Whats the best flowing 360 exhaust manifold? #130438
09/30/08 09:50 PM
09/30/08 09:50 PM
Anonymous OP
Anonymous OP
I have a small block 360 in my pure stock race car. A pure stock is a bone stock car that races on a flat third mile track. I was wondering what exhaust manifolds that will fit on a 360 will flow the best? Any answer right or wrong will be greatly appreciated.
Re: Whats the best flowing 360 exhaust manifold? #130439
09/30/08 09:55 PM
09/30/08 09:55 PM
68-70 340 HP ex manifolds $300-$500 a set
Re: Whats the best flowing 360 exhaust manifold? [Re: RapidRobert] #130440
09/30/08 10:09 PM
09/30/08 10:09 PM
Land of Lost
flatlinedude Offline
No pulse
No pulse
Land of Lost
Magnum truck manifolds. People are giving them away.
Carol: "Wow! He's really fast, isn't he?!" John: "Yeah... but he's stupid."
Re: Whats the best flowing 360 exhaust manifold? [Re: flatlinedude] #130441
09/30/08 10:18 PM
09/30/08 10:18 PM
the 92/3 magnum truck ex manifolds have a much larger outlet than the later ones. iirc 1&7/8 on the later ones & over 2" on the earlier ones.
Re: Whats the best flowing 360 exhaust manifold? #130442
09/30/08 10:22 PM
09/30/08 10:22 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I think the Magnum manifolds are probably the best, but I'm not aware of a test that compares them to others. The early 340 manifolds above are really over-rated, and not significantly better than even 318 log manifolds. Here's a Mopar Muscle article that compares a pile of manifolds and headers on a 300hp crate engine. I wish somebody would do an article like that for big block manifolds, too.
Clair
Re: Whats the best flowing 360 exhaust manifold? [Re: Clair_Davis] #130443
09/30/08 10:31 PM
09/30/08 10:31 PM
I believe the 340 hp PASSENGER manifold & an early magnum truck DRIVERS manifold would be the best combination. just looking at the pass unit with it's flowing curves & 2&1/4" outlet I cant see any other manifold being better than that especially since I think the early magnum truck outlets are 2&1/8" The price differential is night & day, I obtained a set of the early good magnum truck ones for $50.
Re: Whats the best flowing 360 exhaust manifold? [Re: RapidRobert] #130444
10/01/08 09:40 AM
10/01/08 09:40 AM
Andrewh Offline
Andrewh  Offline
the durango ones, at least 2000 is a 2 inch outlet btw.
Re: Whats the best flowing 360 exhaust manifold? [Re: Andrewh] #130445
10/01/08 09:47 AM
10/01/08 09:47 AM
near Alexandria, VA
Gas_Bandit Offline
Gas_Bandit  Offline
near Alexandria, VA
What body style? A driver's side truck magnum manifold is not going to fit a lot of cars w/ the steering column in the way. So then you end up with 2 manifolds w/ different sized runners and outlets......
2003 Mercury Marauder, 34k miles, 3.73s and custom flash tuned
1981 Camaro, 350 w/ Holley Stealth Ram MPEFI, Sportsman heads, roller cam, self-burned chips, wideband O2
1983 Firebird TA
1993 Saturn SL2 83k
Re: Whats the best flowing 360 exhaust manifold? [Re: Gas_Bandit] #130446
10/01/08 12:10 PM
10/01/08 12:10 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I think it's even more interesting that the best headers tested (TTi's) only offered a small gain over the stock 340 manifolds.
Re: Whats the best flowing 360 exhaust manifold? [Re: RapidRobert] #130447
10/01/08 12:15 PM
10/01/08 12:15 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Too bad they didn't throw the magnum manifolds into that MM article.
Re: Whats the best flowing 360 exhaust manifold? [Re: ScottSmith_Harms] #130448
10/01/08 02:09 PM
10/01/08 02:09 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
10hp & 15 peak lb-ft is a pretty nice improvement...
keep in mind the cam in this thing is as meek as a stock 360 cam (actually slightly smaller in lift and maybe duration as a stock 360 magnum cam). pump up the cam even to say, comp XE262 type specs, and the HP and tq differential will change dramatically.
realistically, this engine should have been retested with all these exhaust options, but with something like a comp XE265HR in it as well...
2017 Grand Cherokee Overland
Re: Whats the best flowing 360 exhaust manifold? [Re: patrick] #130449
10/01/08 02:25 PM
10/01/08 02:25 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
The higher the state of tune, the more critical the exhaust gets. 15-20hp on a slug engine is nothing to sneeze at, and is the reason I decided to run TTI's on my Valiant's mild 340. With the headers, it makes an honest 300hp (260 to the rear wheels), and I wanted to sneak every last bit out of that engine.
I think it's time we all started emailing MM and twist their arm in to doing a follow-up article on a hotter engine (say, a 380hp crate), AND a big block manifold/header article, too.
Clair
Re: Whats the best flowing 360 exhaust manifold? [Re: Clair_Davis] #130450
10/01/08 02:47 PM
10/01/08 02:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Well (IMO) when talking about changing only one componant (exhaust) I don't see 10-15hp as a big deal, especially on a street car. Changing cams, intakes, etc. changes everything and tosses any real direct comparison out the window due to too many variables.
Of course a header will be the best ultimate performance choice, and for those seeking every bit of performance they are the easy choice. Personally, but I don't like running them on the street due to heat, noise, under hood clearance, cost, etc. etc. I'll give up the 10-15hp (and those are maximimums, not accross the RPM board gains) for the lack of such potential issues.
Re: Whats the best flowing 360 exhaust manifold? [Re: ScottSmith_Harms] #130451
10/01/08 05:15 PM
10/01/08 05:15 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
again, this was on a motor with a cam about as wild as a stock 318. I'd like to see the test run again with the same manifolds & headers, but the only change, swapping the 300 hp crate motor cam with something like a comp XR265HR which is IIRC 218/224 at .050 and ~.506" lift
I bet peak you'd see more like a 30-40 lb-ft spread and 20-40 hp spread over the manifolds, with the torque up much higher at all RPM ranges.
Re: Whats the best flowing 360 exhaust manifold? [Re: RapidRobert] #130452
10/01/08 05:59 PM
10/01/08 05:59 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
That's what I read in a Hot Rod article based on tests done by Mopar. I'll have to look for it, but they said that a combination of the two tyoes was the best. As for the "good" Magnum manifolds, the info below originally appeared in the June 1999 Mopar Muscle Pg 77 "Dakota Secrets"
1992 and early 1993 factory Magnum cast iron exhaust manifolds are larger than later manifolds. The 1992 manifolds are 2 1/8" inside diameter, and the newer models are 1 7/8" inside diameter. The casting numbers for the 1992/early 1993 exhaust manifolds are:
53006617(driver's side)
53006618(passenger's side).
Re: Whats the best flowing 360 exhaust manifold? [Re: Reggie] #130453
10/01/08 08:56 PM
10/01/08 08:56 PM
ky.
K
kenworth_goose Offline
K
ky.
Had a set from a 92 dodge ram van 5.2. They were 2 1/8 ID. Same as the big blocks. Ran them on a 89 dakota with a 360. Flow like headers without the hassel.
Re: Whats the best flowing 360 exhaust manifold? [Re: ScottSmith_Harms] #130454
10/01/08 09:01 PM
10/01/08 09:01 PM
Anonymous OP
Anonymous OP
FWIW, a couple of decades ago I put a set of cheapy headers on a 73 Duster 340 that was otherwise stock except for a spread-bore Holley, and picked up 7 tenths in the quarter compared to the factory exhaust manifolds.
Way more than a "small gain" . . .
Re: Whats the best flowing 360 exhaust manifold? #130455
10/01/08 09:28 PM
10/01/08 09:28 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
What I'd like to see in another article (and what I don't remember about the last one) is whether or not the testers went through the effort to actually TUNE the engine around the new VE created by the more efficient exhaust system. IIRC, they just bolted the stuff on and made another pull to crank out some numbers. If you're not tuning the engine for the new VE, you're leaving power on the table. If the carb was right for the log manifolds, it was almost certainly lean on the headers. Fatten that up to where it needed to be, and the gains may well have been larger, even on the limp engine.
As for the OP's question, I think I remember Ehrenberg recomending the 340 PS and Maggie DS manifolds, if they'll fit the chassis in question. The 340 PS manifold is the most rare, as that long casting seems to be pretty intolerant of puddles when it's hot, and can crack.
Clair
Re: Whats the best flowing 360 exhaust manifold? [Re: Clair_Davis] #130456
10/02/08 11:14 PM
10/02/08 11:14 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
As for the original question, the guy is running in a pure stock circle track class. Headers are not an option.
When we ran cast manifolds we used the 360 pre Magnuim truck manifolds. The ones without the emmision ports. Most had larger openings, had less restrictive flow patterns, fit most cars with minor tweaking, and were cheap and easliy available. Bolt on the largest diamiter pipe that will fit through the hole and go back at least to the trans crossmember. Make sure your fuel line doesn't pass someplace where the hot exhaust can get trapped around it. Gene
Re: Whats the best flowing 360 exhaust manifold? [Re: Andrewh] #130457
10/11/08 04:27 PM
10/11/08 04:27 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I was surprised a few years ago to find out
there was a special Jeep version of the Magnum 5.2 exhaust manifolds for Grand Cherokee use, including the 1998 year when a 5.9V8 was offered.
Is the Durango Magnum V8 ex manifold version mentioned different from the Jeep and the Ram truck versions ?
