My luck ran out .....
#1302216
09/11/12 07:07 PM
09/11/12 07:07 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
Went racing last week and hurt the trans . First pass it launched a few feet and unloaded the tires and spun REAL good ..then hooked so i ran it out to a blistering 10.40 ![](/ubbthreads/images/graemlins/laugh2.gif) Next pass I put a 3K chip in it to calm her down a bit, let go of the button and it launched about 2 feet and ZINNNGG !! up on the 7K chip. For a split second I thought it just boiled the tires.... then realized the car wouldnt move. So i went to 2nd and then 3rd drove it back. No 1st gear , but I have everything else. My guess is my fancy bolt in sprag let her bits n pieces loose.... Yes ? I was just getting ready to order a ladder bar kit too.. ![](/ubbthreads/images/graemlins/maad.gif)
Re: My luck ran out .....
[Re: 493_DART]
#1302217
09/11/12 07:40 PM
09/11/12 07:40 PM
Posts: 20,720 in a cattle trailer down by th...
Guitar Jones
You may have broken something in the geartrain.
[Re: 493_DART]
#1302218
09/11/12 08:54 PM
09/11/12 08:54 PM
Posts: 6,572 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
You got a billet drum in that? If not it should have put the dash thru the windshield. If it is a stock one it is definitely time to retire it as I'm sure it is full of stress cracks now ![](/ubbthreads/images/graemlins/laugh2.gif) . Can a billet one be put back in service after turning 27 bazillion RPM? Kevin
[Re: Big Squeeze]
#1302220
09/11/12 09:55 PM
09/11/12 09:55 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I always worry about this with my 727. I assume it has a manual valve body with no low band apply. I hurt my last trans this same way and it had a bolt in sprag. just busted the case to turn the sprag.
67' charger 499 RB
10.57 at 127
[Re: 493_DART]
#1302222
09/11/12 10:20 PM
09/11/12 10:20 PM
dragram440
bigfork mn
I agree. The best thing would be to buy a good drum. Dont lift in first gear.
67' charger 499 RB
10.57 at 127
[Re: Twin Turbo Mower]
#1302234
09/12/12 02:40 PM
09/12/12 02:40 PM
Posts: 3,210 robin hood country
deaks
robin hood country
When i read the thread title, i thought your engine had gone bang. Kevin, i fitted an A & A VB with LBA, after the last time i broke the sprag. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
