's w Mopar 555 Solid Flat Tappet. @ 6K RPM she ripped out 513 HP w 501 ft lbs of torque. Sitting on slicks in the stock wheel tubs through full exhaust this black bad a$$ put down a best of:
11.09 @ 118.76 w a 1.47 60ft. This is of course in 80+ degree weather at California Speedway. I think she has a 10 second run in it before we're done tuning. The car weighs exactly 3000lb without me in it. Anyhow, thats my ride in a nutshell.
Re: new Moparts fastest car list, post yours! [Re: gj69charger] #13077
11/08/06 05:57 PM
11/08/06 05:57 PM
Renton Washington
Triple Threat Offline
Renton Washington
11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam
psyco goofed.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: new Moparts fastest car list, post yours! [Re: gj69charger] #13078
11/09/06 01:49 PM
11/09/06 01:49 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
8.81 @ 151.4, 1.268 60', STEFF, 70 Challenger, 526" B1, 3378lbs, 29.5 x 10.5 ET Drag, foot brake, ALL MOTOR
psyco goofed.
Re: new Moparts fastest car list, post yours! [Re: STEFF] #13079
11/11/06 08:01 AM
11/11/06 08:01 AM
pa
572charger Offline
572charger  Offline
pa
somebody add me on!572charger 8.99 at 152.00 1.39 60ft,on pumpgas at 3850 lb on street tires through the full exhaust and a little bit of no2!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: new Moparts fastest car list, post yours! [Re: 572charger] #13080
11/11/06 08:06 PM
11/11/06 08:06 PM
Ca Registered: Mar-2001
hemiallen Offline
hemiallen  Offline
8.99 at 152.00 1.39 60ft,on pumpgas at 3850 lb on street tires through the full exhaust and a little bit of no2! 572 Charger
10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 !
psyco goofed.
'05 Quad cab hemi truck- Flame red- magnaflow exhaust 70-440 cuda- 74-360-4v Challenger- new driver car EX vehicles: 66 charger Drag car- 10.80 at 123 mph 57 imperial 392 Hemi 1960 Sanger V drive- mondello-built 392 hemi
Re: new Moparts fastest car list, post yours! [Re: 572charger] #13081
11/12/06 09:19 PM
11/12/06 09:19 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
572Charger... You're my hero!!!
Re: new Moparts fastest car list, post yours! [Re: 1badx] #13082
11/12/06 09:58 PM
11/12/06 09:58 PM
Columbus Ohio
Moore & Moore Offline
Columbus Ohio
8.46 @ 160, Moore & Moore 70 Duster, 572 Wedge, Single 4, Glide, No Nitrous 2650 lbs
9.09 @ 148 Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs
psyco goofed.
Re: new Moparts fastest car list, post yours! [Re: Moore & Moore] #13083
11/14/06 05:20 PM
11/14/06 05:20 PM
Minnesota
Hemi_Joel Online content
Hemi_Joel  Online Content
Minnesota
86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS [Email]9.14@148[/Email] ONLY 3 PASSES,WILL BE IN THE 8`S NEXT TIME OUT
10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys
psyco goofed.
Re: new Moparts fastest car list, post yours! [Re: Hemi_Joel] #13084
11/14/06 06:54 PM
11/14/06 06:54 PM
Nelsonville , Ohio
Duster3105 Offline
Duster3105  Offline
Nelsonville , Ohio
psyco goofed.
12.55 @109.59, 1.95 60',73 Duster 360/904/4:56 Duster3105 (needs Bigger Conv)
Re: new Moparts fastest car list, post yours! [Re: Duster3105] #13085
11/14/06 08:13 PM
11/14/06 08:13 PM
Baltimore,MD
Bill_LBSR Offline
Bill_LBSR  Offline
Baltimore,MD
8.79 @ 151, 1.30 60', Bill_LBSR, 68 Dart #3400, Stock Suspension,BFG Drag Radial
psyco goofed.
LBSR
Re: new Moparts fastest car list, post yours! [Re: Bill_LBSR] #13086
11/14/06 09:15 PM
11/14/06 09:15 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
12.37 @ 108 BLUERR69 with a 1.73 60ft. 446 with 509cam and 3.23 gears @ 3800#.
Re: new Moparts fastest car list, post yours! [Re: Bill_LBSR] #13087
11/16/06 07:33 AM
11/16/06 07:33 AM
PA
P
PLATINUM6BBL Offline
P
PA
psyco goofed.
12.95@105.94, 1.94 60', PLATINUM6BBL 69-1/2 A12 Road Runner 3972# Pure Stock
Re: new Moparts fastest car list, post yours! [Re: topfueldart] #13088
11/19/06 12:11 PM
11/19/06 12:11 PM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
The Haze 8.02 @ 174+ twin turbo 452"
B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60'
Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only.
"Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156
Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04
Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG
NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph
acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137
440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID
Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor
440PURSUIT 10.073et @131.42 (134.98 best), 1.375 60'. 1/8 6.379 @ 107.24
Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam
StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor.
daron 73 duster 10.50 et @ 127.00 sb street car
TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust
LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas
aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto
w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver
440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street
493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57
68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car
topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft
cudadan, 12.02 at 110 with a 1.58 60ft
quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4
Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger Rallye wanna be RT
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1991.5 W250 Cummins- Big Chief
Re: new Moparts fastest car list, post yours! [Re: PLATINUM6BBL] #13089
11/19/06 10:21 PM
11/19/06 10:21 PM
NC
440Jim Offline
440Jim  Offline
NC
My new best, 9.27 at 141 mph. 440Jim
9.14 @ 148, '86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS
9.14 @ 147, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs.
9.27 @ 141.6, 440Jim, 1.251 60', 5.837 @ 115.5, '69 Dart GTS 3160#, 511 CID NA, no roller cam, footbrake
10.073 @131.42, 440PURSUIT, 1.375 60'
6.379 @ 107.24
psyco goofed.
12.95 @105.94, 1.94 60', PLATINUM6BBL 69-1/2 A12 Road Runner 3972# Pure Stock
Re: new Moparts fastest car list, post yours! [Re: 440Jim] #13090
11/21/06 10:17 AM
11/21/06 10:17 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
6.379 @ 107.24
11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart
psyco goofed.
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: new Moparts fastest car list, post yours! [Re: StripeHOG] #13091
11/26/06 11:15 PM
11/26/06 11:15 PM
S.L . MI
clutch Offline
clutch  Offline
S.L . MI
9.88@131.16 6.18@108 1.33 60' Clutch NA 512 ci pump gas Drag Radials
6.379 @ 107.24
psyco goofed.
Re: new Moparts fastest car list, post yours! [Re: clutch] #13092
11/27/06 07:56 PM
11/27/06 07:56 PM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster
6.379 @ 107.24
psyco goofed.
Re: new Moparts fastest car list, post yours! [Re: Dustedu] #13093
11/28/06 10:49 PM
11/28/06 10:49 PM
huron,ohio
b1headman Offline
b1headman  Offline
huron,ohio
Don't want to mess things up not posting right so if someone can post thank you. 2001 BOS RED 528 blown 871 B-1. 2010 lbs. .952 60ft. 4.09 @ 171 1/8 6.402@210 1/4 scott koffel
