70 440+6 info needed #1303017
09/12/12 06:05 PM
09/12/12 06:05 PM
NW Indiana
A C Offline OP
A C  Offline OP
NW Indiana
How far ahead of the car's build date should the intake casting date be to be considered more or less correct? Also can anyone give me any leads on 70 carhs for an auto. car? Thanks.
Re: 70 440+6 info needed [Re: A C] #1303018
09/12/12 10:47 PM
09/12/12 10:47 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The intake is dependent on the assembly date of the engine vs. the assembly date of the car.
Did you try a want ad in the right place for your carbs ?
Re: 70 440+6 info needed [Re: JohnRR] #1303019
09/13/12 01:34 AM
09/13/12 01:34 AM
OWL
Culvers Offline
Culvers  Offline
OWL
Culvers
Re: 70 440+6 info needed [Re: Culvers] #1303020
09/13/12 10:48 AM
09/13/12 10:48 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Generally that Link has some value. But when it comes to Chrysler, things sometime rarely follow the norm. My 1971 Hemi Motor does not fit into much of the values or time they have set up. Block and head cast in 1968, assembled in 1969 so the 30 to 90 day time period is tossed out the window. I know why the motor to my 1971 Hemi Car has all these extreme date distances from the Cars assembly date and it is common to Hemi Motors put into Hemi Bodies built at the time my Car was assembled.I would think that for 1970 production you could follow some of the rules they have stated in the link.
1971 HEMI E BODY REGISTRY
