Add crank and cam pos sensors to BB (for Megasquirt)?
#1306943
09/19/12 06:50 PM
09/19/12 06:50 PM
Posts: 531 Virginia
JimG
Virginia
Well, I've now bought enough hardware that I'm comitted to a Magasquirt installation.
I have a 3.57 with the MS3X board. I'd really like to do sequential injection with Chevy LS coil-near-plug sequential ignition. To do this, I'll need a crank position sensor and and cam position sensor.
The crank sensor seems easy enough: just buy the proper diameter 36-1 trigger wheel and adapt it and the sensor to the harmonic balacer/front of the engine. That I can handle.
The cam sensor looks like it'll be the challenge. I could use a lean burn distributor for cam positioning only, but then I'd have distributor with no ignition wires bolted to the front of the engine. I'll save that as the drop-dead option. Somehow imbedding a magnet into the upper timing chain sprocket and installing a sensor through the timing cover crossed my mind, but I'm not sure my fabrication skills are up to the task.
So here we are. I'm open to ideas.
Thanks,
Re: Add crank and cam pos sensors to BB (for Megasquirt)?
[Re: JimG]
#1306944
09/19/12 07:55 PM
09/19/12 07:55 PM
Posts: 240 Shingle Springs Ca
haddixj
Shingle Springs Ca
I have a aquatintance who has done this same thing to a bbm. Ill see if he is ok with giving out his email.
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
[Re: haddixj]
#1306945
09/19/12 08:40 PM
09/19/12 08:40 PM
Posts: 531 Virginia
JimG
Virginia
[Re: JimG]
#1306946
09/19/12 09:06 PM
09/19/12 09:06 PM
Posts: 22,773 Bitopia
jcc
Bitopia
I could also cheat and fabricate a second trigger wheel with 2 teeth, and somehow attach it to the crank snout. Then I'd have no way to compensate for timing chain stretch, so that seems like a cheesy plan as well. Somehow imbedding a magnet into the upper timing chain sprocket and installing a sensor through the timing cover crossed my mind, but I'm not sure my fabrication skills are up to the task.
This more of a bump then an answer, but I don't think timing chain stretch is an issue period, its mainly for reference to start the timing sequence, and I don't believe to two tooth wheel solution works, period. I sure others will elaborate. i like the magnet imbedded in the chain sprocket though. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: JimG]
#1306949
09/19/12 10:22 PM
09/19/12 10:22 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Your gonna have to plug the dist. hole somehow & it's gonna have to be set up to control axial thrust on the oil pump driveshaft... So take lesson from Ford & create a stubby housing to mount a cam sensor...
[Re: 1_WILD_RT]
#1306950
09/20/12 11:08 AM
09/20/12 11:08 AM
Posts: 531 Virginia
JimG
Virginia
1 Wild RT:
I had already envisioned something like that when I was thinking this through, I just had no idea that it already existed. Thanks for posting.
Do you know what it fits? I need to find out if they're plentiful in junkyards. It might be possible to graft the top of this thing onto the bottom of a Mopar distributor.
Thanks,
ETA: Google is my friend! It looks like these things are common on late 90's 5.0 Ford Exploders and Mountaineers.
[Re: astjp2]
#1306951
09/20/12 12:02 PM
09/20/12 12:02 PM
DaytonaTurbo
Manitoba, Canada
A dual sync distributor will keep you from modifing things like balancers and timing covers. Tim
Yes that would work, but the OP specifically said he wanted to run coil on plug and not have a dummy distributor sitting around. I suggest just forgetting the COP setup and running a distributor. It will save you all this fabrication work and headache and I don't think will have any measurable difference in performance vs the COP system you are envisioning.
[Re: DaytonaTurbo]
#1306953
09/20/12 12:25 PM
09/20/12 12:25 PM
Posts: 531 Virginia
JimG
Virginia
Yes, I'm considering doing just that - getting it going in "fuel only" mode (with the existing ignition system) at first, then looking at integrating the ignition later.
The downside to running the existing ignition system is that I see no way get the equivalent of ported vacuum to keep the vacuum advance working as it does today. But, with all the fuel only systems available today, someone has probably come up with a workaround that I haven't stumbled onto yet.
One other startup option is to run COP in wasted spark mode and to run the fuel in batch fire rather than sequential - both possible without a cam sensor.
Thanks,
[Re: astjp2]
#1306955
09/20/12 12:34 PM
09/20/12 12:34 PM
Posts: 531 Virginia
JimG
Virginia
Fastman EFI has already done the big block conversion to COP, it uses a dual sync distributor without a cap and rotor. It acts as a cam and crank sensor in one. He has pics of it in his hemi book if I remember correctly. Tim
Good to know, thanks Tim!
I was unaware of this, and also thought you were referring to a "standard" dual sync distributor.
I'll definitely check it out.
[Re: JimG]
#1306956
09/20/12 12:44 PM
09/20/12 12:44 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Ford also used a setup like that on 3.8 & 4.2 V6 engines, there are many ways to do what you want, personally I like the idea of a very minimal sensor housing, it would look cleaner...
[Re: 1_WILD_RT]
#1306957
09/20/12 12:54 PM
09/20/12 12:54 PM
Posts: 21,523 It's a dry heat
gtx6970
It's a dry heat
EFI late model 4.0 Jeeps had a cam sensor where the dist USED to be (no idea if the OD the base is the same as LA or B motors ) Looks like this http://www.ebay.com/itm/Wrangler-Grand-C...9e5&vxp=mtrmight be able to adapt something over , or at least use it to design off of They have a crank sensor positioned on the back of the block that reads crank position off the windows on the flywheel
[Re: JimG]
#1306958
09/20/12 01:49 PM
09/20/12 01:49 PM
Posts: 12,248 Looking for a way out of Middl...
IMGTX
Can you just convert a small block Magnum distributor's trigger wheel to a Big block and use that? Of so a little time and epoxy can make a cover to replace the cap. Save $ Maintain stock easy to find parts. Keeps the distributor to oil pump shaft in place. Just curious ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: JimG]
#1306959
09/20/12 02:25 PM
09/20/12 02:25 PM
DaytonaTurbo
Manitoba, Canada
Thanks,
Megasquirt can control ignition timing without doing COP. Take a lean burn distributor or a stock electronic ign distributor(with the advance locked out) and throw it on. Megasquirt can control your entire ignition timing curve. From the outside it will look stock - distributor, wires, etc, but it's all computer controlled. That's why I say I don't think you will see any difference between this and COP. Generally I would not suggest going through all the work to go EFI just to leave a mechanical/vacuum distributor there.
[Re: JimG]
#1306962
09/21/12 11:45 AM
09/21/12 11:45 AM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
Jim, stick to your original idea with a crank sensor and tooth wheel, you don't want the bad precision from a distributor signal. The cam sensor on the other hand can be something simple like was suggested above. I have the same idea as you, if you know where I can get the good coils at a reasonable price, pm me... Martin ![](/ubbthreads/images/graemlins/musik010.gif)
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
