Re: 904 band adjustment
[Re: BRONZEBEE]
#1305500
09/18/12 01:33 PM
09/18/12 01:33 PM
Posts: 1,550 Michigan
Kiddart
when the pump was sent to the builder so were the drums, and valve body. The builder then repacked the drums with all new clutches and steels then went thru the valve body, a new pump was ordered at the same time from the same shop. he then sent to me and I reinstalled into a freshly washed and blown dry case. I would guess its a ring in there some where. if not it will all go to a trans shop and I will spend another few hundred on a rebuild for a rebuild?? see why its frustrating to me. I will win the battle i promise you that.
Thank you Kiddart
[Re: Clanton]
#1305504
09/18/12 10:16 PM
09/18/12 10:16 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I just use a 1/4 or 5/16 wrench and the jam nut is 5/8" I think and 3/4 on the front band.
Just wrist snug then back it off 2 to 2 1/4 turns low reveres can be looser as it is gust to apply reverse or low hold.
The front band has to stop the front drum to shift into second.
Re: 904 band adjustment(Re-Born)
[Re: Clanton]
#1305506
06/06/13 10:41 PM
06/06/13 10:41 PM
Kiddart
Hi moparts I am going to reserect this one. I finally had time tonight to do the air check. when i do the air check I hear a high pitch whistel in the front clutch hole and I hear a soft clunk in the rear clutch apply.when I do the front and rear servo apply I see the band tignten. Any thoughts on what it can be???
I know its been a while but at least I am at it now.
Thank you Kiddart
[Re: RapidRobert]
#1305508
06/07/13 12:36 PM
06/07/13 12:36 PM
Kiddart
thats my thought as well. It comes out AGAIN. This must be the 10th time. At least I am getting real good at it.
Thank you Kiddart
[Re: Kiddart]
#1305509
06/07/13 12:50 PM
06/07/13 12:50 PM
RapidRobert
What double R said, it was fine till the pump failed & not sure how a pump failure could cause subsequent problems (once you fixed the pump of course) other than debris went everywhere. Yes I'd totally strip it & clean every nook & cranny surgically clean then blueprint all subsystems back together.
