Re: Gen 3 Hemi on dirt..
[Re: CHAPPER]
#1304130
10/16/12 09:14 PM
10/16/12 09:14 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Well Jerry? do you know what is going on here? isn't it 3,4,5 or 6 that is always exiting the block?
detonation on the short intake runner cylinders? oiling? Barton has it figured out
Yes, Jerry, please tell us..
it sure seems to me that the only time I hear of a rod leaving a new hemi is when it has a drag pack intake. there maybe other cases but I dont know of any and there are new challengers and chargers running low nines with boost at 4000lbs not having this problem
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: CHAPPER]
#1304132
10/16/12 09:31 PM
10/16/12 09:31 PM
sixpackgut
Charleston
doesn't make much sense does it and maybe it's just rpm oiling related but I have yet to hear why
[Re: CHAPPER]
#1304135
10/17/12 01:07 PM
10/17/12 01:07 PM
Posts: 2,578 sweden
1Fast340
sweden
what brand rod was it? ARP 2000 bolts?
From what I recall talking with CHAPPER...I know that Scat SB Chevy rods were used. I don't recall what rod bolt's were used.
ARP #8740 bolts were used as that is the bolt supplied with them. Probably should have upgraded, but have used them without any problems in the past. I am still at a loss, as are others apparently, just where the oiling problem is. I would have to guess right now, that it is in the crankshaft. I KNOW all oil passages in block and crank were clean and clear upon assembly. All clearances were acceptable to my standards with previous motors. The 'previous motors' do NOT include a Gen 3 Hemi though. I can't imagine the clearances being hugely different on a Hemi versus a big or small block Chevy, small block Mopar, big block Mopar, etc. The blackened crank is what really makes me wonder just what is taking place in these motors at 7000+rpm.
its just a mopar rejecting GM parts
now back to reality i doubt that the rodbolts are the problem unless you just had some bad luck. i seem to remember a thread or post over on the other site fastmopar.something about an isue with the cranks when turning higher rpms.you might want to check it out over there,sorry to say i cant remember wish thread or even wish section it was in..
[Re: 1Fast340]
#1304136
10/17/12 01:31 PM
10/17/12 01:31 PM
Posts: 2,826 NY usa
540challenger
NY usa
Correct there is a oil problem running a stock crank at high rpms' i forgot which journal or journals, but it was one of the middle rod bearings would lose oil at high rpms.
The fix is an aftermarket crank that drill the middle rod journals differently to help the oil flow.
[Re: CHAPPER]
#1304140
10/20/12 12:15 PM
10/20/12 12:15 PM
sixpackgut
Charleston
Nice, 90 years Dodge has made crankshafts and they get it wrong now
[Re: hemidup]
#1304145
10/21/12 10:39 AM
10/21/12 10:39 AM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Maybe we should put an ad in 'National Inquirer'...you know,,"inquiring minds want to know.."
After a long day at the track today, our transmission broke after the 3rd time trial so Denny and I had plenty of time to discuss "Fred Chapman, CSI".
Fred, I know you stated that the engine was running at 19*s @ WOT, but how did you determine this?
The ignition is the MSD Hemi6 setup. The timing was 'locked' at 19* with a laptop. I am putting my confidence in the ability of the young man that did this, as he was the one that installed the system and did the research/study of the system. I only know as much about the system as he explained to me, but I know he did not intentionally install any type of 'timing curve' into it. Are you still thinking 'detonation'..?
If you like drag racing, support your local track.
[Re: dvw]
#1304146
10/21/12 11:40 AM
10/21/12 11:40 AM
CHAPPER
Belpre,Ohio
First off sorry to see it. Not being a new Hemi expert, But. I question the broken bolt being the cause. How did the journal that hot after the bolt broke? I say lack of oil. At high RPM centrifugal force is trying to restrict oil going into the main journal. If the main doesn't get enough the rod is starved even worse. Just my 2 cents. Doug
The mains look good. I am open to any/all theories. The mains seem to be fine as far as oiling goes, but, I'm thinking the oil is not getting out of the main and on into the rod oiling passage. The #3 rod was the only one that seems to have starved for oil. #4 rod had some damage, but I believe it was caused by #3's problems. It would appear that the #2 main maybe oiling the #2 rod more than it's oiling #3 rod. I am having a hard time understanding why the crossdrilled crank is not moving more oil. Just for some more info, the #2 and #4 mains are the only mains crossdrilled on this crank.
