Re: Best way to 2000 hp
[Re: mopar_mark]
#1307636
09/21/12 03:34 PM
09/21/12 03:34 PM
Posts: 43,336 Bend,OR USA
Cab_Burge
Being mid way through a Twin Turbo (4788's) fuel injected Hemi build, I can tell you this much . . . .
1) Work out your budget 2) Double the above 3) Add another 10% to the above, then you will be in the right ball park . . . .
Sure, I have heard of cheaper, more powerfull Mopar combos, but also hear a lot that crap in the pub. I could of possibly gone with cheaper parts, but then it gets into a vicous cycle
I am running a KB Block
That man be smart ![](/ubbthreads/images/graemlins/grin.gif) ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Performance Only]
#1307637
09/21/12 05:57 PM
09/21/12 05:57 PM
Posts: 568 Ky
moparmafia
Ky
Yes , they are moved away from the cylinder bores , with the 4.5 bore the o-ring gets real close to the stock dowl .
so is the kb block just thicker in this area? I was told my indy block was good for 2000+ hp
i wouldn't ever attempt 2000+ horsepower on a Indy block.
So what is the safe power level for an aluminum indy block?
